Quantization of the electromagnetic field
5 replies · 2K views
Konte
TL;DR
quantization, electromagnetic field
Hi everyone,
It is about the quantization of the electromagnetic field. The expression of field E and B are defined with:
-the annihilation a- and creation a+ operators, and the frequency ω.
So my question is: how does these fields must be expressed if they where "static"? I mean, how the electrostatic and magnetostatic fields must be expressed in quantized version?
Thank you.
Konte
Konte said:
Summary:: quantization, electromagnetic field
Hi everyone,
Thank you.
Konte
In quantum theory a "situation" is described by the state, not by the operators describing observables.
Reply
Here's a rough sketch of how this problem is solved, using a scalar field instead of a vector field for simplicity.
We start with the KG Hamiltonian with a spatially-dependent source ##J(\mathbf{x})##:
$$H = \int d^{3}x ~\frac{1}{2}\pi^2 + \frac{1}{2}(\nabla \phi)^2 + \frac{1}{2}m^2\phi^2 + J\phi.$$ Rewrite the Hamiltonian in terms of a new field ##\psi## related to ##\phi## via
$$\phi = \psi + K(\mathbf{x}),$$ where ##K## is some fixed function. If we choose ##K## such that
$$-\nabla^2 K + m^2 K +J = 0,$$then (after integrating out surface terms) the Hamiltonian will simplify to
$$H = \int d^{3}x ~\frac{1}{2}\pi^2 + \frac{1}{2}(\nabla \psi)^2 + \frac{1}{2}m^2\psi^2 + ...,$$ where the ommited terms depend only on ##K##. The important point is that now the linear term is gone and we can expand via creation-annihilation operators as if the field were free.
The groundstate of the field in the presence of ##J##, which I will call ##|\Omega\rangle##, is defined by $$a_\mathbf{k} |\Omega\rangle = 0$$ where ##a_\mathbf{k}## is the annihilation operator associated with the field ##\psi.## Now ##a## is related to the annihilation operators of the original field ##\phi##, which I will call ##b##, by some relation along the lines of $$a_\mathbf{k} = b_\mathbf{k} - f(\mathbf{k})$$ where ##f(\mathbf{k})## is some c-number. You can figure out what ##f(\mathbf{k})## should be exactly from the second expression above if you feel so inclined (I don't). In any case the definition of the groundstate ##|\Omega\rangle## can now be rewritten as
$$b_\mathbf{k} |\Omega\rangle = f(\mathbf{k})|\Omega\rangle,$$ which means that ##|\Omega\rangle## is some coherent state of the free theory.
Reply
I have a little question that answer can surely help me to understand more: how do we express the interaction term (in the Schrödinger equation) with electrostatic field in the "Stark effect" case when we treat the field as quantized field ? In semi-quantum case, it is only expressed as the product of dipolar moment with classical electrostatic field : ##\mu . E##
