Quantum entanglement in communications possible?
In summary: Note that even after the measurement, the particle can still be in a pure state, but it is no longer in an entangled pure state.Now take a two-spin system in the entangled pure state|\Psi \rangle=\frac{1}{\sqrt{2}} [|\mathrm{up},\mathrm{down} \rangle - \mathrm{down},\mathrm{up} \rangle].Then the spin of particle 1 is described by the reduced Statistical operator\hat{R}=\text{Tr}_2 |\Psi \rangle \langle \Psi |=\frac{1}{2} \hat
Moviemann345
24
Is it possible to move an entangled particle, without disrupting the wave function, to create a communication signal?
well surely if a particle is entangled it's already displaying signs of 'communication' since what happens to one paticle will instantaniously affect the other?
There is no way to send information FTL if that's what you're wondering. Any interaction with a particle in an entangled states tends to break the entanglement, but even then there is no possible way for the two particles to exchange information, so you can't use them for communication. You can however do some very cool things like secure signaling, teleportation, dense coding and stuff, but nothing that violates relativity in any way.
Hold on a sec, why is interaction with a particle that is entangled, breaks the entanglement?
When you just look at one particle in an entangled pair (Bell state), it appears to be in something called a maximally mixed state, which means it has a 50/50 chance of being found spin up or down along ANY axis. But a measurement projects it into a pure state, and in a pure state you can always find an axis along which the probabilities are 1 and 0 or 0 and 1 for spin up/down. So after a measurement, the particle can no longer be in a mixed state, so the entanglement is broken.
Can you simplify by what you mean a mixed state? Are you referring to particle-wave-function property or something else?
A mixed state is used to describe a system whose state is not completely determined. A mixed state is described by a positive semidefinite self-adjoint operator [tex]\hat{R}[/tex] with [tex]\text{Tr} \hat{R}=1[/tex], the Statistical operator of the system.
A pure state is a particular case of this more general situation. [tex]\hat{R}[/tex] describes a pure state if it is a projection operator with [tex]\hat{R}^2=\hat{R}[/tex]. Then there exists a normalized state ket [tex]|\psi \rangle[/tex] such that [tex]\hat{R}=|\psi \rangle \langle \psi |[/tex].
[tex]|\Psi \rangle=\frac{1}{\sqrt{2}} [|\mathrm{up},\mathrm{down} \rangle - \mathrm{down},\mathrm{up} \rangle][/tex].
[tex]\hat{R}=\text{Tr}_2 |\Psi \rangle \langle \Psi |=\frac{1}{2} \hat{1}[/tex]
which is the state of maximal ignorance with respect to the von Neumann entropy as the information measure.
1. What is quantum entanglement?
Quantum entanglement is a phenomenon in which two or more particles become connected in such a way that the state of one particle can affect the state of the other, regardless of the distance between them.
2. How is quantum entanglement used in communications?
Quantum entanglement can be used in communications to transmit information securely and faster than traditional methods. By entangling particles and then separating them, information can be transmitted between them instantaneously.
3. Is quantum entanglement reliable for communication?
While quantum entanglement has been successfully demonstrated in laboratory settings, it is still a relatively new concept and its reliability for communication is still being researched. There are challenges such as maintaining entanglement over long distances and dealing with external interference.
4. What are the potential applications of quantum entanglement in communications?
Quantum entanglement has the potential to revolutionize communication technology by enabling secure and faster communication. It could also be used in quantum computing, quantum cryptography, and quantum teleportation.
5. Are there any ethical concerns surrounding quantum entanglement in communications?
As with any emerging technology, there are ethical concerns surrounding the use of quantum entanglement in communications. These include the potential for misuse or exploitation, as well as the impact on privacy and security. It is important for scientists and policymakers to consider these concerns and address them as quantum entanglement technology advances.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
