Quantum mechanics formalisms and conservation of energy
  • Context: Undergrad
  • Thread starter Thread starter KleinMoretti
    Quantum mechahnics
The discussion revolves around the implications of different quantum mechanics formalisms, specifically the Heisenberg and Schrödinger pictures, on the conservation of energy during measurements. Participants explore whether the choice of formalism affects the understanding of energy conservation in quantum systems, particularly when considering the system as open during measurement.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants question whether the formalism of quantum mechanics used (Heisenberg vs. Schrödinger) influences the conservation of energy during measurements.
  • It is noted that both the Heisenberg and Schrödinger pictures are mathematically equivalent and yield the same predictions, suggesting that the choice of formalism may not be relevant to conservation laws.
  • One participant references a previous comment indicating that in standard quantum mechanics, conservation laws do not hold for the measured system alone due to interactions with measurement devices.
  • Another participant raises concerns about non-equivalence between the Heisenberg and Schrödinger formulations, referencing external literature that discusses quantum field theory and methods of quantization.
  • There is a suggestion that discussions about quantum mechanics often do not specify the formalism, implying that answers may generally apply across different formulations.
Participants generally agree that the conservation of energy statement holds true regardless of the quantum formalism used, but there is ongoing debate about the implications of different formalisms and their relevance in specific contexts.
Some limitations are noted regarding the clarity of how different formalisms apply in quantum field theory compared to non-relativistic quantum mechanics, and the discussion acknowledges that certain assumptions may not be explicitly stated.
KleinMoretti
TL;DR
conservation of energy after measurement in different formalism of qm
in a recent thread @PeterDonis said that in standard quantum mechanics a system being measured must be considered open and you need to include the measurement device if you want to talk about conservation of energy, my question is if the formalism of qm used changes anything here?
What do you mean by this?
so for example if you used the Heisenberg picture as oppose to the Schrödinger
Why would that make a difference? Both pictures are mathematically equivalent and make the same predictions.
so what you said in that thread I mentioned,
"However, it should be noted that, in basic QM (i.e., without adopting any particular interpretation--discussion of how particular QM interpretations deal with collapse belongs in the interpretations subforum), "collapse" is not claimed to be an actual physical process; it's just an update you make in your mathematical model when you know the result of a measurement. Since making a measurement on a quantum system requires the system to be open, i.e., it has to interact with other systems, one would not expect conservation laws to hold for the measured system alone, since conserved quantities can be exchanged through the interaction. For example, the measured system could gain or lose energy from the interaction that takes place during meaurement, so its energy taken in isolation would not be conserved. Only the energy of the whole larger system, including the measuring device and anything else the measuring device interacted with, would be conserved."
is true regardless of the picture of qm you use right?
It's true in both the Heisenberg and Schrödinger pictures, yes.
so just for further clarification when someone says something is true or holds in standard or basic qm, the formulation (e.g Heisenberg, Schrödinger, interaction, etc) is not relevant?
Yes.
PeterDonis said:
Yes.
The reason I asked is because I came across a thread in physics stack that mentions that there are ways to make the Heisenberg and Schrödinger formulations non-equivalent and then I remember your comment from that previous thread here and got me wondering if the formulation one uses changes anything regarding conservation of energy after measurement.
Two of the papers referenced in that response are talking about quantum field theory, which is different from non-relativistic QM. In QFT it's not even clear at the outset what the "pictures" mean, since their definition requires a notion of "time evolution" (the difference in "pictures" in NRQM is in how much of the time evolution you put in the states vs. the operators), and in QFT there is no such notion, at least not in the basic formulation, because any such notion would be frame-dependent.
The other paper talks about methods of quantization other than the Born-Jordan prescription. That paper appears to be talking about NRQM, but AFAIK nobody actually uses any other methods in NQRM. I don't think that paper's analysis would even apply to QFT, since in QFT the whole question of "methods of quantization" is different.
another reason I was curious is because whenever I look through discussions or questions regarding QM (for example my question about conservation of energy in QM in that previous thread) most answers are with respect to quantum mechanics in general without mention of a formulation/picture which is why I wonder if that simply meant the answer is true regardless of the formulation/picture.
As has been stated, it does.
At this point the OP question has been answered and this thread is closed.
  • · Replies 18 ·
  • · Replies 33 ·
  • · Replies 22 ·
  • · Replies 39 ·
