- 8,943
- 2,956
rubi said:Let's assume we use the angles ##\theta_1=0^\circ##, ##\theta_2=45^\circ## and ##\theta_3=90^\circ##. We can prepare different experiments using these angles, for instance Alice sets her detector to ##0^\circ## and Bob sets his detector to ##45^\circ##. There are 6 possible combinations, but 3 of them will suffice to establish the non-existence of a joint probability space. Each of these situations determines an experimental situation (context). We can perform each of these experiments randomly and in the end collect all the data in the probability distributions ##P_i##. For example if ##i=1## refers to Alice using ##\theta_1## and Bob using ##\theta_3##, then we could ask for the probability ##P_1(\text{Alices measures }\rightarrow,\text{Bob measures }\uparrow)##. Of course, for another ##i##, ##P_i(\uparrow,\rightarrow)## makes no sense, because the experiment might not even have a detector aligned in one of these directions, so we are forced to collect our data in different ##P_i## distributions for each ##i##. After all, you wouldn't collect the data of LIGO in the same probability distribution as the data of ATLAS either. So after we have collected the ##P_i##, we can ask, whether all these ##P_i## arise from one joint probability distribution as marginals. And it turns out that this is exactly the case if and only if Bell's inequality holds.
The issue is whether there is a sensible notion of "local" that violates Bell's factorizability condition. You seem to be saying that there is no proof that there is not. Okay, I'll buy that. Then it takes on the role of a conjecture: that every plausible local theory is factorizable in Bell's sense.
