Quantum Mechanics: Speed of an electron
To find the speed of a 2.2 eV electron, the total energy must be calculated using the relationship Etotal = Ek + Erest, where Erest is the rest energy calculated as mc². The rest mass of the electron is 9.11 x 10^-31 kg, leading to a rest energy of 8.199 x 10^-14 J, which exceeds the given energy, indicating that the provided energy is likely kinetic energy. The kinetic energy equation used (Ek = 1/2 mv²) is only valid for speeds much less than the speed of light, and for relativistic speeds, the correct approach involves using the relativistic energy-momentum relationship. If the electron's speed is significantly lower than the speed of light, it can be treated as a classical particle for approximate calculations.
hquiquero
Find the energy (in joules), rest mass (kg), speed (m/s), wavelength (m), and momentum (kgm/s) of a 2.2 eV electron.
I'm having trouble finding the speed of the electron; once I have that I can find the wavelength and momentum.
E = energy
p = momentum
h = Planck's constant (6.63 x 10-34 Js)
c = the speed of light (3.0 x 108 m/s)
λ = wavelength
1 eV = 1.60 x 10-19 J
Etotal = Ek + Erest
E = hc/λ
p = h/λ
Energy of electron in joules:
2.2 eV = 3.52 x 10-19 J
Rest mass of an electron:
9.11 x 10-31 kg
****(Is this a correct answer or do I need to calculate rest mass?)
Speed of electron:
I tried this equation:
Etotal = Ek + Erest
Ek = Etotal - Erest
but it doesn't work because the total energy given for the electron is less than the rest energy calculated...
I'm not sure what equation other equation I can use. Also, I don't know if relativity must be taken into account if the electron's speed is close to the speed of light?
Thank you!
hquiquero said:
E = hc/λ
This is not true, because frequency is not equal to c/λ. You should leave it as E=hf.
hquiquero said:
Speed of electron:
Etotal = Ek + Erest
Ek = Etotal - Erest
Thank you!
The equation is correct, but what are you using for their values? The question gives you Ek, and you should be trying to find Etotal.
Also, you've come across an important point when you said if the electron's speed is close to the speed of light. Compare the rest energy to the Ek and you'll get the answer to this.
Sorry, that equation was for another part of the question about photons that I decided to leave out... the equation I'd use to find wavelength of the electron is λ = h/mv
I was using the given value for energy for the total energy, but when I calculated the rest energy you get
Erest = mc2
=(9.11 x 10-31)(3.0 x 108)2
=8.199 x 10-14 J
which is more than the given energy...
Am I supposed to use the given energy for the kinetic energy? And if so, does it just equal to 1/2mv2?
the energy they give must be the kinetic energy, because it is less than the rest energy.
In relativity, the KE is not 1/2mv^2. I think you should look over the basic definitions again. are you learning from a textbook, or a teacher or online? Wikipedia give a fairly good explanation.
What are you trying to calculate in this question? speed and relativistic momentum?
I am learning from an online course... I tried using the Ek = 1/2mv2 and got a speed that was only 0.3% of the speed of light, so I think that means I don't have to consider relativity in my calculations.. I could be wrong though?
You are correct that the speed of this particle is much less than the speed of light. But the equation you are using (Ek=1/2mv2) is not correct. It is only approximate when the speed of the particle is much less than the speed of light, and it is totally untrue when the particle's speed is close to the speed of light.
Do you know the equation for the energy of a particle in terms of gamma? This is where you should start to find the true speed of the particle.
Or you could just say that since the particle's speed is small compared to the speed of light, you could just treat it as a classical particle. (But this would be an approximate answer).
  • · Replies 34 ·
