Quantum Mechanics without Measurement
286 replies · 31K views · last reply
DevilsAvocado said:
In the case of the double-slit, we can be certain that knowledge of which slit will destroy interference.
That sounds like a "wave function collapse" interpretation. I don't think it's unambiguously true that knowledge destroys the interference. What you can say is that the normal ways that one might attempt to detect which slit the particle goes through destroys the inference. That's because setting up such a detector changes the complete situation. (From the point of view of dBB, each electron is influenced nonlocally by the complete setup, not just the facts about what's happening along its own path).
Einstein was very skeptical about CFD, and maybe we are paying too much attention to this regarding EPR-Bell, I don’t know...
CFD as in contrafactual definitess? I'm not sure I understand the relevance.
As you are saying, it only becomes a problem when we perform the measurement, i.e. suppose Bell required us to have a 'particle' with 6 incompatible values. Then we could build a model of a real spinning 'dice', that for some (unknown) reason will never let us see these 6 values simultaneously, and when we perform a measurement, we will only get one value, based solely on classical probabilities.
What's the problem!?
The problem is that this model works very fine for the 1935 version of EPR, where we theoretically could utilize a 'common influence' on the two 'twin dices', showing correlated behavior at measurement, i.e. if one shows even numbers, the other always shows odd, and vice versa.
This however is a dead parrot after 1964 and Bell's theorem, which mathematically proves that to have 'real twin dices' spinning at the source, the 'common influence' is not 'strong' enough to explain what happens in QM experiments (and predictions).
Bell's theorem has an essential step, which is the assumption that whatever hidden variables there are have an associated measure, or probability. I don't completely know what the physical meaning of nonmeasurable hidden variables would be, but it certainly is a necessary assumption for Bell's proof to go through.
stevendaryl said:
Whatever difficulties we have with compound statement "[itex]s_x = +1/2[/itex] and [itex]s_y = +1/2[/itex]", we'll have exactly the same difficulties with the compound statement: "If F1 is chosen as real, then [itex]s_x = +1/2[/itex] and if F2 is chosen as real, then [itex]s_y = +1/2[/itex]".
Ok, now I see. What you and atyy have in mind is to combine statements about the "real" histories in the frameworks. I agree with your view on this. What I was thinking when talking about meta-statements are statements about probabilities in frameworks. A combined statement of this sort would be "In framework F1, [itex]s_x = +1/2[/itex] has the probability p1 and in framework F2, [itex]s_y = +1/2[/itex] has the probability p2".
Yes, I agree with that.
Yes, of course any type of detection will destroy inference. But think of it like this:
  • If you close/measure one slit, we will know which slit.
  • If you close/measure one slit, inference is gone.
  • To get inference we must have two undisturbed slits open.
And this because no matter of interpretation CI, dBB, Path integral, etc, they all rely on the fact that one particle is generating interference with itself, by the difference in path length between two slits, as in any wave interference:
Simulated wave interference pattern showing circular wavefronts spreading from two sources on the left, with overlapping regions producing a grid of bright and dark bands.
There is no other way for one particle to interfere with itself (in this setup).
Now, imagine you had a "Perfect Theory" that is extremely precise, down to the size of the particle, and every time you prepared a particle, you would have full deterministic information on what it will do once you push the button and let it go, including which slit it will pass through.
So, what exactly would you see on the screen in a case with a "Perfect Theory"?
Well, if the theory is correct, you could close the slit you knew on beforehand it will not pass through, and still get interference on the screen!
But it doesn't work that way, does it? "Perfect Theories" don't change the outcome of empirical experiments, do they?
"Perfect Theories" are doomed to fail in the double-slit...
And I don't blame you; maybe no one knows exactly what went on in Einstein's head after the EPR paper...
In the 1935 EPR paper (which was written in English by Podolsky and Einstein didn't see the final draft) the first premise was "either quantum theory is incomplete or there can be no simultaneously real values for incompatible quantities", and then they went on trying to prove that incompatible quantities indeed could have simultaneous real values, by measuring them separately via entanglement, i.e. quantum theory is incomplete (according to EPR).
But after the EPR publication, Einstein started to work on a clearer version of the EPR argument, where both the criterion of reality and elements of reality was dropped out... and instead he focused entirely on locality/separability vs. completeness (in the state function).
You can read more about it here: http://plato.stanford.edu/entries/qt-epr/#1.3
According to the 1935 EPR criterion of reality, your (LHV) theory must be able to predict, with certainty, the value of the physical quantity. However, one could claim that there are real values indeed, but with current technology we can't reach them (and meanwhile we are 'fine-tuning' the theory :smile:).
The ingenious of Bell is that he handles this 'exception' as well (as in my 'dice example').
The implication is
We close one of the slits [itex]\Rightarrow[/itex] we know which slit it went through [itex]\Rightarrow[/itex] no interference pattern. But it doesn't follow that the interference pattern would be destroyed if we knew in some other way which slit it went through.
First, in dBB, knowing which slit the particle will pass through requires knowing which slits are open, so closing a slit will change the answer, even if the particle doesn't go through that slit.
But that's a nonlocal theory, so let's confine ourselves to local theories.
My first thought was that any argument against hidden variables must make use of probabilities, because Bell's proof makes use of them. But the nice thing about interference is that there are certain cases where the interference makes a 100% certain difference. In your case, there is a spot on the screen that has zero chance of a particle landing on it if both slits are open, and nonzero chance if only one slit is open (and vice-versa). So opening or closing a slit can potential make an observable difference without assuming anything about probabilities.
My original statement was motivated by EPR and Bell's proof, and there I know (because Pitowsky wrote a paper about it) that nonmeasurability can avoid the conclusion. But the two slit experiment is not obvious to me. Maybe you're right, but I'll have to think about it some more.
At the end of http://arxiv.org/abs/1105.3932, Griffiths says "Sensible quantum descriptions can be constructed from the perspective of someone outside the system being considered."
Does this mean that CH still has a measurement problem? Is what is outside and inside subjective? Is the observer still a primitive notion in CH?
stevendaryl said:
To say that we are forbidden to know which slit seems interpretation-dependent. For example, in the Bohm theory, the electron (or photon--I'm not sure if there is a Bohm theory for the photon) has a definite position at all times.
It does - but you can't know what it is. That's because its guided by this pesky pilot wave that has things like interference effects etc. That's why its a hidden variable theory. The particle is really common sense classical but it is intrinsically hidden.
Note I am not an expert on BM - that pretty close to the limit of my knowledge about it. If you want to go into it deeper I am sure guys like Dymistifyer will only be too happy to help.
Thanks
Bill
DevilsAvocado said:
Colour-coded simulation of a wave interference pattern: circular wavefronts spread from a source on the left and produce a grid of bright and dark interference fringes on the right.
You know that that's not strictly true, right?
We do still see an interference pattern from a single slit, but I think you know this already.
As I said, the real point is to pick some spot where the intensity of the interference pattern is 0 for one slit and nonzero for two slits. Then seeing anything at that spot means that both slits are open. So it seems that if the particle only takes one slit, then it must be influenced by the nonlocal information that the other slit is open.
Thanks
Bill
I was actually talking about something other than Bohmian mechanics, which is, the possibility of explaining QM through the use of local interactions, but using nonmeasurable sets. In the specific case of spin-1/2 EPR, I read an article where nonmeasurable sets were used to construct a model that reproduced the predictions of quantum mechanics (and evaded Bell's theorem, because he assumed that certain probabilities were always well-defined).
But in the case of the two slit experiment, I don't see how something similar could be made to work. It sure seems like the appearance of a particle at a particular point depends on nonlocal information--whether both slits are open. So a model with local hidden variables using nonmeasurable sets doesn't seem possible.
Nonlocal to what though? Nonlocal to an arbitrary slit, that the light seen at your observation point must have passed through, at some point in the past? It's not nonlocal to your observation point though.
Even then, it's certaintly not clear from a standard double slit experiment that a point at an arbitrary slit must gather information from the second slit in a nonlocal manner in order to display the interference that we observe.
Why is any of this important? Because if we don't consider it, we fall into using presumptions from Bohmian mechanics in our interpretation.
This thread has taken lots of twists and turns. The specific issue that the double slit experiment is relevant to is whether it is possible to explain QM in terms of a particle having a definite position at all times and being influenced by only local factors (that is, forces and so forth that are present along the path that the particle takes). It's hard to see how that is possible, because closing the slit that the particle doesn't go through seems to have an effect on the particle. Bohmian mechanics explicitly is nonlocal in this sense; even though the particle takes one path, its motion is affected by conditions along the other path.
Yeah, to my mind, in dBB the CFD particle "feels" out the geometry using a non-local pilot wave.
It's worth looking at the Transactional Interepretation too, which gives CFD, but is also explicitly non-local.
All the other interpretations abandon CFD so it becomes meaningless to talk of a single point particle between measurement events, but I think there is a lot of merit in understanding the double slit experiment in these contexts too.
So in answer to your question, I think it's safe to say that there is an overwhelming consensus that if you want an objectively real, single, point particle between measurement events then you have to have an interpretation with non-local influences.
But does the pilot wave have to be nonlocal in the double slit? After all, light already shows diffraction.
Well, in classical optics, light shows diffraction because the electromagnetic waves really do go through both slits, and recombine (either constructively or destructively). But if the particle intensity is low enough that only one particle (photon or electron) at a time goes through the slits, then it's hard to see how it can possibly go through both slits.
I could imagine that in the frame of reference of the particle everything works out. Shrink yourself down and imagine you are the particle. Would the two slits positions appear fuzzy and not well defined, sometimes overlapping so you could get through both at once? With a single slit it might be possible to make it through and achieve any final angle relative to your initial momentum by timing your transit so impact with a side wall to impart the desired momentum. But with two slits it might be impossible to achieve certain angles and some might be more likely than others.
Perhaps it is possible for the pilot wave to go through both slits, but the particle to go through one, just as in Bohmian mechanics. However, because only one particle is involved, the pilot wave can be a local wave like an electromagnetic wave.
In the two particle case, this would be like EPR/Bell again, but then one might hope the nonmeasurable loophole comes into enable local hidden variables.
But since this is a thread on consistent histories, does anyone have thoughts on this issue?
CH makes sense for an observer outside the system. Griffiths, http://arxiv.org/abs/1105.3932 (p30): "Sensible quantum descriptions can be constructed from the perspective of someone outside the system being considered." But, at least to me, it doesn't seem clear whether CH makes sense for an observer in the system. So the measurement is not solved, because we still have to define an observer outside the quantum system, with the quantum system being only a subsystem of the universe.
In Bohmian mechanics the CFD particle and the pilot wave are the electromagnetic wave and are non-local.
Wow. That's an interesting option. I always dismissed the pilot wave as an actual wave, precisely because of the fact that for multiple particles, it evolves in 3N dimensional configuration space instead of 3 dimensional physical space. But maybe it's only a real wave for single particles? Hmm. I have to think whether that's possible.
It sounds like a pretty complicated hidden-variables theory, though. But it might just work.
Somehow, I still don't understand your point here. There is nothing special about the observer in CH, as far as I can see. The observer is subjectively special (in that the observer thinks of himself as special). But there is no special physics involved in the observer, unlike in interpretations where observation collapses the wave function.
But can the observer be in all frameworks?
The observer has property X from framework Y and property X' from framework Y'?
I think it has a hard enough time being in one framework, completely at least, nevermind them all.
Can it be partly in all of them? That would be omnipresence.
stevendaryl said:
The implication is
Of course, some ancient symbols on a paper can't change anything happening in the real world, but if the physical consequence of these symbols are that we will know – with 100% certainty – that the particle we are about to send towards the double-slit will only pass through one slit*, this is will have the same effect as physically closing one slit, except in this case the 'closing' is theoretical.
*I haven't thought this through; but my guess is that it's enough to create a "Perfect Theory" that proves that the particle only goes through one slit (of course without any 'pilot influences'), to make the double-slit experiment 'break down', i.e. you are not required to tell exactly which slit ... I guess, maybe ...
True.
Graph of normalized intensity I(α)/I0 against α/π, showing a central peak of 1 at zero flanked by symmetric, decreasing interference maxima, i.e. the double-slit diffraction pattern.
Graph of N(q)/N0 against q/a from about -5 to 5: a thick red bell curve peaking near 1 at q=0, with two thinner black bell curves peaking near 0.6 at q=-1 and q=1.
Yes, it's a hard nut to crack, please let me know if you find any weakness in the argument.
Yes, I'm not an expert on this either (i.e. same status as on the rest of the enchilada :smile:), but I think that besides the pilot wave, Bohmian mechanics needs the quantum equilibrium hypothesis to be compatible to the Born rule (and experiments), as it otherwise would be a fully causal, deterministic model. I think...
Bell's proof simply fails for nonmeasurable local hidden variables. That doesn't mean they exist, but Bell's proof does not exclude them.
Yup, that's why I wrote "(in this setup)". :wink:
This has puzzled me. How is information 'transmitted' between the two 'pilot beams', to make the particle land on the screen in the right place? If a particle is going through one slit, accompanied by only one 'pilot beam', you won't get the correct result, do you?
Computed Bohmian trajectories for a double-slit experiment: curved flow lines spread from two slits on the left, forming an interference pattern as they reach the detection screen on the right.
Isn't there but a single "pilot wave" that goes through both slits?
