Quaternion Derivative: Product Rule Explained
The discussion centers on the application of the product rule in quaternion derivatives, specifically for the function f(q) = q* x a x q. Participants explore the right and left quaternion derivatives, highlighting the need for clarity in defining multiplication direction when calculating limits. A key point is that the function f(q) does not fit the forms required for left or right differentiation, indicating it lacks these derivatives. The conversation also references a theorem from quaternionic analysis that outlines conditions for differentiability in quaternion functions. Overall, the complexities of quaternion derivatives and their implications in analysis are emphasized.
abhiroop_k
How does the quaternion derivative work in the presence of a quaternion product.
More specifically, does the standard product rule apply for quaternion derivatives?
Say, I have a function f(q) = q* x a x q [where q -> quaternion, a -> const vector x-> quat prod]
what is the result of the operation d[f(q)] / dq ?
For quaternion, we have two kind of derivatives, the right derivative respect ## q## defined as
## \left(\frac{d}{dq}\right)_{r}f=\lim_{h\rightarrow 0}\frac{f(q+h)-f(q)}{h} ##
and in similar way the left derivative...
Thanks!
Could you please elaborate a little more w.r.t the example I mentioned?
I read a few articles and have come up with the following result for the equation i posed:
d [f(q)] / dq = [-(a x q)/2] + [q* x a]
Is this right?
yes it is possible, I don't understand the ##\frac{1}{2}##, using the definition
## \left(\frac{d}{dq}f\right)_{r}=\lim_{h\rightarrow 0}\frac{(q+h)^{*}a(q+h)-q^{*}aq}{h}=\lim_{h\rightarrow 0}\frac{q^{*}ah+haq+h^{2}a}{h}=q^{*}a+aq ##
I don't know if it is what you need because depends from the definition (other authors can use a different definition). Quaternionic analysis is useful in different fields as robotic, mathematical physics ... I wrote one chapter on my book of analysis about quaternionic analysis
http://www.lulu.com/it/it/shop/simone-camosso/analisi-matematica/paperback/product-20723617.html
( is in Italian ... )
I'm confused. What is "right" in this formula? What would the "left" version be? (I mean on the right-hand side of the equals sign.)
(Also, the division by h in the formula is not well-defined unless it is specified to be either left- or right-multiplication by 1/h.)
yes, right stands for right multiplication for ##\frac{1}{h}##, now that I see there is also an error in the previous example ... ## \lim_{h\rightarrow 0}\frac{q^{*}ah +h^{*}aq +h^{*}ha}{h}=q^{*}a+\lim_{h\rightarrow 0} h^{*}aqh^{-1}+ \|h\|^{2}ah^{-1}=q^{*}a -\frac{1}{2}aq## so the result agree with abhiroop_k ...
Given the function1
f(q) := q* a q​
(where a is a constant quaternion, and q* denotes the conjugate of q), what is the derivative d[f(q)] / dq ?
As mentioned, the usual definition of the derivative needs to choose whether to multiply the difference quotient on the right or on the left by 1/h before taking the limit.
We can try to use either
d[f(q)] / dq := limh→0 (1/h)(f(q+h) - f(q))​
or
d[f(q)] / dq := limh→0 (1/h)(f(q+h) - f(q))(1/h).​
Suppose we decide to try to use the top definition, the quaternion derivative on the left.
Then Theorem 1 from the paper Quaternionic analysis by A. Sudbery, Math. Proc. Camb. Phil. Soc. (1979), vol. 85 states:
If the left quaternionic derivative exists in some open set of the quaternions, then
f(q) = c + q d
where c and d are constant quaternions.​
(Of course the hypothesis means that the increment h can approach 0 from any direction.)
Likewise, if we assume the existence of the right quaternionic derivative as in the second definition above, then
f(q) = c + d q​
for some constant quaternions c and d.
Finally, if the function f is both left- and right-quaternionically differentiable, then we can conclude that
f(q) = c + r q​
for some constant quaternion c and real number r.
Because the function f(q) = q* a q is not (and cannot be expressed) in the form
f(q) = c + q d​
or
f(q) = c + d q,​
that means it does not possesses either a left or right derivative.
______________________________________________________________________
1 The original question has been edited and reformatted for clarity.
Quaternion functions as ## f(q)=q^{2} ## have some problem with differentiation in the sense that I used above, the Theorem 1 cited by Zinq is a classical result in quaternionic analysis. Possible results can be obtained focusing in a particular directions using the Gateaux derivative for quaternions
## Df(q)(h)=\lim_{t\rightarrow 0}\frac{f(q+th)-f(q)}{t} ##
with ##t\in\mathbb{R}##.
9K
  • · Replies 24 ·
21K
