Query concerning derivative of e^x
  • Context: Undergrad
  • Thread starter Thread starter Kaimyn
    Derivative E^x
6 replies · 12K views
Kaimyn
I've been studying calculus and have always been confused about the property of e^x.
"e is the unique number such that e^x is equal to its derivative."
I haven't ever really understood why, but have figured it would pop up some time later. Unfortunately, it still hasn't popped up, so I've decided to ask. How is e^x the derivate of itself?
I was mucking around with numbers a bit and came up with a couple of things:
Asumming e^x is its derivative:
[tex]y = e^{x^{2}+2}[/tex]
Then:
[tex]\frac{dy}{dx} = e^{x^{2}+2}[/tex]
However (using the chain rule):
[tex]\frac{dy}{dx} = 2xe^{x^{2}+2}[/tex]
Which isn't the same thing...
Also, while I'm on the topic, is there a way to calculate NP derivatives such as: [tex]2^{x}[/tex]?
I am sorry if this seems basic, or is commonly asked, but I just can't seem to figure it out.
Hi Kaimyn! :smile:
(try using the X2 tag just above the Reply box :wink:)
Kaimyn said:
… is there a way to calculate NP derivatives such as: [tex]2^{x}[/tex]?
2x = (eln(2))x = ex.ln(2), so (2x)' = ln(2).2x :smile:
(and since ln(e) = 1, e is the only number with (ex)' =ex)
Then:
The derivative of ex with respect to x is ex. If x is a function of t (ie., x = t2) and you want the derivative with respect to t of the whole expression, then of course you have to use the chain rule.
One common method is to take a logarithm (it doesn't have to be the natural logarithm) of both sides and use implicit differentiation (ie., use the fact that if A(x) = B(x) and A is differentiable, then A'(x) = B'(x)).
Then:
[tex]\frac{dy}{dx} = e^{x^{2}+2}[/tex][/itex]
You just said ""e is the unique number such that e^x is equal to its derivative."
Given that, it is impossible that [tex]e^{x^2}[/tex] is also its own derivative!
Why would you assume that?
Both tiny-tim and slider showed how to get the derivative of ex from the derivative of ln(x). Here's how to get it directly.
If f(x)= ax, for any positive number a, then
[tex]\frac{f(x+h)- f(x)}{h}=\frac{a^{x+h}- a^x}{h}= \frac{a^xa^h- a^x}{h}= a^x\frac{a^h- 1}{h}[/itex]<br /> <br /> Thus,<br /> [tex]\frac{da^x}{dx}= a^x\lim_{h\rightarrow 0}\frac{a^h- 1}{h}[/tex]<br /> <br /> In other words, the dependence on x can be taken out of the limit: since that limit does not depend on x, it is a constant.<br /> <br /> So, for any positive real number, a, the derivaive of a<sup>x</sup> is a constant time a<sup>x</sup>. <br /> <br /> It is not too difficult to see that if a= 2, say, then that limit must be less than 1 or that if a= 3, it is larger than 1. Thus, there exist a value of a between 2 and 3 such that <br /> [tex]\lim_{h\rightarrow 0}\frac{a^h- 1}{h}= 1[/itex] <br /> and we define e to be that number.[/tex][/tex]
Assuming you can find the derivative of ln(x) straight from the definition, you can use the chain rule to find the derivative of e^x.
[tex]\frac{d(ln(e^x))}{dx} = \frac{d(x)}{dx} = 1[/tex]
but [tex]\frac{d(ln(e^x))}{dx} = \frac{d(ln(u))}{du}\frac{d(e^x)}{dx} = \frac{1}{e^x}\frac{d(e^x)}{dx}[/tex]
therefore, [tex]\frac{1}{e^x}\frac{d(e^x)}{dx} = 1[/tex]
or [tex]\frac{d(e^x)}{dx} = e^x[/tex]
Thank you for all your helpful replies.
Thanks, now it actually makes sense.
[tex]\frac{f(x+h)- f(x)}{h}=\frac{a^{x+h}- a^x}{h}= \frac{a^xa^h- a^x}{h}= a^x\frac{a^h- 1}{h}[/itex][/tex]
[tex] <br /> Now I have "proof".<br /> <br /> <blockquote data-attributes="" data-quote="Random Variable" data-source="post: 2201477" cite="https://www.physicsforums.com/goto/post?id=2201477" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> Random Variable said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> [tex]\frac{d(ln(e^x))}{dx} = \frac{d(x)}{dx} = 1[/tex]<br /> <br /> but [tex]\frac{d(ln(e^x))}{dx} = \frac{d(ln(u))}{du}\frac{d(e^x)}{dx} = \frac{1}{e^x}\frac{d(e^x)}{dx}[/tex]<br /> <br /> therefore, [tex]\frac{1}{e^x}\frac{d(e^x)}{dx} = 1[/tex]<br /> <br /> or [tex]\frac{d(e^x)}{dx} = e^x[/tex] </div> </div> </blockquote><br /> Another mathematical proof that makes sense.<br /> <br /> <br /> Thanks again for all the helpful replies.[/tex]
