Question 19 - quadratic probility problem
  • Thread starter Thread starter thomas49th
    Quadratic
19 replies · 3K views · last reply
thomas49th
a) (i) (x-14)(2x-7)
(ii) x = 14 or x = 3.5
b)
i) [tex]\frac{7}{n+7}[/tex]
ii) Take n to be 8
[tex]\frac{7}{8+7}[/tex]
[tex]\frac{7}{15}[/tex] that DOESN'T round down to [tex]\frac{2}{5}[/tex]
Is that all correct so far?
If so I will post the next (really hard) question)...
Thanks
Why take n to be 8? Nothing is said about any value for n.
If 7/(n+7)= 2/5, SOLVE for n. What happens?
[tex]\frac{7}{n+7}[/tex] = [tex]\frac{2}{5}[/tex]
cross multiply!
[tex]\frac{35}{2n+14}[/tex]
now where?
Um...you're leaving out the equality part of the equation. Solve for n.
Alternatively, you can note that you have 35/(2n + 14) = 1. 35 is odd. 2n + 14 is even. Strange, isn't it?
Look, you're essentially supposed to say, "Suppose Bill is right. Suppose 7/(n + 7) = 2/5. Then such and such would follow." Why would the conclusion be a problem?
[tex]\frac{35}{2n+14}[/tex] = 1
now I need to get N on it's own (don't know how- please show). But I am guessing that n is greater than 3/5 so it CANT be right?
Multiply both sides of the equation by 2n + 14, so you end up with:
35 = 2n + 14
silly me...
2n = 35-14
n = 10.5
EDIT: Which as a fraction is 10/1/2 which DOESN'T equal 2/5...am i right yet. I doubt that's right...
You're getting there. What's the problem with n being 10.5. Look at your original assumptions. What are you tacitly assuming about the original n balls?
you can't have 1/2 a ball... :bugeye:
am I right or am I right
(probability of taking white x probability of taking yellow) + (probability of taking yellow x probality of taking white)
Is that somthing to go from?
Thanks
I got it down now to [tex]\frac{14n}{2n^{2}+28n+98}[/tex] = [tex]\frac{4}{9}[/tex]
is that right so far?
EDIT: is the question is says -28n but I've got +28n
EDIT 2: O no it must be this so far
[tex]\frac{14n}{n^{2}+14n+49}[/tex] = [tex]\frac{4}{9}[/tex]
got it!
[tex]\frac{4n^{2} + 56n + 196}{2}[/tex] = [tex]\frac{14n * 9}{2}[/tex]
[tex]\2n^{2} + 28n + 98[/tex] = [tex]68n[/tex]
[tex]\2n^{2} - 35n + 98 = 0[/tex]
and the answer to d must be 1/9
x must be 14 as you can't have 3.5 balls
