Question about algebraic transformation
  • Context: Undergrad
  • Thread starter Thread starter Peter_Newman
    Transformation
The discussion revolves around the algebraic transformation of an equation involving inner products and orthogonalized vectors, specifically in the context of the Gram-Schmidt process. Participants seek to understand how to manipulate the equation to demonstrate a relationship between the inner product of a vector and its representation in an orthonormal basis.
  • One participant seeks clarification on transforming the equation involving inner products of orthogonalized Gram-Schmidt vectors.
  • Another participant suggests expressing the vector in terms of its Gram-Schmidt basis and notes the orthogonality of the basis vectors.
  • Several participants discuss the implications of expressing a vector in different bases and how to simplify the resulting expressions.
  • There is a proposal to utilize the properties of inner products and orthogonality to derive the desired equation.
  • Some participants express uncertainty about the correctness of their simplifications and seek verification from others.
  • One participant mentions the potential for a simpler approach using normalized orthonormal bases.
  • Another participant questions the assumptions made regarding the orthogonality of the original vectors.
Participants generally agree on the importance of the orthogonality of the Gram-Schmidt vectors, but there are multiple competing views on the correct approach to simplify the expressions. The discussion remains unresolved as participants explore different methods and seek clarification on specific steps.
Participants express uncertainty about certain mathematical steps and simplifications, particularly regarding the representation of vectors in different bases and the implications of orthogonality. There are also references to potential limitations in their approaches, but these remain unresolved.
Peter_Newman
Hello,
I would like to reproduce the following equation, but I don't quite understand how to do the transformation:
$$ \sum_{i=1}^k \left( \frac{\langle y , x_i^* \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2 = \langle y, y \rangle$$
Where ##x_1^*,...,x_k^*##, are orthogonalized Gram-Schmidt vectors of ##x_1,...,x_k \in \Lambda## and ##y \in span(x_1^*,...,x_k^*) = span(x_1,...,x_k)##.
I would be very grateful for any helpful hints!
I think this reduces to recognising that <br /> y = \sum_{i=1}^k \frac{\langle y, x_i^{*} \rangle}{ \langle x_i^{*}, x_i^{*} \rangle }x_i^{*} <br /> =\sum_{i=1}^k \frac{\langle y, x_i^{*} \rangle}{ \sqrt{\langle x_i^{*}, x_i^{*} \rangle } }\frac{x_i^{*}}{ \sqrt{\langle x_i^{*}, x_i^{*} \rangle } } and noting <br /> \left \langle \frac{x_i^{*}}{ \sqrt{\langle x_i^{*}, x_i^{*} \rangle } }, <br /> \frac{x_j^{*}}{ \sqrt{\langle x_j^{*}, x_j^{*} \rangle } } \right\rangle = \begin{cases} 1 &amp; i = j, \\ 0 &amp; i \neq j.\end{cases}
If you express ##y## in the ##\{x_i\}## basis, then it should be clear.
Edit I meant ##\{x_i^*\}## basis. Apologies for the confusion caused.
Hello @pasmith thank you for your reply!
So if I understand the first part correctly, then that is in words ##y## expressed as its Gram-Schmidt "version"
Hello @PeroK thanks also for your answer. YES that was my approach too, but so right I don't see that. Let ##y = \sum^k c_i x_i## in its ##x_i## basis, but then I would have in the big sum something like:
$$\sum_{i=1}^k \left( \frac{\langle y , x_i^* \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2 = \sum_{i=1}^k \left( \frac{\langle \sum_{j=1}^k c_j x_j , x_i^* \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2$$
then I would use to reduce the sum in the second part this property ##\langle x+y, z\rangle = \langle x,z \rangle + \langle y,z \rangle##, but that doesn't really seem to help me?
And from here I do not really see how we achive ## \langle y,y\rangle##. It would be nice if you can help me further. :smile:
Set y = \sum_{i=1}^k a_ix_i^{*}. The point is that as the x_i^{*} are orthogonal, <br /> \langle y, x_j^{*} \rangle = \sum_{i=1}^k a_i \langle x_i^{*}, x_j^{*} \rangle<br /> = a_j \langle x_j^{*}, x_j^{*} \rangle.
You use the orthogonality of the ##x_i##. Note that if use the normalised, orthonormal version of the basis then the result is trivial.
PS that gives another possible approach.
@pasmith I agree with that (and great hint!), but let's go some steps further. If we take this result into the big sum we would have (and recap that we have ##\langle y, x_i^{*} \rangle##)
$$\sum_{i=1}^k \left( \frac{\langle y , x_i^* \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2 = \sum_{i=1}^k \left( \frac{a_i \langle x_i^{*}, x_i^{*} \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2 = \sum_{i=1}^k \left( a_i^2 \langle x_i^{*}, x_i^{*} \rangle \right) = \sum_{i=1}^k \left( a_i^2 {x_i^{*}}^2\right) = ||y||^2$$
Right?
@PeroK how would you do this with your recommendation using ##y## in the ##x_i## basis? :cool:
Right?
How much time are you willing to invest?
Here is an interesting read about the geometry behind those products:
https://arxiv.org/pdf/1205.5935.pdf
Perhaps this should be posted as homework!
Thanks for all the help so far! That is very nice. I currently still have two open points:
1. Is what I have done in post #8 so correct? Can I leave it as it is?
2. I would like to know how to do the representation of ##y## to the base ##x_i##. I have already started to do this, see post #4, but I do not really get further. @PeroK it would be nice if you could help me here maybe again, because as simple as you say, I do not find that.
My approach:
Let
$$ y = \sum_{j=1}^k c_j x_j$$
Then
$$ \sum_{i=1}^k \left( \frac{\langle y , x_i^* \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2 = \sum_{i=1}^k \left( \frac{\langle \sum_{j=1}^k c_j x_j , x_i^* \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2 = \sum_{i=1}^k \left( \frac{\sum_{j=1}^k c_j \langle x_j , x_i^* \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2 $$
But I'am not able to simplify the last expression... I think the idea is to simplify or rewrite ##\sum_{j=1}^k c_j \langle x_j , x_i^* \rangle## but I don't see it...
My approach:
Let
Then
Due to policies of the forum I cannot very directly help you, but why, my friend, are you not simplifying that
## \sqrt{ \langle x_i^*, x_i^*\rangle}## to the norm of ##x_i^*##?
And didn’t you yourself write in the original post that $$y \in span\{x_1^*, \cdots, x_k^*\}$$? But you equated ##y## to a span of ##x_1, \cdots, x_k## in your last post.
The ##x_i## are orthogonal. What does that mean when ##i \ne j##?
@Hall you mean ##\sqrt{ \langle x_i^*, x_i^*\rangle} = ||x_i^*||## right? And with the idea that ##y \in span\{x_1^*, \cdots, x_k^*\}## I would have suggested that the simplification is then this, what I did in post #8 (but for this I have no final verification from someone here, but for me it looks good). But is this what you mean?:
With:
$$y = \sum_{j=1}^k a_j x_j^*$$
$$ \sum_{i=1}^k \left( \frac{\langle y , x_i^* \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2 = \sum_{i=1}^k \left( \frac{a_i \langle x_i^{*}, x_i^{*} \rangle}{\sqrt{\langle x_i^*, x_i^* \rangle}} \right)^2 = \sum_{i=1}^k \left( \frac{a_i^2 ||x_i^{*}||^4}{||x_i^*||^2} \right) = \sum_{i=1}^k \left( a_i^2 ||x_i^{*}||^2 \right) = \sum_{i=1}^k \left( ||a_i {x_i^{*}}||^2\right) = ||y||^2 $$
(I'am not sure if the simplification with the norm is correct in the last step(s))
@PeroK in the case of ##i \ne j## I would say, that ##\langle x_i, x_j \rangle = 0##. But from what comes your assumption that the ##x_i## are orthohonal (that the ##x_i^*##'s are pairwise orthogonal is clear because of the Gram Schmidt process)?
It is as correct as it can be.
@Hall thank you for your verification that is very good! 👍
Now the only missing part is to show the same but expressing ##y## in the ##x_i## basis. I am curious to see what happens next here.
I got the assumption from your original post:
Hello @PeroK thank you for your reply. I'm actually still interested in a solution via your approach, and would like to work that out (with your help).
The ##x_i^*## are orthogonal to each other that is clear, since these arise from the linearly independent ##x_i##'s by the Gram Schmidt procedure. But that does not mean that the ##x_i##'s are also orthogonal? With the Gram Schmidt method it is enough that the input vectors are linearly independent, the goal is the orthogonal basis.
A little example let ##x_1= (1,0)^T, x_2 = (1,2)^T## they are linear independent and span the space and let ##x_1^* = (1,0)^T , x_2^* = (0,1)^T## they are linear independent and orthogonal due to the Gram Schmidt process and span ##\mathbb{R}^2##. But what I mean is, and that's something I don't quite understand, why one can say that the ##x_i##'s are orthogonal.
From that we get ##\vec{a}\cdot\vec{b}=|\vec{a}|\cdot|\vec{b}|\cdot\cos\left(\sphericalangle\left(\vec{a},\vec{b}\right)\right).##
@fresh_42 nice plot! But I don't know what you want to say with this... (I know this plot and also the dot product but, I can not relate it to my problem above)
Peter_Newman said:
@fresh_42 nice plot! But I don't know what you want to say with this... (I know this plot and also the dot product but, I can not relate it to my problem obove)
The cosine gets ##0## if and only if the angle gets ##90°.## So the dot product can be used to "detect" right angles. Your question reduces to prove
\sum_{k=1}^na_k\cdot b_k= \sqrt{\sum_{k=1}^n a_k^2}\cdot \sqrt{\sum_{k=1}^nb_k^2}\cdot \cos (\sphericalangle (a_k,b_k))
or
\cos (\sphericalangle (a_k,b_k))=\dfrac{\sum_{k=1}^na_k\cdot b_k}{\left(\sum_{k=1}^na_k^2\right)\left(\sum_{k=1}^nb_k^2\right)}
This is basically the definition of the cosine and the image above illustrates it.
@fresh_42 ok, I understand what you want so say. But I don't know how this exactly helps If I express ##y## in the following way ##y = \sum_{i=1}^k a_ix_i## and then trying to reduce/simplify this ##\langle y, x_j^{*} \rangle = \sum_{i=1}^k a_i \langle x_i, x_j^{*} \rangle## because I don't know the angle between the ##x_i##'s and the ##x_j^*##. The great thing was if one expresses ##y## in ##x_i^*## basis that one can directly see the orthogonality, but with ##y## in the ##x_i## basis this is much more complex.
You need to write ##y = \sum_{i=1}^k a_ix_i^*## since otherwise, you have to deal with an additional basis transformation ##x_k=\sum_{i=1}^k b_ix_i^*## which complicates the issue unnecessarily. The ##\{x_i^*\}## is a ONB, so why not use it?
I am absolutely d'accord with you. Yes of course you can express the ##y## using the ##x_i^*##. This is also the way, which is absolutely plausible (I have shown this here #14, @Hall was so friendly to confirm this :smile: ). But @PeroK had here #3 suggested that this also goes if one expresses ##y## in such a way with the ##x_i##'s (the way is more difficult that's true, but that interests me :smile: )
But I think, this is not so "clear". :oldconfused:
Apologies for the confusion. It somehow didn't register that ##x_i## is the original basis and the orthogonalised basis has a ##^*##. I can't explain how I missed that!
  • · Replies 25 ·
  • · Replies 40 ·
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 52 ·
