Question about chemical potential
In a gas composed of two different kinds of particles, there are indeed two distinct chemical potentials, one for each species. Chemical potential is an abstract quantity that reflects the change in energy when a particle is added, while keeping entropy, volume, and the number of other particles constant. This concept is illustrated in biological systems, such as electrolytic solutions, where varying concentrations of ions create different driving forces across cell membranes. The Nernst equation relates the chemical potential difference to voltage, which can be measured in laboratory settings to assess cellular function. In the case of ideal gases, the chemical potential for each species is proportional to the logarithm of its partial pressure.
Einj
It is probably a silly question, but here it is. Suppose we have a gas composed by two different kinds of particles. There will be two different kinds of chemical potential? One for each specie?
Chemical potential is not some substance that can "be there in the container". It is rather an abstract mathematical quantity that gives the change of energy of the container when one particle is added, while the entropy, volume and numbers of other particles are kept at the same value.
As the change of energy depends on the kind of particle one is adding, there is different chemical potential to each different kind of particle.
Yes- a good example is an electrolytic solution, such as found within biological systems. The cytosol of your cells has high potassium, low sodium, and *very* low calcium concentrations, while the outside (extracelluar space) has high sodium, low potassium and low calcium concentrations. Thus, there are different driving forces on the ions corresponding to the different concentration gradients across the cell membrane. For sodium and calcium, the electrochemical potential difference is always strongly negative- sodium and calcium ions experience a strong driving force into the cell. Potassium's electrochemical difference is close to zero or slightly positive, so potassium ions experience a weak driving force out of the cells.
The Nernst equation shows that in equilibrium, the chemical potential difference across a membrane is equivalent to a voltage. In my lab, we measure this voltage as an electrophysiological readout of cellular function.
Perfect! Thank you very much!
Just wanted to add that in case of ideal gasses the chemical potential of each species is \mu_i=\mu_0+RT \ln p_i/p_0, i.e. the chemical potential is proportional to the logarithm of partial pressure of each species.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 28 ·
  • · Replies 16 ·
