Why Does an Object Appear Blue When All Other Frequencies are Absorbed?
  • Context: Undergrad
  • Thread starter Thread starter KGC
The discussion centers on the phenomenon of color perception, specifically why objects appear blue when they absorb all other light frequencies. Participants explain that the color of an object results from the wavelengths of light that are reflected, while absorbed light energy is converted into thermal energy rather than being re-emitted as photons. The conversation highlights the importance of energy levels in atoms and the phonon mechanism, which describes how absorbed energy increases atomic motion, contributing to heat rather than light emission.
  • Understanding of light absorption and reflection principles
  • Familiarity with atomic energy levels and electron transitions
  • Knowledge of phonon mechanisms in solid materials
  • Basic concepts of thermal energy and heat transfer
  • Research the phonon mechanism in solid-state physics
  • Study atomic energy levels and their relation to photon absorption
  • Explore the concept of indirect band gap materials in photonics
  • Learn about the relationship between thermal energy and color perception
Students of physics, materials scientists, and anyone interested in the principles of color perception and light-matter interactions.
KGC
Quick question about colour. As far as I understand it the colour of the object comes from the frequencies of light reflected?
My question though is when the light absorbs some of the frequencies would this not cause the excitiion and decay causing the material to emit photons of the absorbed colour?
I am not sure why if all frequencies but blue (for example) are absorbed the object would appear blue?
Thanks for any help.
Science news on Phys.org
Most colours seen in ordinary experience are caused by the partial absorption of white light. The pigments that give colour to most objects absorb certain wavelengths of white light(adding to the internal energyof the object) and reflect or transmit others, producing the colour sensation of the unabsorbed light
What happens to the absorbed light though, how come it is not re-emitted when the electron goes back down an energy level.
The wavelengths that are reflected, is this because there is no electron requiring that energy to get up a level?
You may want to start by reading the FAQ thread in the General Physics forum. The entry that might be relevant is on the speed of photons through a material. The discussion on the phonon mechanism within the material is relevant here. It tells you that the absorbed energy is directly converted into the vibrational (thermal) energy of the material.
Zz.
This only happens when the atom has an energy level that matches the energy level of the photon. If the energylevel does not match the photon energy, it does not go back to the light. The energy instead goes toward increasing the motion of the atoms, which causes the material to heat up
Zz.
Hi ZapperZ! :smile:
I don't get it. :redface:
If the "spring" absorbs a photon, it goes into a higher mode (presumably in the form of a roamier electron) …
why doesn't it then fall to the original mode, and release an identical photon?
Obviously, it doesn't, and the energy is passed instead to an adjacent "spring" …
but how does that happen (since they're not actually springs)? :confused:
tiny-tim said:
Hi ZapperZ! :smile:
It's not a "coherent" absorption. Think of it as being similar to an absorption of a photon by an indirect band gap.
The vibration can easily be absorbed by the solid as heat, so there is more than one way (other than photon emission) for that energy to be dissipated. So when you have such a collective excitation whereby the phonon mode is available, the whole solid can absorb that energy.
Zz.
  • · Replies 40 ·
