Undergrad Question about Complex limits of definite integrals
The discussion centers on the application of the Gamma function and its integral representation for complex values. The integral $$\Gamma(s) = \int_{0}^{\infty} e^{-x} x^{s-1} dx$$ can be extended to complex values of the parameter \(a\) through a parameterized path integral, specifically along the contour defined by \(\gamma_{\theta}\). The use of Cauchy's integral formula and the residue theorem is essential for proving the equivalence of the integrals along different paths, particularly when no poles are enclosed. The integral's behavior as the contour approaches infinity is also discussed, emphasizing the importance of understanding complex analysis in this context.
  • Understanding of the Gamma function and its properties
  • Familiarity with complex analysis concepts, particularly Cauchy's integral formula
  • Knowledge of the residue theorem and its applications
  • Ability to perform contour integration and parameterization of paths
  • Study the proof of Cauchy's integral formula in detail
  • Learn about the residue theorem and its implications for complex integrals
  • Explore the concept of contour integration and its applications in complex analysis
  • Investigate the behavior of integrals along different paths in the complex plane
Students and professionals in mathematics, particularly those focusing on complex analysis, integral calculus, and mathematical physics. This discussion is beneficial for anyone looking to deepen their understanding of the Gamma function and its applications in complex domains.
MAGNIBORO
Hi, I see a formula of gamma function and i have a question.
(1) $$\Gamma (s) = \int_{0}^{\infty } e^{-x}\, x^{s-1} dx$$
(2) $$ x=a\, n^{p} \rightarrow dx=ap\, n^{p-1}dn$$
(3) $$\frac{\Gamma (s)}{pa^{s}} = \int_{0}^{\infty } e^{-an^{p}}\, n^{ps-1} dn$$
i understand the formula but why works for complex values of a?
i mean the substitution in (2) is valid for ##a > 0## and ##p>0##
Because otherwise the upper limit would be ##\pm \infty \, i ## or ## \infty \ \pm \infty \, i ##
Depending on the value of a.
thanks
Let's define for all -\frac{\pi}{2}<\theta<\frac{\pi}{2} a line
<br /> \gamma_{\theta} = \{\tau e^{i\theta}\;|\; \tau\in\mathbb{R},\;0\leq \tau\}<br />
Do you know how to prove the formula
<br /> \int\limits_0^{\infty} e^{-x}x^{s-1}dx = \int\limits_{\gamma_{\theta}} e^{-z}z^{s-1}dz<br />
jostpuur said:
Let's define for all -\frac{\pi}{2}&lt;\theta&lt;\frac{\pi}{2} a line
nope
By definition of an integral over a parameterized path the integral on right is the same as
<br /> \int\limits_{\gamma_{\theta}} e^{-z} z^{s-1} dz = \int\limits_0^{\infty} e^{-\tau e^{i\theta}} (\tau e^{i\theta})^{s-1} e^{i\theta} d\tau<br />
which is roughly the same thing you were asking about. For this reason it would be better to speak about modifying the integration path than performing "a complex change of variables". There is some theorem that states how the change of variable works, but the theorem assumes that the change of variable happens with real parameters, so if you try to apply "a complex change of variables", you are not obeying the assumptions of the theorem.
Next question is that do you know what Cauchy's integral formula and residue theorem are? If not, you'll have to study complex analysis to learn about those. The formula I asked about can be proven with Cauchy's integral formula (or residue theorem).
I studied something on the subject But I do not quite understand it, I know that a complex integral Can be "separated" in the cauchy main value and on the path that follows the integral, so the trick Was to show that the path of the integral is 0, so the principal value and the complex integral are the same, the reason why the change of variable is right is because something like that?
No, this is not related to principal value stuff. By Cauchy's integral formula and residue theorem I meant these:
https://en.wikipedia.org/wiki/Cauchy's_integral_formula
https://en.wikipedia.org/wiki/Residue_theorem
I see that mentioning the Cauchy's integral formula was slightly confusing because there is no pole in sight in your problem, but anyway, of course Cauchy's integral formula is related in the sense that the residue theorem is based on it. In your problem we are going to apply the residue theorem in the special case that no poles are present, the value of the integral over a closed loop is going to be zero.
Was there a special name for a result that the value of a complex integral is zero, if there are no poles enclosed? I don't remember it anymore, if there was.
The formula
<br /> z\mapsto e^{-z}e^{(s-1)\log(z)}<br />
defines a complex analytic function on the set \mathbb{C}\setminus\;]-\infty,0] when we use the branch of logarithm that is continuous elsewhere but not on the line ]-\infty,0].
For simplicity, now we'll assume 0&lt;\theta&lt;\frac{\pi}{2}. We'll define a loop that consist of three pieces by setting
<br /> \gamma^{\textrm{arc}}_{\theta,R} = \big\{Re^{i\varphi}\;\big|\; 0\leq \varphi\leq\theta\big\}<br />
and
<br /> \gamma^{\textrm{line}}_{\theta,R} = \big\{\tau e^{i\theta}\;\big|\; 0\leq \tau\leq R\big\}<br />
The residue theorem will imply that
<br /> \int\limits_{[0,R]\cup \gamma^{\textrm{arc}}_{\theta,R}\cup \gamma^{\textrm{line}}_{\theta,R}} e^{-z}z^{s-1}dz = 0<br />
because there are no poles enclosed by this loop. The integral is the same as
<br /> \int\limits_0^R e^{-x}x^{s-1}dx + \int\limits_0^{\theta} e^{-Re^{i\varphi}}(Re^{i\varphi})^{s-1} iRe^{i\varphi} d\varphi<br /> - \int\limits_0^R e^{-\tau e^{i\theta}} (\tau e^{i\theta})^{s-1} e^{i\theta} d\tau<br />
Then you'll have to figure out a way to prove that the integral over the arc part goes to zero in the limit R\to\infty.
Likes MAGNIBORO
thanks , even if i don't understand completely I know that the integral on a closed curve without poles is 0 so I got an idea of the general concept =D
  • · Replies 16 ·
