PeroK said:
Take, for example, the idealised electron single-slit experiment.
Before the slit, the electron has a state that resembles a classical particle, with low uncertainty in lateral momentum.
It is generally assumed to be in a plane wave state with with low uncertainty in momentum. This is very far from a classical particle.
PeroK said:
The interaction with the slit forces the state to evolve into a superposition of states with varying quantities of lateral momentum.
No. The filter containing the slit turns most of the plane wave into heat, with exception of the little part that passes through the slit.
PeroK said:
It has evolved (deterministically in the key criteria) into a state with considerable uncertainty in lateral momentum.
This part is generally modeled classically (like a wave in classical optics), hence the determinism. Probability is not conserved.
After the slit, the surviving wave is still treated classically, resulting in a spherical wave. At best, the spin degrees of freedom receive a quantum treatment.
PeroK said:
Finally, the electron interacts with the detector in a position that appears not to be predictable from the initial state. Despite the uncertainties in the initial state, they do not appear to be sufficient to predetermine the electron to impact at a specific lateral position on the detector.
This is because a spherical wave has no particle character.
PeroK said:
Nor does the configuration of the detector appear to determine which cell is illuminated.
It appears so to you, without any stringent argument. This is your most questionable assumption.
PeroK said:
The variable interaction with the detector appears to be determined, in standard QM fashion, by the intermediate evolution associated with the interaction with the single slit.
The spatial probability distribution is determined by the squared amplitude at each detector position.
PeroK said:
My point is simply that the interaction with the slit alone appears sufficient to produce different, probabilistic outcomes.
The slit only produces the spherical wave, nothing more, which defines a mathematical probability distribution, but no actual outcomes, hence no randomness - the spherical symmetry is preserved before meeting the detector.
But the outcomes are produced by the detector, according to this distribution. The observed emerging detection pattern is fully consistent with the assumption that each local neighborhood of the detector responds independently with a tiny probability proportionally to the tiny strength of the impacting wave at that neighborhood. Thus it is natural to assign the randomness to to the unknown details of each neighborhood.
PeroK said:
That is sufficient to class the experiment as non-deterministic.
But not sufficient to pinpoint the reason.
PeroK said:
It may be the case that the states of the source and detector determine the outcome, but it does not seem necessary to consider those. Nor the precise state of the intermediate slit.
So how do the mere probabilities create the outcomes?
PeroK said:
Especially, and I labour the point, since the probabilities appear to respect the intermediate evolution of the electron state.
Only after the slit and before the detector. There probabilities (or rather probability amplitudes) evolve deterministically.
PeroK said:
No additional mathematics is needed to calculate the required probabilities!
But without additional mathematics you don't get any outcomes, hence no randomness.
PeroK said:
I thought I was taking more an experimental view of establishing which components appear to influence the probabilities of the outcomes. In the single-slit it appears that the calculation associated with the intermediate interaction with the slit is sufficient to produce the probabilities that describe the outcome.
There is a difference between producing probabilities and producing outcomes - this is what
@Demystifier repeatedly pointed out. An outcome is an actual change in the detector, but a probability distribution is just an idea in our mind, and cannot cause such an outcome. While the interaction with the detector can and does!
PeroK said:
I acknowledge we can't have an experiment without a source and detector. But, we can calculate the relevant probabilities without reference to the precise state of either.
This is just shut-up-and-calculate, about which there was never any dispute. But calculations have no causal power, only interactions have!
