Question about Factoring Equation
  • Thread starter optics.tech
  • Tags
    Factoring
In summary, the conversation discusses methods for factoring quadratic and cubic equations. The use of the cubic formula, which is similar to the quadratic formula, is suggested for solving cubic equations. However, it is noted that there is no formula for polynomial equations of degree higher than 4. The conversation also touches on the significance of using complex numbers in solving these equations and the importance of these methods in the development of mathematics.
optics.tech
79
Hi,
I use the [tex]\frac{-b \ \pm \ \sqrt{b^2 - 4ac}}{2a}[/tex] formula to factoring the quadratic equation. Can anyone tell me how to factoring the cubic equation? Usually I use the division method to factoring higher order than quadratic equation such as cubic, etc., by trial, one-by-one.
Cheers http://img395.imageshack.us/img395/7776/cheers.gif
Mathematics news on Phys.org
Well, use the cubic formula, of course! Just as you can use the quadratic formula to solve any quadratic equation, so you can use the cubic formula to solve any cubic equation and then the factors are D(x- a)(x- b)(x- c) where a, b, c are to roots of the equation.
Look at http://en.wikipedia.org/wiki/Cubic_equation#Cardano.27s_method
Needless to say, it is considerably harder than the quadratic formula. There is also a formula for solving fourth order equations but it is even harder- in part it involves reducing to a cubic equation and using Cardano's formula. There is no formula for polynomial equations of degree higher than 4. It was proved in the nineteenth century that there exist such equations whose solutions cannot be written in terms of radicals.
The quoted pages may look a bit formidable to you.
The way I remember it and could always construct a solution if needed is: just as you solve a quadratic by "completing the square" - i.e. by expressing it as the difference of two squares, then the solution of that difference = 0 is one square equals the other... you know the rest, so you try to express the cubic as difference of two cubes. You find that in order to do that you are led to have to solve a quadratic equation.
You find that if the cubic equation has 3 real roots you will need to use the nonreal complex roots of that quadratic to get them. They could find no way not to use these, so that led to the discovery that square roots of negative numbers are not just a silly answer to a silly question but something serious, useful and it turned out, inevitable. I.e. it was hoped to find some way to solve using just real numbers but it was proved this would be impossible. I don't know how elementary and accessible that last bit is and am curious.
Anyway the point is that what looks like a specialised problem, solving the cubic, turns out to lead to one of the most important things in mathematics, also surely one of the key steps in the process of abstraction in maths. The ideas and calculation for solving the cubic and quartic are really less difficult and more natural than the formidable-looking formulae would lead you to think.
1. What is factoring?
Factoring is a mathematical process of breaking down a larger expression into smaller expressions that can be multiplied together to get the original expression. It is commonly used in algebra to solve equations.
2. Why is factoring important?
Factoring is important because it allows us to simplify complex equations, find solutions to equations, and identify patterns in mathematical expressions. It is also a fundamental skill for solving higher-level mathematical problems.
3. How do you factor an equation?
The first step in factoring an equation is to identify the greatest common factor (GCF) of all the terms. Then, use algebraic techniques such as grouping, difference of squares, or trinomial factoring to further break down the expression into smaller terms. Finally, check the factored expression by multiplying the terms back together to ensure it is equivalent to the original expression.
4. What is the difference between factoring and solving an equation?
Factoring is a process of breaking down an expression, while solving an equation involves finding the value of the variable that makes the equation true. Factoring is often used as a step in solving equations, as it can simplify the equation and make it easier to find the solution.
5. Can you factor any equation?
Not all equations can be factored. For example, equations with irrational or imaginary solutions cannot be factored. Additionally, certain equations may not be easily factored using traditional methods and may require more advanced techniques. However, many equations encountered in algebra can be factored using basic factoring techniques.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
