Question about noether's theorem argument
4 replies · 3K views
painfive
Given a lagrangian [itex]L[\phi][/itex], where [itex]\phi[/itex] is a generic label for all the fields of the system, a transformation [itex]\phi(x) \rightarrow \phi(x) + \epsilon \delta \phi(x)[/itex] that leaves the lagrangian invariant corresponds to a conserved current by the following argument.
If we were to send [itex]\phi(x) \rightarrow \phi(x) + \epsilon(x) \delta \phi(x)[/itex], this would not in general be a symmetry, but would be in the special case that [itex]\epsilon[/itex] is constant. Therefore*, the change in the lagrangian must be proportional to the derivative of [itex]\epsilon(x)[/itex], that is:
[tex]\delta L = j^\mu (x) \partial_\mu \epsilon(x)[/tex]
Now when the equations of motion are satisfied, all infinitessimal variations, symmetries or not, leave the action unchanges, so in this case we must have:
[itex]0 = \delta S = \int d^4x j^\mu (x) \partial_\mu \epsilon(x)[/itex]
or, integrating by parts:
[itex]0 = \int d^4x \epsilon(x) \partial_\mu j^\mu (x)[/itex]
Since [itex]\epsilon(x)[/itex] is arbitrary, this implies [itex]\partial_\mu j^\mu(x) = 0[/itex].
My problem is with the part marked by a *. Just because something vanishes when [itex]\epsilon[/itex] is constant, why should we expect the thing to be proportional to the dderivative of [itex]\epsilon(x)[/itex]? I could imagine other dependences. For example, the following things all vanish when [itex]\epsilon(x)[/itex] is constant:
[tex](j^\mu \partial_\mu \epsilon(x) )^2[/tex]
[tex]\partial^2 \epsilon(x)[/tex]
[tex]\epsilon(x+1) - \epsilon(x)[/tex]
I could go on. Granted, you could eliminate these examples individually, eg, the variation should be linear and local in [itex]\epsilon(x)[/itex], and by integrating by parts we can turn the middle one into the desired form. But there are other examples, and I'm wondering how we can argue for the form [itex]\partial_\mu \epsilon[/itex] directly rather than eliminating these other possibilities one by one.
Try expanding L as a Taylor series in [itex](\epsilon \delta \phi)[/itex]. Then because [itex]\delta \phi[/itex] is by definition infinitesimal, the higher-order terms vanish.
Now, because you are looking at the change in L under infinitesimal variations, the zeroth-order term also vanishes. What you should be left with is the first-order term.
So the taylor expansion would have to be a sum over all terms of the form:
[tex]\Pi_{i, m_i, n_i} ({\partial_i}^{m_i} \epsilon(x) )^{n_i}[/tex]
where the product is over some subset of the values i, m_i, and n_i could take, and the sum would be over all such subsets. This is a pretty extreme generalization of taylors theorem. If it is true, then I guess we could argue we can ignore terms except those of the form:
[tex]{\partial_i}^{m_i} \epsilon (x)[/tex]
and then integrate by parts. This might be what they mean, but if so, it isn't very satisfying or intuitive, and they really skipped over a lot of details.
I'm actually the OP, I illegally had two user names, painfive is now gone. But I'd still like someone to tell me if this taylor's theorem argument is the way to go.
I hate to see the beautiful theory made ugly by some textbooks! And I also hate the method that I will describe below!
Let us consider the infinitesimal transformation
[tex]\phi \rightarrow \phi + \delta \phi ,[/tex]
[tex]\delta \phi = F( \phi ) \epsilon (x) , \ \ | \epsilon | \ll 1[/tex]
Infinitesimal means that
[tex]\epsilon^{n} \approx 0, \ \forall n > 1[/tex]
This transformation induces an infinitesimal change in the Lagrangian according to
[tex]\delta \mathcal{L} = \frac{\partial \mathcal{L}}{\partial \phi} F( \phi ) \epsilon + \frac{\partial \mathcal{L}}{\partial \partial_{a} \phi} \epsilon \partial_{a} F + \frac{\partial \mathcal{L}}{\partial \partial_{a} \phi} F \partial_{a} \epsilon[/tex]
Now, we define the objects
[tex]J^{a} \equiv \frac{\partial \mathcal{L}}{\partial \partial_{a} \phi} \ F( \phi )[/tex]
and
[tex]E( \phi ) = \frac{\partial \mathcal{L}}{\partial \phi} - \partial_{a} \left( \frac{\partial \mathcal{L}}{\partial \partial_{a} \phi } \right)[/tex]
and rewrite the change in the Lagrangian as
[tex]\delta \mathcal{L} = \left( E( \phi ) F + \partial_{a} J^{a} \right) \epsilon + J^{a} \partial_{a} \epsilon[/tex]
Notice that the first term represents the infinitesimal change in [itex]\mathcal{L}[/itex] for constant [itex]\epsilon[/itex]. So, we can write
[tex]\delta \mathcal{L} = \delta \mathcal{L}|_{\epsilon = \mbox{const.}} + J^{a} \partial_{a}\epsilon[/tex]
Now, if for CONSTANT [itex]\epsilon[/itex], the transformation above is a symmetry, i.e., if the (Noether) identity
[tex]\delta \mathcal{L}|_{\epsilon = \mbox{conct.}} = E( \phi ) F( \phi ) + \partial_{a}J^{a} = 0[/tex]
is satisfied, then the change in the lagrangian will be given by
[tex]\delta \mathcal{L} = J^{a}\partial_{a}\epsilon[/tex]
where [itex]J^{a}[/itex] now is the conserved current of the corresponding GLOBAL symmetry; notice that the Noether identity above implies [itex]\partial_{a}J^{a} = 0[/itex] ON-SHELL, i.e., when the field satisfies the equation of motion [itex]E( \phi ) = 0[/itex].
Regards
sam
