Question about Pearson-Anson Relaxation Circuit
  • Thread starter Thread starter Infernorage
    Circuit
The Pearson-Anson relaxation circuit is designed to blink neon lamps by utilizing a capacitor that charges until it reaches a voltage threshold, causing the lamp to ionize and conduct. The lamp behaves as a short circuit once it fires, discharging the capacitor until the voltage drops below a second threshold, at which point the lamp turns off and the capacitor begins to recharge. The battery does not keep the lamp lit because the lamp requires a specific voltage to conduct, and the resistor in the circuit limits the current, preventing the battery from maintaining the lamp's voltage. This circuit typically operates at high voltages, around 60 volts, and requires careful selection of resistor values to ensure proper operation.
  • Understanding of RC (Resistor-Capacitor) circuits
  • Knowledge of neon lamp operation and threshold voltages
  • Familiarity with voltage and current behavior in parallel circuits
  • Basic electronics concepts, including charging and discharging of capacitors
  • Study the operation of RC circuits in detail, focusing on transient behavior
  • Research the characteristics and applications of neon lamps in electronic circuits
  • Learn about the use of Schmidt trigger ICs for low-voltage oscillators
  • Experiment with 555 timer IC circuits to create similar blinking effects at safer voltages
Electronics enthusiasts, hobbyists, and students interested in understanding relaxation oscillators, as well as engineers designing circuits involving neon lamps and capacitors.
Infernorage
As seen in the circuit diagram picture below, the Pearson-Anson relaxation circuit is often used to blink neon lamps. According to what I have read, the lamp does not permit a current until the capacitor reaches the voltage threshold, causing the gases in the lamp to ionize and a sudden current. Once the capacitor discharges enough, the voltage falls below the lower threshold, the current drops to zero, and the power source begins charging the capacitor again to repeat the process.
My question is, why doesn't the battery just turn on the lamp and keep it lit while charging the capacitor. The voltage of the capacitor will never exceed the battery so the battery must have enough voltage to turn the lamp on. Also, since the lamp is in parallel, isn't the voltage difference across the lamp the same as that of the capacitor? I don't see why the battery wouldn't just light the lamp right away. Can anyone clarify this for me? Thanks in advance.
Because, once the voltage across the neon lamp increases beyond its threshold voltage and begins to conduct, the lamp acts like a short circuit which discharges the capacitor. Re-analyze the circuit treating the neon bulb as a short circuit when the lamp is on.
I understand why the capacitor discharges, but I suppose my problem is with what happens before the voltage threshold. The lamp is parallel to the capacitor, so I figured the voltage difference of the power source would also be across the lamp, but that would immediately light it. Why isn't the batteries voltage difference initially applied to the neon lamp?
Infernorage, It seems you’ve copied the schematic drawing from the wiki page http://en.wikipedia.org/wiki/Pearson–Anson_effect
If you have not done so yet, may I suggest you read the two paragraphs just below the diagram labeled “Charging” and “Discharging” where the operation of the circuit is discussed with elegant clarity.
If then you have some doubts or questions about the operation, please return here and post them. Members here are always willing to assist any true searcher for understanding of the mysteries of our natural world.
Cheers,
Bobbywhy
The lamp is basically an open circuit below its threshold, so that part of your problem is reduced to understanding the transient behavior of a simple RC circuit. You wouldn't expect a capacitor that is charged with a current limited (as in the resistor) voltage source to instantly reach the supply voltage, would you?
The lamp also has two thresholds.
Before it fires, it draws no current and produces no light.
Once it fires, (that is, when the voltage across it reaches the first threshold), it draws current and produces light as it gets current mostly from the capacitor and some from the resistor.
It then reaches the second threshold when the voltage across the lamp is not enough to maintain conduction. So the lamp switches off and the capacitor starts to charge up via the resistor.
These devices usually operate at a relatively high voltage of about 60 volts and this circuit produces a crude but large sawtooth waveform across the capacitor.
The value of the resistor is important for this to work. If R is too small, there will be a delay while C charges up to the threshold voltage, and then the lamp will be permanently on, as the OP suggested.
R needs to be big enough so the battery can't maintain the lamp voltage on its own, because of the voltage dropped across R.
C acts like a "second battery" to keep the lamp voltage high, but the voltage falls as C discharges, until the lamp goes off and the battery can then recharge C to repeat the process.
Incidentally, you can make a low voltage version of this using an Schmidt trigger IC instead of the neon lamp, and you can make a similar oscillator with the common "555" IC. Experimenting at 5V is much safer than messing around with 60V or 90V neon lamps!
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 28 ·
14K
