Question about plasma modeling
  • Context: Undergrad
  • Thread starter Thread starter mody mody
    Modeling Plasma
The discussion revolves around the different methods for modeling plasma physics, specifically focusing on the distinctions between single particle, kinetic, and fluid models. Participants explore the complexities and simplifications inherent in these approaches, as well as their applicability in various contexts.
  • Some participants note that while the single particle model is conceptually simple, predicting the behavior of a large number of particles is extremely challenging.
  • It is suggested that the fluid model is mathematically more tractable than the particle model due to its high-level approach.
  • Participants discuss whether both kinetic and fluid models can be considered statistical approaches, with some expressing confusion about the differences between them.
  • One participant explains that kinetic models provide more complete information about particle distribution functions, while fluid models only capture statistical moments of these distributions.
  • There is a discussion about the implications of using fluid models, particularly regarding the assumption that all particles in a fluid move with the same average velocity, with some nuances regarding temperature effects being mentioned.
Participants generally agree on the basic distinctions between the models but express uncertainty about the implications of these differences and the conditions under which each model is applicable. The discussion remains unresolved regarding the finer points of how these models relate to one another.
Some limitations in the discussion include the dependence on definitions of terms like "fluid" and "kinetic," as well as the unresolved nature of how well fluid models can represent systems with non-Gaussian velocity distributions.
mody mody
hi ,, hello dears
first i hope i choose the suitable section to put my question
i want in fact to distinguish between different methods to model or study or describe plasma physics .. from my read i found that there are various ways to study plasma physics one way is the single particle description which held by following the trajectory of each particle but this is very complicated method due to large number of particles ,, other models is the kinetic model and fluid model in fact here my confusion appeared i can't distinguish between them what is the major difference between them and why the fluid model is more simpler .. i hope my question is specific and clear :)
I think the part you might be confused about is, while the particle model is *conceptually* simple since each particle is rather simple, it's the ability to make predictions that is super-hard. How do you calculate the behavior of 1023 particles?
The fluid model takes a high-level approach, thus being mathematically much more tractable.
mm i understood the difficulty at dealing with such high number of particles
could i say that both kinetic and fluid model are both statistical approaches or what in fact the difference between both of them
I think you have the right idea. Kinetic and fluid models are a sort of coarse-grained model. Both of them treat the plasma as a continuous medium, when in fact it is made up of a large number of particles. This allows us to ask questions like, what is the density of the plasma at a point (x,y,z). The plasma parameters are averaged over a small volume around the point. The number of particles is generally so large that we aren't too concerned about each individual one.
The difference between kinetic and fluid models is that a kinetic model is more complete and contains information about the full distribution functions of the particles involved, while fluid models only contains information about the (statistical) moments of the distribution functions. A distribution function tells you how many particles have a particular velocity near a point in space. The zeroth, first, and second moments of this distribution function give you the total number of particles near this point in space (the density), the average velocity, and the temperature.
So, with a fluid model, we can say the fluid is moving with velocity (vx, vy, vz) at point (x, y, z). But that doesn't mean every particle is moving at velocity (vx, vy, vz). If the particles have a Gaussian distribution of velocities (MB distribution of speeds), then a fluid model will probably work fine, since the entire distribution function can be described by just the amplitude, center, and width of the Gaussian, which correspond to the density, velocity, and temperature of the fluid. But if the distribution function has a weird shape which can't be described by a few moments, then the fluid model will be inadequate.
so happy that finally one put his hand on my confusion :))
at first i apologize as i am a beginner at his topic so my question may appear trivial
you said ' with a fluid model, we can say the fluid is moving with velocity (vx, vy, vz) at point (x, y, z). But that doesn't mean every particle is moving at velocity (vx, vy, vz)' your sentence agree with what i read at books but from my ideas isn't fluid treated a whole as if it has only one average velocity ?? to be more clear if i treat the fluid such water then all species of the following water will move together with average velocity ??
For the most part, yes, but some models will include some effects of finite temperature.
13K
