Is Coefficient Pairing in Polynomials Justifiable Through Equality Definition?
  • Context: Undergrad
  • Thread starter Thread starter aikismos
    Polynomial Terminology
The discussion centers on the justification of coefficient pairing in polynomials through the definition of polynomial equality. Participants confirm that when two polynomial expressions are equal, their corresponding coefficients must also be equal, as demonstrated with the example of the equation 3x² + bx = ax² + 5x, leading to a = 3 and b = 5. Additionally, the expression P(x) = ax² + bx can be used to indicate that P(x) has no constant term by stating P(0) = 0. The rigorous justification involves recognizing that polynomial equality implies the independence of the coefficients.
  • Understanding of polynomial equality and its implications
  • Familiarity with partial fraction decomposition techniques
  • Knowledge of vector representation in polynomial contexts
  • Basic principles of calculus, specifically the concept of independence of functions
  • Study the concept of polynomial equality in depth
  • Learn about partial fraction decomposition in algebra
  • Explore the Wronskian and its application in determining function independence
  • Investigate the implications of coefficient comparison in higher-degree polynomials
Mathematicians, algebra students, and educators seeking to deepen their understanding of polynomial functions and their properties, particularly in the context of equality and coefficient analysis.
aikismos
Just to double check, but if one wanted to, like in partial fraction decomposition, associate literal coefficients of polynomials with corresponding unknowns on the other side of the equation, the justification for this action is the definition of equality of polynomials?
EDIT: I know this isn't true. Let's see, ## a - b = 2 ## is as far as it can be reduced.
## 3x^2 + bx = ax^2 + 5x \rightarrow a = 3, b = 5 ##
Another related question is how do I express symbolically that in:
## P(x) = ax^2 + bx ##
P(x) has no constant term?
I'm kinda groping around for a rigorous way to express and justify the pairing of coefficients if you were to write them as two equivalent n-tuples.
I would put everything on the same side and group similar powers of ##x## like this: ##(3-a)x^2+(b-5)x = 0 ##. Since this is true for all ## x ##, and since ## x ## and ## x^2 ## are independent functions (their Wronskian does not vanish), their coefficients must separately each be zero. This is a lot like having, for arrow vectors in the plane, that ## (3-a)\mathbf{i}+(b-5)\mathbf{j} = 0 ##. The only way to add a vector in the ## \mathbf{i} ## direction to one in the ## \mathbf{j}## direction and get zero is if, in fact, both vectors are the zero vector.
For the second question, how about writing it as ## P(0) = 0 ##?
In partial fractions decomposition, you're setting up an equation that is true for all values of the independent variable (except those that make any denominator zero). IOW, two expressions that are identically equal.
So, for ## 3x^2 + bx = ax^2 + 5x##, for all x, it must be the case that a = 3 and b = 5.
Thanks guys!
  • · Replies 18 ·
