Question about the Magnetic Flux equation in Integral form
In summary, @TSny implies that the ##\cos\theta## term is hidden inside the dot product of the vectors. However, it is not a constant term like it is in the case of a uniform magnetic field and a plane surface, it varies as we move from point to point on the surface, which makes the integration difficult.
Einstein44
125
31
I was a bit confused with all the formulas for Flux, so here's my question...
I know that for a uniform B field flux is defined as ##\phi =BAcos\Theta ##, however when looking at the integral form I never saw it written with ##cos\Theta##... Is there a reason? Could it still be written with a cos at the end??
Can you give us the explicit expression for the integral form? Does the integrand have a dot product of vectors?
Likes vanhees71 and Delta2
Yes, @TSny implies that the ##\cos\theta## term is hidden inside the dot product of the vectors. But is not a constant term like it is in the case of a uniform magnetic field and a plane surface, it varies as we move from point to point on the surface, which is what makes the integration difficult.
Yes, it is ##\phi =\iint_{S}B\cdot dS##
So you are saying that it is implied due to the dot product, but just not shown in the equation. I am not sure I fully understand what is going on, but I get what you are saying.
Yes well you wrote correctly the formula at post #4, but the whole point there is that ##B\cdot dS## is a very cute and compact formalism that hides a mini can of worms underneath: If you want to exactly write its equal expression using cosine of angle its a kind of trouble.
Likes Einstein44
Yes. Note that for a uniform B field, you can write the flux in terms of a dot product as ##\Phi = B S \cos \theta = \vec B \cdot \vec S## where in the last expression the ##\cos \theta## is "hidden" in the dot product. You just want to make sure that you understand the meaning of an area vector.
Likes Einstein44
Got it, thanks!
Likes berkeman
Related to Question about the Magnetic Flux equation in Integral form
1. What is the magnetic flux equation in integral form?
The magnetic flux equation in integral form is given by: Φ = ∫S B ⋅ dA, where Φ is the magnetic flux, B is the magnetic field, and dA is the differential area vector.
2. How is the magnetic flux equation derived?
The magnetic flux equation is derived from Faraday's law of induction, which states that the induced electromotive force (EMF) in a closed loop is equal to the negative rate of change of magnetic flux through the loop. By integrating this equation over a surface, we get the magnetic flux equation in integral form.
3. What is the significance of the magnetic flux equation?
The magnetic flux equation is important in understanding the relationship between magnetic fields and induced EMF. It is also used in calculations for magnetic circuits and in the study of electromagnetic waves.
4. How does the magnetic flux equation relate to Gauss's law?
The magnetic flux equation is analogous to Gauss's law in electrostatics, where the electric flux is given by ΦE = ∫S E ⋅ dA. Both equations represent the total amount of the respective field passing through a surface.
5. Can the magnetic flux equation be used to calculate the magnetic field?
Yes, the magnetic flux equation can be rearranged to solve for the magnetic field B. However, it is not always the most efficient method for calculating the magnetic field and other equations, such as Ampere's law, may be more appropriate in certain situations.
