Question about Tong's cosmology lecture notes eqn. 1.19
The discussion revolves around an equation from David Tong's cosmology lecture notes, specifically equation 1.19, which pertains to the derivation of cosmological redshift. Participants are examining the mathematical reasoning behind the equation, particularly focusing on an integral identity and its implications in the context of cosmological signals.
  • One participant questions the derivation of the right-hand side of equation 1.19, seeking clarity on the integral identity used by Tong.
  • Another participant suggests that the lack of mathematical rigor in Tong's explanation may stem from the assumption that the time intervals between signals are small.
  • Some participants propose that the mean value theorem is relevant to understanding the derivation, emphasizing the assumption that the time intervals approach zero.
  • There is a discussion about the implications of larger time intervals between signals, with one participant noting that the redshift result should still hold even if the intervals are significantly larger.
  • Another participant mentions that using the expansion history becomes necessary when the small delay approximation is no longer valid.
  • One participant expresses a preference for a treatment of the problem in terms of 4-frequency and invariants, while another references existing literature that may cover this approach.
Participants express differing views on the clarity and rigor of Tong's derivation, with some agreeing on the need for a more explicit explanation while others defend the method presented. The discussion remains unresolved regarding the implications of larger time intervals on the derivation.
Participants note the dependence on assumptions regarding the size of time intervals and the applicability of the mean value theorem, as well as the potential need for a more comprehensive understanding of the expansion history in cosmology.
haushofer
Insights Author
TL;DR
Question about Tong's cosmology lecture notes eqn. 1.19 (integral identity used?).
Dear all,
I have a rather basic question about an equation in David Tong's lecture notes on cosmology; see
http://www.damtp.cam.ac.uk/user/tong/cosmo.html
My question is about eqn. 1.19 (page 14), in which the cosmological redshift is derived. It's not about the physics, but about some basic integral identity I apparently don't see: how does he arrive at the conclusion after the arrow in that eqn. 1.19? To reproduce that eqn.,
$$\int_{t_1 + \delta t_1}^{t_0 + \delta t_0} \frac{dt}{a(t)} - \int_{t_1}^{t_0} \frac{dt}{a(t)} = 0 \rightarrow \frac{\delta t_1}{a(t_1)} = \frac{\delta t_0}{a(t_0)} \ \ \ \ (1.19) $$
I do understand that we can write the LHS as
$$\int_{t_0}^{t_0 + \delta t_0} \frac{dt}{a(t)} - \int_{t_1}^{t_1 + \delta t_1} \frac{dt}{a(t)} = 0$$
and I've drawn the integral equation geometrically, but I don't see how Tong arrives at the RHS of eqn. 1.19. Is there some mean value theorem involved? Differentiating the equation also leads me nowhere. I feel a bit silly. Thanks!
Space news on Phys.org
I don't get it either. I think it is not mathematically clear/rigorous. Probably he means that the time interval between successive signals is small therefore the integral is equal to the value of the function times the length of the interval. Something like ##\int_a^{a+\varepsilon} f(x) dx = f(a)\varepsilon##.
It is the mean value theorem along with the assumption that ##\delta t_i \to 0##. Tong could have been more explicit here.
While perfectly fine, I prefer a treatment in terms of 4-frequency and using invariants.
Thanks! But why ##\delta t_i \to 0##? This result of redshift also holds if we increase the time between two signals, right? What happens if the second light signal is send out/absorbed billions of years later such that ##\delta t_i = \mathcal{O}(10^9 \ yr)##?
Then you will need the expansion history because you can no longer use the small delay approximation. Redshift is something that by construction deals with the rate of phase increase.
Ok, thanks, I'll have another look and compare it with the usual derivation involving invariants.
I’d say the method presented by Tong is by far the most common one. I’m actually not sure what sources contain the argument based on parallel transport of the 4-frequency, but it should be covered in this Insight I wrote several years back: https://www.physicsforums.com/insights/coordinate-dependent-statements-expanding-universe/
  • · Replies 19 ·
