Question for strcpy and pointer
  • Thread starter Thread starter Linda8888
The discussion centers on modifying the declaration of the pointer s1 to ensure that the strcpy function successfully copies the string from s2 to s1. The solution involves allocating stack memory for s1 using an array declaration, such as char s1[100];, which provides sufficient space for the string. This approach prevents memory wastage while ensuring that s1 points to a valid memory location on the stack.
  • Understanding of C programming language syntax
  • Knowledge of string handling functions in C, specifically strcpy
  • Familiarity with stack memory allocation in C
  • Basic concepts of pointers and arrays in C
  • Research stack memory allocation techniques in C
  • Learn about safe string handling functions to avoid buffer overflows
  • Explore the differences between pointers and arrays in C
  • Study the implications of using dynamic memory allocation with malloc and free
C programmers, software developers, and students learning about memory management and string manipulation in C.
Linda8888
Summary:: Question: In the blank space below, write a new version of the first line of this code segment such that the strcpy succeeds. Use only stack memory and try not to waste memory.
how can I change the first line of the code?
Code:
char *s1;       // change this line
char *s2 = "good luck";
strcpy(s1, s2); // I must succeed
  • · Replies 21 ·
  • · Replies 24 ·
