Question of "min" function from Spivak
The discussion revolves around the use of the "min" function in a proof involving the inequality |x - a||x + a| < ε, as presented in Michael Spivak's work. Participants explore the implications of bounding |x - a| and |x + a| under certain conditions, particularly focusing on the necessity of proving |x + a| < min(1, ε/(2|a| + 1)). The conversation includes technical reasoning, assumptions, and clarifications related to limits and continuity in mathematical proofs.
  • Some participants question the necessity of the assumption |x - a| < 1 and seek clarification on its role in the proof.
  • Others argue that the use of the "min" function is essential to ensure both |x - a| and |x + a| remain within bounds that satisfy the inequality |x - a||x + a| < ε.
  • A participant suggests that if |x - a| is bounded by the minimum of 1 and ε/(2|a| + 1), it allows for a more robust proof structure.
  • Some express confusion about the meaning of the "min" function and its implications for the proof.
  • There are discussions about the implications of choosing 1 as a boundary and whether other values could serve the same purpose.
  • Participants highlight that the proof's goal is to show how close x needs to be to a for the inequality to hold, emphasizing the importance of making assumptions in mathematical reasoning.
  • Concerns are raised about the treatment of values of |x - a| that exceed 1, with some asserting that the proof focuses on values close to a.
Participants do not reach a consensus on the necessity of the assumption |x - a| < 1 or the implications of using the "min" function. Multiple competing views remain regarding the assumptions made in the proof and their relevance to the overall argument.
Some participants note that the proof's validity depends on the assumptions made about the values of |x - a| and that these assumptions may not hold for all real numbers. The discussion reflects a range of interpretations regarding the conditions under which the proof operates.
Amad27
Hi,
Suppose you want to prove [itex]|x - a||x + a| < \epsilon[/itex]
You know
[itex]|x - a| < (2|a| + 1)[/itex]
You need to prove
[itex]|x + a| < \frac{\epsilon}{2|a| + 1}[/itex]
So that
Why does Michael Spivak do this:
He says you have to prove --> [itex]|x + a| < min(1, \frac{\epsilon}{2|a| + 1})[/itex] in order to finally prove, [itex]|x + a||x - a| < \epsilon[/itex]
Why do we need the "min" function there?
Amad27 - The closing itex tag starts with /, not \. I fixed them all for you. - Mark44
Thanks!
If we assume [itex]|x - a| < 1[/itex] then [itex]a - 1 < x < a + 1[/itex] so that [itex]2a - 1 < x + a < 2a + 1 \leq 2|a| + 1[/itex]. That in turn means that [tex] |x - a||x + a| < |x - a|(2|a| + 1)[/tex] and we can ensure [itex]|x - a||x + a| < \epsilon[/itex] by requiring that [tex] |x - a|(2|a| + 1) < \epsilon,[/tex] so that [tex] |x - a| < \frac{\epsilon}{2|a| + 1}.[/tex] However the preceding argument assumed that [itex]|x - a| < 1[/itex], so [itex]|x - a|[/itex] must satisfy that constraint as well. Hence we must have [tex] |x - a| < \min\left\{1, \frac{\epsilon}{2|a| + 1}\right\}.[/tex]
pasmith said:
If we assume |xa|<1|x - a| < 1 then a−1<x<a+1a - 1 < x < a + 1 so that 2a−1<x+a<2a+1≤2|a|+12a - 1 < x + a < 2a + 1 \leq 2|a| + 1. That in turn means that
Hello @pasmith, I don't understand;
On WHAT basis and WHY are you assuming [itex]|x - a| < 1[/itex]??
Amad, be careful when you quote someone. @pasmith did not write "|xa|<1|x - a| < 1" - what he wrote was "If we assume |x−a| < 1 then ..."
He made this assumption, and if it turns out that this assumption is incorrect, all that is accounted for in the last line of his post where he says that |s - a| will be less than the minimum of 1 and the expression involving ##\epsilon##.
Mark44 said:
He made this assumption, and if it turns out that this assumption is incorrect, all that is accounted for in the last line of his post where he says that |s - a| will be less than the minimum of 1 and the expression involving ϵ\epsilon.
Hi,
What does [itex]min(1, \frac{\epsilon}{2|a| + 1|})[/itex]
Actually mean? I don't understand this "min" idea??
Amad27 said:
Hi,
It's very simple - it means the minimum, or smaller, of the two values.
@Mark44, why can't we directly prove:
[itex]|x - a| < \frac{\epsilon}{2|a| + 1|}[/itex]
Why is that 1 required.
Why does it matter if |x - a| < min of something?
Thanks!
Thanks!
The goal is to prove that |x - a||x + a| < ##\epsilon##
You need to get bounds on the value of |x + a|. He could just as easily assumed that |x - a| < 1/2 or |x - a| < 3 or whatever.
Oh,
So its we know that
[itex]\frac{\epsilon}{2|a| + 1} < 1[/itex]?
If [itex]\frac{\epsilon}{2|a| + 1} < 1[/itex] is minimum of course.
Amad27 said:
Oh,
So its we know that
It all depends on the value of ##\epsilon##. For some values ##\frac{\epsilon}{2|a| + 1}## will be smaller than 1, but for suitably large values of ##\epsilon##, 1 will be larger.
Mark44 said:
It all depends on the value of ϵ\epsilon. For some values ϵ2|a|+1\frac{\epsilon}{2|a| + 1} will be smaller than 1, but for suitably large values of ϵ\epsilon, 1 will be larger.
Right, since it depends for every [itex]\epsilon[/itex]
But why would he randomly choose one (1) as a part of the minimum function? Why not two(2) or three(3)?
So, if 1 is the minimum then how does it prove
[itex]|x-a||x+a| < \epsilon[/itex]?
The "[itex]\delta[/itex]" was derived under the assumption that |a- 1|< 1 (so that -1< a- 1< 1 and then 1< a+ 1< 3). In order for the proof to work, both [tex]|a- 1|< \delta[/tex] and [tex]|a- 1|< 1[/tex] must be true. That will be the case if it is less than the smaller of the two.
HallsofIvy said:
"δ\delta" was derived under the assumption that |a- 1|< 1 (so that -1< a- 1< 1 and then 1< a+ 1< 3). In order for the proof to work, both
|a−1|<δ​
|a- 1|< \delta and
|a−1|<1​
|a- 1|< 1 must be true. That will be the case if it is less than the smaller of the two.
But it has work for all real numbers,
Not just |x-a| < 1 what about |x-a| > 1 ?
We don't care about that. You're missing the big picture here. The goal is to see how close x needs to be to a so that |x2 - a2| < ##\epsilon##.
We don't care about any x values that are relatively distant from a.
Mark44 said:
We don't care about that. You're missing the big picture here. The goal is to see how close x needs to be to a so that |x2 - a2| < ϵ\epsilon.
I really don't understand this concept.
The definition says you have to prove there is some [itex]\delta[/itex] such that [itex]|x - a| < \delta[/itex] not that [itex]|x - a| < \delta < 1[/itex]
Also, there is no proper definition of "relatively distant." Relatively close could mean 10000000000000. Why are you making assumptions anyway?
Because if you don't make assumptions, you'll never get anywhere.
I don't believe so; The goal I think is to bound the number [itex]|x - a|[/itex] so that it doesn't go overboard. Because when looking at limits you generally look at values close to x = a.
And that right there, that's the assumption. We assume that x is close to a - namely, that |x - a| < 1. We can safely assume this, so we do, and the rest of the proof follows from such.
We don't care about [itex]|x - a | \geq 1[/itex].
To conclude that [itex]x^2 - a^2[/itex] is continuous at [itex]a[/itex] you need to prove:
Statement 1
For all [itex]\epsilon > 0[/itex] there exists a [itex]\delta > 0[/itex] such that for all [itex]x[/itex], if [itex]|x - a| < \delta[/itex] then [itex]|x^2 - a^2| < \epsilon[/itex].
What Spivak invites you to prove is a stronger statement:
Statement 2
For all [itex]\epsilon > 0[/itex] there exists a [itex]\delta > 0[/itex] such that [itex]\delta < 1[/itex] and for all [itex]x[/itex], if [itex]|x - a| < \delta[/itex] then [itex]|x^2 - a^2| < \epsilon[/itex].
Note that Statement 2 implies Statement 1. Of course one could substitute any [itex]R > 0[/itex] for '1' in Statement 2 and the result would still imply Statement 1, but 1 is the most natural choice.
Really? In what context could 10 trillion be considered relatively close?
Saying that "relatively close" could mean 10 trillion comes off in my mind as trolling. Since the question has been asked and answered, I am closing this thread.
  • · Replies 35 ·
9K
