Question on Experiments with Entangled Particles and Quantum Mechanics
  • Context: Graduate
  • Thread starter Thread starter cybercrypt13
    Experiment
28 replies · 6K views
cybercrypt13
I've been trying to study up on the experiments where people have taken entangled particles and done measurements that suggest that they are able to communicate faster than the speed of light.
The couple experiments I've read up on seem to have a device that pairs the particles and then fires them outward towards two detectors. Quantum Mechanics suggests that both particles exist in all states until they are measured, so the thought goes that both particles are in all possible states and the measure of one of them causes the other to snap to attention and measure the same or opposite value.
All books and examples I've read provide a really neat example of having two boxes that are separated by miles and one person opens the box takes a measure, then the other person and they determine that they are the same. They use this to state absolutely that 100% of the time this happens just as suggested by QM.
After reading a bit, I am seeing signs that the experiment is only capable of firing the particles and taking a single measurement as they pass through a magnetic detector to note whether the spin is up or down. This device can't give exact measurements so I'd think if one particle were at a 15% or even a 45% different spin, the detector would not know this.
I also assume that the particles can only be measured once and in a single orientation. I get this idea from the way the experiment is described so please correct me if I'm wrong on any of these points. If this is true, the multitude of people describing this experiment as a box that you can open and check over and over are doing an extreme dis-justice to the experimental results.
I've also read of a recent experiment where someone shot the particles between islands and measured them. This would appear very interested as I'm not sure how they'd know anything at all of the particles after they'd been hit by light, air, birds, and everything else in between. Yet this experiment was also tauted as further proof of QM.
Then I've read the fact that these experiments are very finicky and require extreme care be taken to make sure nothing touches the particles until they've been measured, otherwise they become unpaired and the results can't be depended on.
So, assuming all of what I've read is true, here is my question:
How can anyone state the facts as they've stated them supporting QM with this experiment if you can only measure the particles once? I would suggest that when the particles are paired they have opposite spins which would support the test results. I'd also say that anything you do to touch the particles would break this and therefore you'd no longer see the results you are thinking you see.
A better experiment might work as follows: Shoot two paired particles (Pa and Pb) apart. At point A we measure Pa only and note its spin. Then at point B along the path of the particle Pb we measure its spin only.
Then at the end of both, we measure Pa and note Pb. In my opinion only this result would prove what is being claimed if:
1) Pa had spin X at point A.
2) Pb had spin Y at B.
3) Both particles had yet another spin at the final point and matched each other. This would tell us that the particles were changing over time and yet were somehow matching each others spin at each point of measurement.
The experiments in their current form (unless I"m still not understanding them) do not allow you to claim absolutely one thing or another as they are way too basic and touchy.
Could anyone explain where I'm wrong with this line of thought?
Thanks,
glenn
glenn,
Have you really read the details of how the experiment is performed? Check some of the papers I have provided as reference previously, including the following:
Violation of Bell's inequality under strict Einstein locality conditions
These experiments are considered conclusive to most scientists. The photons are often sent through fiber optics, which does NOT cause collapse of the wave function. While the experiments are often called "finicky", this is an issue to the experimentalist and is not representative of their conclusions.
Your hypothesis (1,2,3) does not make sense because after entangled particles are measured, they no longer display the characteristics of entanglement.
As to having opposite spins and not being entangled: Only entangled particles can have this attribute. But this itself is not a proof that there is something "freaky" going on! It takes Bell's Theorem to get us to that point. And that theorem involves tests at angles OTHER THAN opposite. So you are mixing your criticisms.
DrChinese said:
glenn,
Yes, I really read them. What physical medium the particles are sent through really isn't important. What seems important to me is the fact that 1: You can't touch them until the magic moment, and 2) Once you touch it the party is over. Its like making a claim that two baseballs always communicate with each and change their spin instantly when one is looked at. But you can only look once because after that point it no longer holds true. How can you make the claim that something "ALWAYS" happens when in reality you can really only see it happen 1 time. And even then, Only when great care has been taken to set things in motion?
But is this not the entire point of my argument? My point was that only if you could do such a test could you make the overwhelming claim that is being made. The fact that you can't do the test was never mentioned but seems to backup my point even further. If you can't do anything but a single test that you've basically setup from the start to pass, then I don't see how its so important.
I'm not sure I follow this. I know the tests are done at different orientations, however, the original two particles are hooked together through this entanglement process. So of course they are related and therefore any test on one is going to show similar results on the other. You've set them up to be that way from the start of the experiment.
You yourself accept that once you've touched either particle you've broken the link. Therefore, its like having my 2 baseballs and you make the claim they always know about each other and instantly change, until I hit one with a baseball bat. At that point it doesn't hold true any longer.
Perhaps I'm not fully grasping the magic quality of this experimental result. When I first read about this test I was intrigued as it did sound pretty interesting based on the "Particle in a box" example that was given. However, as soon as I read how simple the test was and how touchy it was, I lost the magic. Perhaps there is still something not being explained properly that I'm missing?
Thanks,
glenn
cybercrypt13 said:
1. But is this not the entire point of my argument? My point was that only if you could do such a test could you make the overwhelming claim that is being made. The fact that you can't do the test was never mentioned but seems to backup my point even further. If you can't do anything but a single test that you've basically setup from the start to pass, then I don't see how its so important.
2. I'm not sure I follow this. I know the tests are done at different orientations, however, the original two particles are hooked together through this entanglement process. So of course they are related and therefore any test on one is going to show similar results on the other. You've set them up to be that way from the start of the experiment.
3. You yourself accept that once you've touched either particle you've broken the link. Therefore, its like having my 2 baseballs and you make the claim they always know about each other and instantly change, until I hit one with a baseball bat. At that point it doesn't hold true any longer.
4. Perhaps I'm not fully grasping the magic quality of this experimental result. When I first read about this test I was intrigued as it did sound pretty interesting based on the "Particle in a box" example that was given. However, as soon as I read how simple the test was and how touchy it was, I lost the magic. Perhaps there is still something not being explained properly that I'm missing?
1. Your hypothesis is factually false. It is not the responsibility of QM to provide a description which is inaccurate, nor does it need to describe everything. It need only be useful. You can set the bar wherever you like, just don't expect others to agree with it.
2. There are set up to be entangled, yes. And the entanglement leads to predictions which are incompatible with local realism. The predictions are related to the observer, and not solely the source particles themselves (as would be expected in a classical world). Bell specifically addresses the incompatibility issues and the "naive" view that explains the "perfect" correlations. The naive view cannot address the correlations at other angles, however, and that is the issue.
3. Why should they remain entangled forever? This criticism makes NO sense. Besides, it is not strictly true that they stop being entangled when you hit them with a "baseball bat". Only the non-commuting observables are affected. A polarization observation does not affect such observables as position or momentum.
4. What you are missing is that there is nothing "simple & touchy" about the results, which agree with the predictions of QM within 50+ standard deviations - and are FAR outside the range for classical explanations.
I never said anything about responsibilities to explain everything. I only stated that I do not, and still don't understand how something so specific has been stated based on this experimental evidence. The link you sent even states that currently they are only able to measure 5% of the particles that even move through the device. So we're basing something on 5% of measured particles. But this is really not as much a problem for me. Its more the fact that the experiment is so basic. Yet there have been volumes written on how this experiment proves the completeness of QM.
Where would this be? Where are the measurements that can't be explained any other way, except through QM? You mess around with two baseballs and get them to spin opposite each other. You then fire them out into a field and take a single measurement on them and determine, hey, these things are spinning opposite each other, and when I measure that one over there (one time only), this one over here happens to be spinning in a relation to that one. But didn't we setup the experiment for this to exist? Didn't we begin the very first step of the experiment to correlate the two particles? So wouldn't it be more amazing if they were not still spinning like that?
Even you admit that after you measure one particle that you can't do further measurements because its likely they are not entangled any longer. This would hold true to my "classical" point of view, that the only reason they are still spinning the way they are is because no one has touched them. As soon as you start jacking around with them we will no longer be able to be sure things had not changed.
I never said they had to. I only stated that you use the term as if its mysterious that they are entangled at that first point of measure for observer Allison. This to me is not mysterious at all but can be explained in the world in which I live. I just think we're giving a little too much credit to an experiment that quite honestly doesn't seem prove anything at all.
To state the particles are entangled seems to actually mean that you've gotten them to spin in relation to each other. Thats it. Its not that they had a conversation with each other and transmit information faster than light, its more that we related their spin from the start of the experiment and then sent them on their way. To forever stay that way unless anything at all touches them.
Again, what are these things that can't be explained?
Thanks, Just trying to understand...
glenn
What do you mean "a 15% or even a 45% different spin"? Spin is a quantum property where whenever you make a measurement of spin on a particular axis, the measurement always collapses the wavefunction in such a way that the particle is 100% spin-up or 100% spin-down on that axis.
Hmm, I think that from what I've been reading that the techniques for actually measuring spin up and down are with the use of a device that has opposing magnetics. From what I understand (which could be wrong) the spin up and down come from the fact that as the particle flies through the magnets it is either deflected up or down which is why they say it has spin up or down. So my point is, that when the particle flies through, we have absolutely no way to determine if the actual spin is 100% up, or has a 10% deflection. All we know for sure is that it passes through our device and is deflected up or down.
So unless there is some way to measure things exactly I would say my statement has just as much relevance as to say things are always 100% up or down. To further prove my point, you can take the device and rotate it to say 45% and a certain percentage of the particles still moves through the device while a certain percentage are blocked. This would seem to say that 100% up or 100% down is not exactly correct. Its all related to the orientation of the device itself that is measuring the particles as they pass through.
Are there other methods of measuring these things that I need to read up on?
Also: To clarify the purpose of this post, its not to bash anyone or QM. I am only confused due to people stating as fact things that appear on the surface to be completely unknown. Blame my current state on all the books I've read... :-) I just really want to understand this stuff...
Thanks for you time,
glenn
As has been explained, there IS nothing surprising about the results you describe above IF that was what was going on. This situation was originally described in the 1935 EPR paper (in a little different manner).
But your example is one that is referred to as LOCAL REALISTIC. In such a theory, it doesn't matter how each of the 2 observers' measurement settings are oriented - the results are always predetermined for any angle. Bell discovered that this could not be true IF the cos^2(theta) held. And this is the significance of the Bell tests.
Specifically, your hypothesis requires that all possible outcomes have a likelihood of occurrence in the range of 0 and 100%. It turns out that some of these outcomes actually would occur on the order of -10% of the time. So your hypothesis fails. QM does not make the same assumptions you do, so it does not have this problem.
glenn
Electrons are tested for spin with magnets sometimes, while photons are tested using polarized crystals of varying types.
But your idea about spin is way off. If you take a particle with measured spin oriented at 0 degrees - and then test its spin at 0 degrees a hundred more times, it will still show as having that orientation each time. It will NOT have a 50% chance each time. So the idea that there is some kind of range is invalid. If your idea was correct, it would have been obvious a long time ago.
And, of course, your idea continues to run afoul of Bell's Theorem which rules it out completely.
Ok, So you are saying that the measurement of a particle doesn't change its orientation? Since earlier we were saying that we can only measure the particle once because it decouples it with the other.
Also, I'm still confused about my angle point because you are assuming I'm talking about a single particle measurement over and over. I'm actually talking about the following: 1 particle route through 1 device. You sent 1000 particles through the device: 1) Do you see all 1000 come through? Reason for question is that from what I've read you do not. 2) if you do see them all come through can you guarantee me that all 1000 have exactly 0 degree spin up? Or could one have been 5% off dead center and another 10%? I don't see how you can tell me since a polarized lens or a magnet are not going to block all particles except those that meet top dead center.
From your first post above: The measurements are always what is expected? First of all are you telling me someone has captured more than a small percentage of the particles to test? The article you sent specified 5% was as high as they got on their captures. Secondly, Can we change the line of the conversation to only discussing your point of expected results?
Could you please give me an example of what would be different between QM and classical in the following example so I can better understand where the strangeness enters.
Classical: I say that if you successfully entangle two particles that the following will happen: (keeping in mind its possible you think you entangle but they may not in fact be) I say that as the two particles pass through detectors that are oriented the same way that they will show the opposite results (ie: spin up on one and down on the other). If they are at different angles then they will show different results but based off of the same spin up down orientation.
So what exactly is seen? What is the specific point that QM describes that can not be described in classical physics?
Thanks again for you time, sorry I'm being so hard headed... :-)
Also, I am correct when I state that two entangled particles each spin opposite each other aren't I? Or do they both spin up and I have gotten myself confused?
glenn
The following article gives an example of the sort of things that happen when the polarizers for the two particles are not parallel:
http://home.southernct.edu/~watsonm4/mermin_moon.pdf
When you measure a particle's spin on a given axis, it collapses its wavefunction so it's totally spin-up or spin-down on that axis, but there's a random element to what you'll find if you then measure on a different axis (the probability of collapsing into spin-up or spin-down on that axis depends on the angle between it and the first axis). So if you measure on axis A, then measure again on axis A, you're guaranteed to get the same spin on the second measurement as the first (and will continue to get the same spin if you measure on A more times); but if you measure on axis A, then measure on a different axis B, then measure on A again, you may get a different spin on the second A-measurement than you got on the first.
What you see in QM but would never see in classical physics is violations of Bell inequalities. On another thread I posted an analogy to help explain what this means:
Suppose we have a machine that generates pairs of scratch lotto cards, each of which has three boxes that, when scratched, can reveal either a cherry or a lemon. We give one card to Alice and one to Bob, and each scratches only one of the three boxes. When we repeat this many times, we find that whenever they both pick the same box to scratch, they always get opposite results--if Bob scratches box A and finds a cherry, and Alice scratches box A on her card, she's guaranteed to find a lemon.
Classically, we might explain this by supposing that there is definitely either a cherry or a lemon in each box, even though we don't reveal it until we scratch it, and that the machine prints pairs of cards in such a way that the "hidden" fruit in a given box of one card is always the opposite of the hidden fruit in the same box of the other card. If we represent cherries as + and lemons as -, so that a B+ card would represent one where box B's hidden fruit is a cherry, then the classical assumption is that each card's +'s and -'s are the opposite of the other--if the first card was created with hidden fruits A+,B+,C-, then the other card must have been created with the hidden fruits A-,B-,C+.
The problem is that if this were true, it would force you to the conclusion that on those trials where Alice and Bob picked different boxes to scratch, they should find opposite fruits on at least 1/3 of the trials. For example, if we imagine Bob's card has the hidden fruits A+,B-,C+ and Alice's card has the hidden fruits A-,B+,C-, then we can look at each possible way that Alice and Bob can randomly choose different boxes to scratch, and what the results would be:
Bob picks A, Alice picks B: same result (Bob gets a cherry, Alice gets a cherry)
Bob picks A, Alice picks C: opposite results (Bob gets a cherry, Alice gets a lemon)
Bob picks B, Alice picks A: same result (Bob gets a lemon, Alice gets a lemon)
Bob picks B, Alice picks C: same result (Bob gets a lemon, Alice gets a lemon)
Bob picks C, Alice picks A: opposite results (Bob gets a cherry, Alice gets a lemon)
Bob picks C, Alice picks picks B: same result (Bob gets a cherry, Alice gets a cherry)
In this case, you can see that in 1/3 of trials where they pick different boxes, they should get opposite results. You'd get the same answer if you assumed any other preexisting state where there are two fruits of one type and one of the other, like A+,B+,C-/A-,B-,C+ or A+,B-,C-/A-,B+,C+. On the other hand, if you assume a state where each card has the same fruit behind all three boxes, like A+,B+,C+/A-,B-,C-, then of course even if Alice and Bob pick different boxes to scratch they're guaranteed to get opposite fruits with probability 1. So if you imagine that when multiple pairs of cards are generated by the machine, some fraction of pairs are created in inhomogoneous preexisting states like A+,B-,C-/A-,B+,C+ while other pairs are created in homogoneous preexisting states like A+,B+,C+/A-,B-,C-, then the probability of getting opposite fruits when you scratch different boxes should be somewhere between 1/3 and 1. 1/3 is the lower bound, though--even if 100% of all the pairs were created in inhomogoneous preexisting states, it wouldn't make sense for you to get opposite answers in less than 1/3 of trials where you scratch different boxes, provided you assume that each card has such a preexisting state with "hidden fruits" in each box.
But now suppose Alice and Bob look at all the trials where they picked different boxes, and found that they only got opposite fruits 1/4 of the time! That would be the violation of Bell's inequality, and something equivalent actually can happen when you measure the spin of entangled photons along one of three different possible axes. So in this example, it seems we can't resolve the mystery by just assuming the machine creates two cards with definite "hidden fruits" behind each box, such that the two cards always have opposite fruits in a given box.
cybercrypt13 said:
1. Ok, So you are saying that the measurement of a particle doesn't change its orientation? Since earlier we were saying that we can only measure the particle once because it decouples it with the other.
2. Also, I'm still confused about my angle point because you are assuming I'm talking about a single particle measurement over and over. I'm actually talking about the following: 1 particle route through 1 device. You sent 1000 particles through the device: 1) Do you see all 1000 come through? Reason for question is that from what I've read you do not. 2) if you do see them all come through can you guarantee me that all 1000 have exactly 0 degree spin up? Or could one have been 5% off dead center and another 10%? I don't see how you can tell me since a polarized lens or a magnet are not going to block all particles except those that meet top dead center.
3. From your first post above: The measurements are always what is expected? First of all are you telling me someone has captured more than a small percentage of the particles to test? The article you sent specified 5% was as high as they got on their captures. Secondly, Can we change the line of the conversation to only discussing your point of expected results?
4. Could you please give me an example of what would be different between QM and classical in the following example so I can better understand where the strangeness enters.
5. Also, I am correct when I state that two entangled particles each spin opposite each other aren't I? Or do they both spin up and I have gotten myself confused?
glenn
I'll do my best, but you are all over the place. :smile: Because you don't follow a single point all the way through, it makes it difficult to drive the point all the way home.
1. No one knows ACTUALLY what happens. We know that it appears to happen AS IF a measurement of one instantaneously affects the other so it matches. But whether or not that actually happens is a guess. Maybe there is some other mechanism (but not LOCAL REALISTIC) at work.
2. Not sure what you mean. In a normal stream of (randomly) entangled particles, 50% will pass through regardless of the orientation. Once a photon passes through a polarizer lens, it is oriented at that angle.
3. All of the properly entangled pairs are measured. Keep in mind that most photons entering the PDC apparatus do NOT turn into an entangled pair. They come straight out and are diverted to aplace where they can be ignored. Many pairs come out entangled, but they are not at quite the proper wavelength. These too are diverted. The successful pairs are then tested. Most of these are seen, but a small percentage yield a detection on one side without a detection on the other. This is due to detector efficiency.
Keep in mind that most Bell tests use polarizing beamspitters rather than filters. Therefore, the photons on each side are seen as either hortizontal or vertical (H or V is arbitrary).
4. I keep trying to explain that your classical description FAILS in actual experiments because there are hidden assumptions. You are ignoring the hidden assumptions. Specifically, these are detailed in Bell's Theorem. If you want to see the assumptions and the related math for yourself, go to my page on the subject:
Bell's Theorem with Easy Math
By the way, this page follows the logic of Mermin per the article cited by JesseM, but may perhaps be easier to follow... or not.
5. That is a good question. In Type I PDC, the photons have identical polarization. In Type II PDC, the photons have orthogonal polarization, which is to say they are 90 degrees apart. Orthogonal is also referred to less precisely as "crossed" from time to time.
I hope this helps.
JesseM,
Thanks for the information. I understand in theory the point, however, I'm still very much confused as to what specific element of the noted test falls into this card game. First of all, we are responsible for entangling the particles which does not appear to me to be as simple as choosing randomly 2 playing cards. We are basically aligning those particles to each other before we start our test.
Next, unlike the game, we can't sit and play over and over with the same particles to see what happens. After we play once we must throw away the 2 cards and draw another 2. Because of this we loose the ability to get anything useful out of the game.
Next we have the issue with the ending measurements (when detected) being of the same relationship and we therefore imply that the two particles have communicated with each other faster than the speed of light would have allowed. But what I'm trying to get in my head is exactly what magic thing is happening here that I can't provide an explanation for in the classical sense.
I am not arguing with you, if you actually could show me the cards or a box with two particles in it that acts the way all the books and articles I've read explain it to work, then I'd be very intrigued indeed. However, when getting down to the nuts and bolts there are no 2 boxes, there are no cards. There are only 2 particles that we setup to run a test on by entangling them through whatever means, then send on their way. There is only a single test that can be run on them before the relationship between them is broken.
This all makes perfect sense to me. I'm still trying to find the part that doesn't make sense. Can you explain it without actually getting into boxes and card tricks but using only 2 particles that can only be tested once?
Again, using your example I agree completely that something strange is going on, but I'm fighting with understanding what in this test would lead to this conclusion.
Thanks,
glenn
Dr Chinese,
Thanks for all the info, I'll take a look at your site and get back with you guys tomorrow if I have any more questions. I'm sorry I'm jumping around as you said, I'm trying to stay focused on this one issue but there are a few different aspects of it...
Talk to you tomorrow and thanks again for your time.
glenn
cybercrypt13 said:
JesseM,
I didn't say anything about "randomly choosing" the cards. In fact, since whenever we both choose to scratch the same box on a given trial, we always get the opposite answer, it's obvious that the cards cannot be generated in a completely random way. If you assume that there is a definite fruit behind each of the three boxes on a given card, then in order to explain this correlation, you must assume that whoever is sending us these cards is always taking care to send me a card with the opposite fruit behind each box as the one that's sent to you--if my card's "hidden fruits" are a cherry behind the left box, a lemon behind the middle box, and a lemon behind the right box, then your card's "hidden fruits" must be a lemon behind the left box, a cherry behind the middle box, and a cherry behind the right box. If the person sending out pairs of cards wasn't taking care to correlate them in this way, how else could you explain the fact that on every trial where we both choose the same box to scratch, we always get opposite fruits, even if we repeat the experiment for thousands of trials?
But the correlations that violate Bell's theorem have nothing to do with measuring the same particles over and over. Rather, they involve doing the experiment over and over with a new pair of entangled particles on every trial, and noting that on every trial where both experimenters happen choose the same axis to measure, they always get opposite results for the spin of their particle. This is just like the scratch lotto game, where you do the experiment over and over again with a new pair of cards on each trial (imagine the cards self-destruct after you reveal one box), and you note that on every trial where both of us chose to scratch the same box on our respective cards, we found opposite fruits behind that box.
It's not clear that you're actually understanding the experiment I'm proposing with the cards. But yes, using quantum physics you could simulate these results--say instead of an actual physical card, on each trial our computer monitors each display an image of a card with three hidden boxes, and we click on a box to reveal the fruit there, after which the card disappears from the screen and we then see a new card with three hidden boxes on the next trial. If our computers were hooked up to measuring-devices measuring the spin of entangled particles, and our choice of which box to select determined which angle the device would be set, and which fruit the computer displayed would depend on whether the particle was measured to be spin-up or spin-down on that axis, then you could get exactly the results I described--whenever both of us clicked the same box on a given trial we'd always get opposite fruits, yet on the set of trials where we clicked different boxes, we'd get opposite fruits less than 1/3 of the time. If the computers weren't allowed to use quantum effects to determine what fruit to display, though, this pattern would be totally impossible to explain classically! Read over my explanation again if you don't see why.
Again, although a given pair of entangled particles are only measured once, the violation of Bell inequalites which violates classical expectations is based on the statistics when you repeat the experiment many times with multiple pairs of entangled particles.
cybercrypt13 said:
JesseM,
Looking at related experiments like the delayed choice quantum erasor can help you believe that the quantum states aren't pre-set at emission. This experiment doesn't set out to prove this antecedent.
The conclusion is false. You don't have to use the same coin to do probability tests on coin-flipping. Again, understanding previous experiments will help. You're jumping into the middle of the QM story.
See comment #1. You first have to be convinced that the photons' states are indeterminate before detection. This is a tenent of QM.
It follows from that if the states of the photons are indeterminate to start with, then when you collapse the wave function of the first particle, something happens which causes a property of the second particle to be determined as it is flying to the second detector. That something is the entanglement of the particular (i.e. spin) property of the two photons. It's as if information is exchanged, but faster than the speed of light.
You're thinking about "relation" in the wrong way. There is no rod connecting them. Also, you haven't gotten them to "spin" at all, until they reach the destination. All they have are the words, "spin me the same way as you spin the other ball", written on them as instructions to the catcher.
Thats it.
No, it's not.
Yes it is.
You said it, we *related* their spin. You don't seem to understand "related", though.
Here is another way to look at the situation. Consider the two photons as part of a computer program. Photons have a class which defines their behavior. You create two photons/objects using the photon/class-template, and each has an independent set of variables and functions. Accessing one of the variables calls a random number generator to set the variable if the value is "undefined", so you can expect that variable, "spin", has no correlation between the two photon/objects.
Now, to entangle the "spin" variables, immediately after you create the photon/objects, you override the accessing method to call the random number generator, get a random value, and set the "spin" variable of BOTH photon/objects to that value (or it's inverse)[if undefined]. You have now "related" the [spin] variable of the two photon/objects.
The photon/objects continue merrily in your execution loop, until one gets a "detector" event, accesses the appropriate variables (i.e. "spin"), and then is destroyed. You can see that the photon/object remaining in the loop now has a value for it's "spin", and that will be the value delivered to the detector.
In the program, there is no delay between setting the two values, in terms of the loop counter, which holds the "time" value for the photon/objects (disregard the CPU clock cycles). For real photons and everything else, there is supposed to be a delay based on the speed of light.
This is a pretty direct analogy [better than cards, coins, baseballs] to what QM tells us about entanglement, IMHO.
I think I understand what you are saying but I really don't see how your example makes the "relate" process any different from my point. By related, they have something to do with each other.
Definition: Correlate: to place in or bring into mutual or reciprocal relation; establish an orderly connection
Definition: Entangle: To twist together or entwine into a confusing mass
Whether you want to say things don't exist or do exist at the point they are entangled or only later when they are actually measured is a ridiculous (or would seem) argument since you have absolutely no way to prove it true or false.
So we just have to stick with the fact that they are entangled at the source, or at the point of our constructor for our two classes. However, even in your example, at the point of calling our detect function, you have agreed that the two particles are in fact entangled at this point which is the only point I'm concerned with.
So here are a couple questions to make sure I understand this experiment fully, then I"ll ask my next question.
1) When the particles are created and begin their path through whatever medium we've setup for our test, they are entangled so as to share some relationship to each other?
2) When we measure one particle we find that the other immediately snaps to an opposite orientation of the first?
3) The single item on our list that you are saying can not be explained through classical physics is not the effect of the two particles sharing their relationship, but the fact that 25% of the time they do when they shouldn't.
To further explain my question: All material I've read on the experiment describes 3 switches on each device that are each chosen completely randomly. 100% of the time when the switches are the same, we get a matching light. Since we have 3 switches and two boxes, we should expect to get a 33% matching rate and a 66% non matching rate. However, what the test reveals is a slightly more matching rate. Its described as being 50% match and 50% non match. It says 25% but would seem 17% would be more exact unless I'm doing my math wrong.
So we're mainly concerned with this extra matching of the lights when the switches were NOT set on the same marks?
Before we continue I want to make sure I'm understanding the test.
Thanks,
glenn
Yes, experiments to test Bell inequalities involve pairs (or occasionally triplets or more) of entangled particles.
Only if both experimenters set their detector at the same angle are they guaranteed to measure opposite spins.
25% is just a number I picked because it looks nice, all that's important is that it's less than one third. And it's not that the number is less than one third on all trials, it's that it's less than one third on the subset of trials where the experimenters have chosen two different angles.
Well, only if you set it up so that you get a "matching light" when the spins are opposite rather than the same...but yes, as long as you define "matching" this way you'll get 100% matching when the angles are the same.
Not necessarily, classically the matching could be anywhere between one third and 100%. Imagine that on each trial, the three "hidden spins" on the angles of the detectors are always +++ for one particle, and --- for the other. This will ensure that when both experimenters choose the same angle, they always get opposite spins, but it will also ensure that even when they choose different angles they always get opposite spins. On the other hand, if the source always creates particles in non-homogeneous hidden states like +-+ and -+-, then when they choose different angles they'll get opposite spins one third of the time. If the source sends out some mixture of pairs that are in homogeneous hidden states and pairs that are in non-homogeneous hidden states, then when they choose different angles they'll get opposite spins somewhere between one third and 100% of the time.
Who said it was described as 50% match and 50% non match? It all depends on what three angles you pick and on the probability of getting opposite results for each possible pair. For photons, for any two angles X and Y the probability of getting opposite results is the cosine squared of Y - X. So suppose A = 0, B = 60, and C = 120. Then there are 6 possible cases where they choose different angles: experinter 1 chooses A and experimenter 2 chooses B [1A, 2B], experimenter 1 chooses A and experimenter 2 chooses C [1A, 2C], and so on for [1B, 2A], [1B, 2C], [1C, 2A], [1C, 2B]. So, total probability of getting opposite spins when different detector settings are chosen would be 1/6*P(opposite spins given [1A, 2B]) + 1/6*P(opposite spins given [1A, 2C]) + 1/6*P(opposite spins given [1B, 2A]) 1/6*P(opposite spins given [1B, 2C]) + 1/6*P(opposite spins given [1C, 2A]) + 1/6*P(opposite spins given [1C, 2B]). Given the angles above and the cosine squared formula, this works out to 1/6*(0.25) + 1/6*(0.25) + 1/6*(0.25) + 1/6*(0.25) + 1/6*(0.25) + 1/6*(0.25) = 0.25
You're concerned with fewer "matches" than expected classically, again assuming a "match" means the spins were opposite.
First who said 50/50?... look up at the posts that others have attached to this thread. They state that each switch setting ends up being chosen exactly 1/3 of the time and so in ALL runs the same colors will flash 1/2 of the time.
This 25% you keep talking about doesn't make sense to me either though. You are saying 25% which is less than 1/3, but its not less than 1/3, its more. The way I'm reading the experiment and you've already agreed that 100% of the time when the same measure angles are chosen you get the same colors. That means that if all switch settings are chosen equally that you should expect to get a 1/3 match based on this fact alone. That leaves 2/3's to work with. Now, on that 2/3's, the experiment details state that classical physics expects to get 100% of them to not match. The 25% you are talking about is not actually that we're getting less matches but that some of the time we get more matches than what one should expect.
So if you could please explain to me what you are talking about getting less than 1/3 I'd appreciate it as that statement has me rather confused at the moment.
I'm also not sure I follow your last paragraph. I see the numbers but classically you've only selected the 6 settings that should result in non matches 100% of the time. Classically I'd be surprised that I got any matches at all during those tests and here is why.
If the particles acted classically then I'd agree with your numbers and there being a possibility of having a few matches slip in here and there. However, from what QM says, the particles don't have any spin until they are measured and then both snap to attention at that point(faster than the speed of light).
If this were really true, then it would appear that me measuring particle A at ANY switch setting would cause B to snap to the same angle or opposite angle. Now if this were really happening I'd expect the lights to never show a match because B would always be at a different angle than my switch setting was looking for.
The fact that we're getting matching lights at all during this 2/3's part of the test baffles me. Classically I can make sense of it but Quantum Mechanically I can not.
Also, do you know of a picture or explanation of the actual measuring device? I've seen a few drawings of the measuring device but they always have A,B,C from left to right and I don't really understand what is going on inside the device itself. I'd like to better understand that.
Thanks,
glenn
Well, if the probability of getting opposite spins with different detector settings is 0.25, then it's true that on all runs you'll get opposite spins 1/2 of the time. But as I said, that depends on your choice of the three detector angles.
What do you mean? Clearly 1/4 is less than 1/3!
That would mean at least 1/3 on the total set of trials, including those where both experimenters chose the same setting.
It seems like you're talking about the total set of trials, but what I actually said was that classical physics predicts you'll get a match on 1/3 or more of the subset of trials where the two experimenters chose different angles. In other words, on 2/3 of the total trials the experimenters will happen to choose different angles, and if we just look at these trials and throw out all the ones where they chose identical angles, classical physics predicts that we got a match on at least 1/3 of these trials, which means it's predicting a match on at least (1/3)*(2/3) + (1)*(1/3) = 5/9 of the total trials.
Yes, again, I selected the subset of trials where the experimenters chose different detector settings.
The numbers I posted would be impossible to explain classically, assuming that on the trials where the experimenters did choose the same setting they found opposite spins 100% of the time. Look over my explanation of why classical physics predicts at least 1/3 on the subset of trials where they pick different detector settings (or different boxes in my scratch lotto card analogy) again:
There are different "interpretations" of QM, only in the Copenhagen interpretation does measurement instantaneously "collapse" the wavefunction in this way. This wouldn't be true in the many-worlds interpretation or the Bohm interpretation, both of which are equally consistent with the observed probabilities.
No, the wavefunction assigns probabilities to the particle being spin-up or spin-down along each possible angle, and what happens is that if you measure one particle to be spin-up on angle A then the Copenhagen interpretation says this "snaps" the wavefunction of the second particle such that it has a 100% probability of being spin-down on angle A, but for other possible angles it still has some probability of being spin-up or spin-down (again, for photons the probability of being spin-down on angle B would be cos^2(B-A) ).
Remember, no matter what angle each experimenter chooses, they'll always find the particle either spin-up or spin-down on that angle. So a "match" doesn't literally mean both particles are spinning on the same axis or anything, it just means that if I measure angle A and you measure angle B, then if I get spin-up on angle A you'll get spin-down on angle B, and vice versa.
It would depend on what particle you're measuring, but for electrons you might use a Stern-Gerlach device which creates a magnetic field in one direction, and that deflects the electron up or down relative to the direction of the field. There's a good description of it here.
Thanks for sticking this out with me...
Yes, I know 25% is less than 33%, my point was that we were not seeing an overall decrease in results but rather an increase... Now that you've explained that we're only looking at the non matches instead of all matches I understand...
However, I'm still not quite there. First of all, if we were truly looking at random particles that absolutely, only could have a spin up or spin down then I'd agree that classical physics would predict what you are stating. However, I'm not quite seeing it this way.
First of all, we have two particles that you are entangling with each other, this would mean to me that we're relating the two with each other ( no matter where this happens ). So taking this into consideration I would not think that we'd see the percentages that you are stating. First of all, if I measured a particle on side A and got a green light, I would not think that we could guarantee that the actual spin-up angle was at 0 degrees of spin up. Its possible it was actually at 15 degrees off dead center and that depending on the selection at point B, might just fall into that detectors opposite detection and display the same light.
I could also tell you that this will not be the case 100% of the time which means that instead of 33%, I'm saying it would be less than 33%, but I couldn't tell you exactly how much less.
The fact that this entanglement is so delicate would seem to indicate to me that any messing with either of the two particles will cause them to no longer be spinning in the same or opposite orientation and therefore we could not predict what was going to happen.
What would really be exciting to me is if you could tell me the particles really did communicate in ways that constant measuring over and over caused them to continue to communicate. But what it seems this test is doing is simply telling me that they had a similar orientation at the point of origin. I don't see the magic here and I'm trying really hard...
I've read 3 different papers on this experiment and what its out come is, however, I am really having a hard time seeing what is so special about it. I could have given you a prediction of less than 33% without any QM at all. It seems like common sense to me if you assume that we can't know the exact spin of a particle.
Along that line, I understand that to measure spin up and down we either use polarizers or magnetic devices and all experiments say that rotating the device still yields results of spin up and down. This would also be expected if you assume you do not know for sure the exact angle of spin. All I see at this point is that you know what it is sort of doing. I also understand that non of the tests are able to capture 100% of the particles and I read in one of the latest that they were able to capture the most at around 5% of all the particles sent through. This would seem a huge gap in available information...
Please don't get upset with my point of view as I'm just talking... I am enjoying this conversation and hope that the magic sinks in soon...I'm sure you are too... :-)
glenn
Please don't think the particle has a well-defined "spin angle", this concept only makes sense classically! Right as you posted I added this edit to my last post:
I also recommend reading the article on the Stern-Gerlach apparatus I posted, it explains how classical charged spinning objects do have a well-defined spin axis which means that they can be deflected at a range of angles depending on the difference between their spin axis and the external magnetic field, while particles in QM are always deflected at one of two possible angles, labeled "up" and "down", regardless of how the external magnetic field is oriented. A quantum particle just has a wavefunction which assigns different probabilities to spin-up vs. spin-down on different axes, and in the Copenhagen interpretation each measurement "collapses" the wavefunction so it's 100% spin-up or 100% spin-down on whatever axis was measured, but different probabilities on other axes.
What will not be the case 100% of the time? It's an actual confirmed result that when both experimenters measure the spin of entangled particles at the same angle, one gets spin-up and the other gets spin-down 100% of the time.
Have you looked at the simple proof I posted? Do you disagree that if we imagine one particle has the preset spins A+, B-, C- (meaning you'd get + if you measured on axis A, - if you measured on axis B, and - if you measured on axis C) while the other has preset spins A-, B+, C+, then if we randomly choose two different axes the probability of getting opposite results will be 1/3? Do you disagree we need to imagine the two particles have states which preset the results you'll get if you measure on any of the three axes A, B and C in order to explain how we always get opposite results when we choose the same axis in a classical world with no FTL signalling?
No you can't. It really is impossible classically that both the following would be true:
1. When you measure both on the same axis, you always get opposite spins 100% of the time.
2. When you measure the two on different axes, you get opposite spins less than 33.3...% of the time.
Again, look at the proof I posted and tell me where you think it's wrong.
What would be expected? Classically, if you have a charged object spinning on a particular axis which travels through an external magnetic field, it can be deflected at an infinite range of angles depending on the angle between its spin axis and the external field. In QM you only get two possible angles for the deflection, and there's no notion of explaining this in terms of the particle having a definite spin axis pointing in a particular direction. If you think it does, how would the direction of this axis determine whether it goes up or down?
Also note that the proof of Bell's theorem is very general...even if particles were deflected at a range of angles, you could still turn it into a binary choice by classifying all trials into something like "difference between deflection angles less than 180" and "difference between deflection angles greater than or equal to 180", and if it was true that you always got a difference of more than 180 on 100% of trials where both experimenters oriented their magnetic fields in the same direction, it would be absolutely impossible for them to get a difference of more than 180 on less than 33% of the trials where they chose two different magnetic field orientations (assuming they were each choosing randomly between three possible orientations).
All that matters for Bell's theorem is the results, which are impossible to explain classically regardless of what idea you might have about why the particles give the results.
Assuming there's no correlation between which pairs of particles you miss and which detector settings you happen to be using, I don't think this would matter (and since the two settings can be chosen independently in such a way that the particles can't be influenced by both without FTL signals being involved, I think such a correlation can be ruled out as a loophole). But I haven't looked too much into the specific experiments they've done, I think we should concentrate first on making sure you're clear on the impossibility of reproducing the ideal theoretical experiment in classical physics, and then if you're convinced it would be impossible in the idea experiment you could look into the actual experiments and see if they have any significant loopholes.
Well, I'm thinking that missing 95% of the data might just be important for the following reasons. First, if we were to say that its just possible that running the particles through a magnetic device could possibly influence their original path, then its possible that you don't only have spin-up and spin-down based on the angle of measure. Of course I'm not saying any of this is real, just thinking through it.
It would also appear that if I had 2 particles that were entangled and let's just say our measuring devices are set to measure at 0 degrees straight up. If the particles left at say 10 degrees and 190 degrees respectfully, and we took into account that our device might just pull the particle up to zero just by the act of measuring it, then we could expect to see it always be spin-up and down based on the orientation of our measuring device. The fact that we're not able to detect 100% of the particles sent through however, also means its possible that some of the particles can't in-fact be brought up and therefore don't pass through.
Taking this into account, it could also explain small pass ratios that you wouldn't normally expect to see, based on the fact that you are actually pulling the particles around to measure what you expect in QM.
Of course, I'm not saying this is fact, just that its possible and would be impossible (or so it would seem) to prove either way.
The magnetic device we're measuring with seems to support my conclusion in the following condition. We know that if 2 filters are placed after each other 1/2 of all particles shot through them pass through both filters if they are oriented in the same up position. If you place the second filter 180 degrees from the first then 0% will pass through. However, if you then place a third filter between the 2 and place it at 90 deg, then you will get 1/4 of the particles passing through the final filter. This would appear to show that the first filter snapped the particles to 0 degrees or close enough, the second filter was able to snap 1/2 of those around to 90deg or close enough, which then allowed the final filter to snap 1/2 of those around to 180. So it would appear that we can't possibly say the filters do not in any way modify the original particles spin after they enter the field of the devices.
QM assumes the particles have no spin at all until you actually measure them, where they snap into existence and exist. However, it would appear this experiment might present a problem with this aspect as well, due to the fact that the particles always seem to snap into existence oriented to our magnets. Doesn't this seem strange?
I'm still reading up on this stuff so please forgive me, but I just do not see how this experiment proves anything at all for QM. If the things you are stating here are absolute facts then I'd have to let go, but the fact is, we can't see the particles we're measuring and as such have no way to know for sure what they are really doing. We're trying to determine that by doing tests, but to state that QM is the only way to explain the results we're seeing just hasn't sunk in with me yet.
To save you time, I guess I'll go back and study some more and see if I can get it on my own. At the moment I think the two of us are stating the same facts back and forth and not moving much. Thanks for your time though as you've been a great help. I'm just not quite there with seeing the contradiction yet. Perhaps I'll feel really stupid once it finally hits me... :-)
Thanks again,
glenn
This won't affect the proof of Bell's theorem. No matter what angle the device is set at, 50% that go through will be spin-up and 50% will be spin-down, randomly. And yet if the particle going through one device is spin-up, and the other device is at the same angle, the other particle is guaranteed to be spin-down, and vice versa. If FTL is impossible, and the source has no way of knowing what angles the devices will be set at in advance, the only way to explain this classically is to say that every particle has a predetermined answer to what spin they'll be when measured at a given angle, and the two particles are always created with opposite answers. Now, "predetermined answer" doesn't necessarily mean the particle is already spin-up or spin-down relative to a particular axis, it just means that (the particle's preexisting state before being measured) + (the choice of detector angle) -> a single possible outcome for whether the particle will be measured spin-up or spin-down after it flies through the detector. You're free to imagine that the detector is changing the internal state of the particle as it travels through it, but as long as it does it in a deterministic way such that the above condition is satisfied, the proof of Bell's theorem is unaffected (in the proof I gave earlier a symbol like B+ need not mean the particle was 'already spin-up on axis B' before being measured, it can just mean that the particle's internal state was such that, if measured on axis B, it was guaranteed to give the result 'spin-up').
What does it mean for a particle to "leave at" a certain angle? The paths of both particles go straight from the source to the detector, otherwise you wouldn't detect them. Perhaps you're imagining the particles have their own spin axis like a classical spinning ball, and you're talking about the spin axis rather than the path the ball travels?
Well, it wouldn't work this way with a classical ball, but as I said you're free to imagine that the measuring device changes the internal state of the particle, as long as it works in a deterministic way such that the outcome is predetermined by the initial state of the particle before going through the device + the angle of the device, and as long as you also imagine that the initial state of both particles are such that they're predetermined to give opposite answers when they go through devices set to the same angle. If you imagined there was any random element to whether a given particle goes up or down given its initial state, then without FTL signalling you'd get a certain number of trials where both particles give non-opposite answers when they go through devices set to the same angle. Do you disagree?
No, it can't explain violations of Bell's theorem, not if a given particle's likelihood of passing through depends only on the angle of the device it actually travels through and is not affected by the angle of the other device (if it was affected by it, that'd require FTL). Just go back to my scratch lotto card example, and imagine that a certain fraction of the cards would spontaneously combust when you tried to scratch one of the three squares. The probability of spontaneous combustion can depend on which square you pick to scratch and what the "hidden fruits" behind each square are, but it can't depend on what square the other distant person scratches. If you think about this you will see that there is still no way to get the probability of opposite fruits when different squares are scratched lower than 33%, not if you assume the three hidden fruits on each pair of cards are always opposite (i.e. if one is cherry-lemon-cherry the second must be lemon-cherry-lemon), an assumption you must make in order to explain why you always find opposite fruits when both people scratch the same square.
No, as I already said there are interpretations which do not assume this. And the proof of Bell's theorem certainly doesn't depend on any assumption like this.
You keep saying you're not convinced, but you never address the details of my proof! Do you see a flaw in it? If so, what is it? And can you please address the questions I asked you in my last post about it?
The proof doesn't depend on any assumptions about what they are really doing! It just shows that the results cannot be explained by any local hidden variables theory, where "hidden variables" stand for any details about the hidden internal state of the particle. Once again, please address the proof instead of just speculating about what you imagine the particle might be doing, speculations which if you studied the proof you'd see are not actually relevant to the logic of the proof.
If you'd just address the proof we'd get somewhere--you might start with the simple questions I posted above.
Just a few comments as I have to run to school.
First, my comment about angle was related to spin, not direction of particles.
Secondly, I don't think you are quite following me either. My point is that if you assume that when you entangle the two particles that they start to spin in opposite directions, then it does take into account your findings. For example, any time you measure particle B and it is spin up, you are also 100% of the time going to find particle B spinning at its opposite (spin down).
We also seem to be totally ignoring the other 95% of the particles that we're loosing during the test. These particles could be getting blocked by the device entirely due to their spins not being oriented in such a way that they are able to pass through the measuring device. As such they get bounced off.
I'll go back and read your posting and give it a more complete response later tonight. Thanks again for all your patience.
glenn
But then you can't account for the under 33% figure when you measure different axes! This is the whole point of the proof, we aren't going to get anywhere if you just avoid addressing it.
Yes, and I already pointed out that this makes no difference to the proof in my last post:
There are few photons that are lost as you describe. The photons are time-stamped and logged at one of 2 detectors. The 2 detectors correspond to the 2 outputs of a beamsplitter (a crystal that transmits photons polarized in one direction and reflects all others). The beamsplitter can be oriented at any angle. It is easy to determine that the beamsplitter is not responsible for any significant loss, and this is of course checked by the experimenter. Beamsplitters typcially have high efficiency, into the high 90's (where 100 is ideal).
I don't know where you get the 95% number from either. a) There are some photons that are not detected due to detector inefficiency issues. b) There are some photons that are detected even when the source is turned off (so-called dark rate counts). These are usually noted in the experiment. Since these experiments are performed by world class scientists, they take great care to consider all of the issues you raise and many more. Their results include a factor for experiment error, and at this time the error is not large enough to skew the conclusion.
Further, as time passes, the detectors get better. As a result, the experimental error shrinks while the results themselves stay pretty much the same. Therefore, it is unreasonable to assert that the experiment is somehow contaminated so as to render a false conclusion.
