Question on finding moment of inertia about the center of mass
The moment of inertia (I) is not zero when the axis of rotation passes through the center of mass (c.o.m.). The formula I = m*r^2 applies, where r is the distance from the axis of rotation to the mass elements. For a solid cylinder, the moment of inertia is calculated as I = 1/2(Mr^2). The discussion illustrates that even when the c.o.m. is at the origin, the moment of inertia can be computed using the formula MOI = SUM (mi * ri^2), demonstrating that integration over mass elements is necessary for arbitrary objects.
  • Understanding of moment of inertia concepts
  • Familiarity with the center of mass (c.o.m.)
  • Basic knowledge of integration in physics
  • Knowledge of solid cylinder properties and formulas
  • Study the derivation of moment of inertia for various shapes
  • Learn about the parallel axis theorem in rotational dynamics
  • Explore integration techniques for calculating moment of inertia
  • Review examples of moment of inertia calculations for composite bodies
Students in physics, mechanical engineers, and anyone studying rotational dynamics or moment of inertia calculations.
melizabeth
So I have a question. I (moment of inertia) is basically mr^2 right? And r is supposed to be the distance from the axis of rotation. When the axis of rotation is directly through the center of mass, how is there Icm (moment of inertia about the center of mass). It's confusing to me, because so many problems demand using the Icm when the axis is through the center of mass. Wouldn't Icm be zero? But then they expect you to use the radius of the cylinder. The I of a solid cylinder is given as 1/2(Mr^2). Someone please help me. I think it might just be my lack of understanding.
It is your lack of understanding. Just because the axis of rotation runs thru the c.o.m., it does not necessarily follow that the moment of inertia is automatically zero. Remember, I = m*r^2, and that r^2 is what is key to understanding why I is not zero.
As an example, let's say that I have four masses m arrayed about the origin:
Mass 1 is located at (1,1)
Mass 2 is located at (-1,1)
Mass 3 is located at (-1,-1)
Mass 4 is located at (1,-1)
Clearly, the c.o.m. is located at (0,0). Each mass is Sqrt(2) units from the origin.
MOI = SUM (mi * ri^2), for 1 = 1 to 4
The MOI = m1 * 2 + m2 * 2 + m3 * 2 + m4 * 2 = 4*m*2 = 8m
The moment of inertia is only mr2 when the whole mass is at distance r from the axis, e.g. as would be the case for a small mass element of a larger body. To get the MI of an arbitrary object you need to integrate over these mass elements: ∫r2.dm. Since dm and r2 are both non-negative, the result never cancels out.
  • · Replies 21 ·
  • · Replies 40 ·
