Question on four momentum squared
The discussion revolves around the concept of four-momentum in the context of relativity, specifically focusing on the squared magnitude of four-momentum and its implications in conservation problems. Participants are exploring the relationship between four-momentum, rest mass, and the Lorentz factor, as well as the mathematical expressions involved.
  • Participants are attempting to understand the expression for four-momentum squared and how it relates to the rest mass and velocity. Questions arise regarding the treatment of the Lorentz factor and the implications of the angle between vectors in the context of dot products.
The discussion is ongoing, with participants clarifying notation and exploring algebraic manipulations. Some guidance has been provided regarding the interpretation of the four-momentum and the simplification of expressions, but no consensus has been reached on the specific steps to arrive at the expected results.
Participants are navigating through potential misunderstandings regarding the application of the Lorentz factor and the conditions under which it can be simplified. There is also a recognition of the importance of algebraic manipulation in resolving the problem.
bonbon22
Why does the four momentum squared lead to simply m^2*c^2
P (mc,mVx,mVy,mVz) <---- components of four vector where v is velocity in x y z directions
mc*mc - (three vector multiplied and added with corresponding parts)
ϒ = gamma factor = lorentz factor = (1/1-v[SUP]2[/SUP]/c[SUP]2[/SUP])[SUP]1/2[/SUP]
google lorentz factor if it looks confusing.
P ⋅ P/[p][p] =cos(θ) <----- three scalar product rule a level maths stuff
So i have taken a beginner course on relativity, first year physics student. I am confused as to why four momentum squared simply gives
m2* c22 -(three vector multiplied and added with corresponding parts) *ϒ2
so as the three vector part which is being subtracted, is the same as - (P ⋅ P) *ϒ2, a normal three dot product, which is the same as the - [p][p]cos(θ)*ϒ2
,but what would cos(θ) be ? If it is zero then we have an actual value for [p][p]cos(θ) = [p][p] which then i don't get how
m2* c22 - [p][p]cos(θ)*ϒ2 = is somehow simply m2* c22?
finally in many questions i have come across they seem to ignore fully the *ϒ2
(1/1-v2/c2)1/2 factor when doing conservation of four momentum problems. Where P1 +P1 =P3
where P1, P2,P3 are four momentums with the four components. Squaring both sides i get P12 + P22 + P1*P2 = P32 which ends up being m12c2 +m22c2 plus four vector product = m32c2[/SUP][/SUP]
Your notation is somewhat hard to read, but you do not appear to me to have quoted the four momentum correctly. It is ##P=(\gamma mc,\gamma m\vec v)##, where ##m## is the rest mass and ##\vec v## is shorthand for the three spatial components of velocity. The answer you are looking for follows directly.
Exactly thank you that does look better I am new to using the symbols my mistake.
So squaring a four momentum vector with itself gives (##\gamma mc## )2 subtracted with the ##\gamma##2## m ##2##\vec v## *##\vec v##
where the ##\vec v## *##\vec v## can be written as the [##\vec v##][##\vec v##]cos(θ)
P2 = (##\gamma mc## )2 - ##\gamma##2## m ##2##\vec v## *##\vec v##
or
P2 = (##\gamma mc## )2 - ##\gamma##2## m ##2[##\vec v##][##\vec v##]cos(θ)
im guessing as the the two four vectors are in the same direction the angle is zero the cos(θ) is then 1 simply so i don't simply get an answer of (##\gamma mc## )2
that was my question how did they arrive at the answer of (##\gamma mc## )2.
bonbon22 said:
im guessing as the the two four vectors are in the same direction the angle is zero the cos(θ) is then 1 simply so i don't simply get an answer of (γmc\gamma mc )2
that was my question how did they arrive at the answer of (γmc\gamma mc )2.
You are correct that the ##\theta## is the angle between the vectors, and the angle between a vector and itself is, indeed, zero.
I'm not sure what you are expecting to be equal to ##(\gamma mc) ^2##. The modulus of the four momentum is just ##(mc) ^2##. The modulus of the four momentum (and any four vector) is invariant, and cannot depend on a frame-dependent quantity like ##\gamma##.
or
Remember that ##\gamma^2 = \frac{1}{1- v^2/c^2}##.
Or, sometimes more useful is:
##\frac{1}{\gamma^2} = 1 - v^2/c^2##
i see, but how does that link in with the problem?
It simplifies the expression to ##m^2 c^2##, which is the correct result.
I see, i understand so in this case do we just ignore the gamma factor? Can we only ignore this factor when gamma is equal to 1 for that to be true wouldn't the velocity be equal to C?
No. But cos(0)=1.
##\gamma = 1## when ##v = 0##.
No one is ignoring the gamma factor. Have you heard of algebra or the concept of simplifying an expression?
What level of mathematics have you studied?
No. You wrote:
(incidentally, the * should be a dot) and we've just agreed that this is ##(\gamma mc)^2-\gamma^2 m^2v^2## because the dot product of a 3-vector with itself is just its length squared. Getting to the correct result is just algebra from here (hint: ##\gamma=1/\sqrt{1-v^2/c^2}=c/\sqrt{c^2-v^2}##). As @PeroK asks, how much algebra do you know?
Why are you tryn diss me mate you feelin alright. I understand the expression but why would you write v=o when you square a four momentum. If you read my post you would know what level I am studying at.
You wouldn't. Nobody is doing this, as has been noted several times.
As has also been said a couple of times, all you need to do is work through the algebra and you will find the answer you are expecting. How far have you got with this?
I just realized my mistake apologies, for making v = to c and actually solving the problem cheers you two. @Ibix @PeroK
...um, you don't need to make ##v## equal to ##c##. The ##\gamma## drops out for any ##v##.
no i understand that replying to what @PeroK said i wrongly made v = to c to make gamma = to 1 by mistake. Wait why does it drop out for any v.
Based on what you've learned in this thread, why don't you post what you have so far? I don't think it's clear to any of us here what you're getting stuck on.
  • · Replies 38 ·
  • · Replies 16 ·
