Function Template: Solve Complications with Mixing Types for Variable Swapping
  • Thread starter Thread starter yungman
    Function
The discussion focuses on the challenges of using C++ templates for swapping variables of different types, specifically between an integer and a double. The original attempt to use a single template parameter for the swap function fails due to type incompatibility when passing by reference. A solution is proposed using two template parameters, allowing for the swapping of variables of different types while maintaining type safety. The conversation also references examples from Ivor's book and highlights the importance of understanding template functions in C++.
  • Understanding of C++ templates and their syntax
  • Knowledge of variable types in C++ (e.g., int, double)
  • Familiarity with function overloading and passing by reference
  • Basic understanding of type casting in C++
  • Research "C++ template specialization" for advanced template usage
  • Learn about "C++ type traits" to understand type properties at compile time
  • Explore "C++ function overloading" to handle multiple types effectively
  • Study "C++ standard library algorithms" that utilize templates for generic programming
C++ developers, software engineers working with templates, and anyone interested in type-safe programming practices in C++.
  • #31
Mark44 said:
As I'm sure you know, function whose parameters are passed by reference, either as C++ references or as pointers, can modify its actual parameters, as in the following example. Strictly speaking, the function below doesn't return anything, but when it returns a has been increased by 1 and b has been increased by 2.
That's the sense in which @yungman meant that a function could "return" two values.
C++:
void alterTwoVars(int& x, int& y)
    x += 1;
    y += 2;
int main()
    int a = 3, b = 5;
    alterTwoVars(a, b);
Yes, They are passed by reference so it's NOT returning anything.
I have been reading the books over, it is still not clear to me why I cannot have two functions with only one template<class T> declaration. My understanding is when you make this declaration, meaning the function that use T data type becomes a "mold" or blue print of a function. Then in the program, compiler will search the function name ( like swapVars or larger) and instantiate the object accordingly. So why can't I define 2 function with T?
Another question I want to clarify, template ONLY work on function, ADT like struct and class, it is NOT for declaring variable type like what I did T a; to declare a is T type that I can make it int, double, string variable in the program.
Thanks
Technology news on Phys.org
  • #32
pbuk said:
If you want two function templates how many times do you think you would have to use the keyword template? How many times have you used it?
  • #33
I know what you are getting to. As I wrote in the last post, all the books said it's a blue print, none say you can only make one function out of the mold.
  • #34
Do you? You have said that you have understood things in the past but have later demonstrated that you have not. This time, if you want to learn, answer the questions.
Q1. If you want two function templates how many times do you think you would have to use the keyword template?
Q2. How many times are you using the keyword template?
  • #35
I think I get it, let me verify
The function should be written like
C++:
template<class T>  T larger(T &x, T &y){}//in one line because they have to go together
It is deceiving to written like this as it looks like two individual lines:
C++:
template<class T>//not a separate line
T larger(T & x, T &y){}
That I should read it as one line. Am I right? This will make a world of sense, that they both goes together, that you have to write this every time.
That template<class T> is NOT like a general declaration that "you are using template in this program".
  • #36
I am taking the time to help you, take the time to answer my questions.
  • Love
  • #37
I thought I answer, the two lines has to go together, so you have to write template<class T> for every function declaration.
  • #38
I'll make it easier for you, multiple choice:
Q1. If you want two function templates how many times do you think you would have to use the keyword "template"? (a) one (b) two (c) some other number
Q2. How many times are you using the keyword "template"? (a) one (b) two (c) some other number
  • #39
1) If I am correct in post 35, then (a) one for each function, you can have two function and use two.
2) as 1).
  • #40
"one for each function" is not an option. The options are (a) one (b) two (c) some other number.
  • #41
I know what you want me to say, it's one. But I don't know why. I thought this is ok also.
C++:
template<class T> T larger(T &a, T &b){}
template<class T> voide swapVars(T &a, T &b){}
If this is not correct, I am still missing something that I don't understand and I cannot find it in the books.
  • #42
Or I have to do this for two functions
C++:
template<class T1, class T2>
T1 larger(T1 &a, T1 &b){}
void swapVars(T2 &a, T2 &b){}
That I can only use T1 ones and T2 ones?
See, this is what I don't understand why. I don't want to answer by guessing.
  • #43
That is because the problem is not in the books, it is in your head. I can help you solve this but only when you accept that the way to learn is not to present me with what you think you know or what you think you want me to hear, it is simply to answer the question. One letter will do, a, b or c:
If you want two function templates how many times do you think you would have to use the keyword template? (a) one (b) two (c) some other number?
  • #44
It is one.
My question is why?
It is obvious, it's not helping if I have no idea why.
  • Love
  • #45
Please don't make fun of this, I have been struggling on this for a few days and I cannot find the answer. I am stuck.
  • #46
Ok, that is wrong. If you want two function templates you have to use the keyword template twice.
I have quite a lot more to give you here, but here is a start as to why: (taken from http://www.cplusplus.com/doc/oldtutorial/templates/ - I will try and get a more up to date source)
The format for declaring function templates with type parameters is:
C++:
template <class identifier> function_declaration;
or
C++:
template <typename identifier> function_declaration;
So each function declaration requires its own 'template' keyword and a class or typename identifier as appropriate. The class or typename identifier only has a meaning within the function definition with which it is associated (i.e. that is its scope).
  • #47
I have quite a lot more to give you here, but here is a start as to why: (taken from http://www.cplusplus.com/doc/oldtutorial/templates/ - I will try and get a more up to date source)So each function declaration requires its own 'template' keyword and a class or typename identifier as appropriate. The class or typename identifier only has a meaning within the function definition with which it is associated (i.e. that is its scope).
Thanks, I have to spend some time reading it. I'll be back.
Thanks
  • #48
No, don't go away! I'll help you go through it: let's stick with that guide.
  • #49
So we have read that a function template has three parts:
  1. the template keyword
  2. a declaration in the form <class identifier> or <typename identifier> (it goes on to say that it doesn't matter which form you use but the examples use <class> so we will stick with that for the time being)
  3. a function_declaration
It then gives an example:
C++:
template <class myType>
myType GetMax (myType a, myType b) {
  return (a>b?a:b);
  • #50
You can see that the example has been split over 4 lines; it could just as easily have been written
C++:
template <class myType> myType GetMax (myType a, myType b) { return (a > b ? a : b); }
or
C++:
template
  <class myType>
or even
C++:
template
  <class
    myType>
  myType
    GetMax (
      myType
        a,   // a is the first argument
      myType
        b    // b is the second
      return
          a > /* that sign means greater than */ b
          ? a
          : b
  • #51
The third example would be ridiculous of course, I only wrote it to demonstrate that in c++ the amount of whitespace (i.e. spaces, tabs and new lines) separating symbols doesn't matter - pretty much anywhere we can put a space, we can start a new line, and anywhere we have a new line we can replace it with a space.
The important exceptions to this are compiler directives, which are not actually part of c++ itself, and these always start with # as the first character of a new line, and in // style comments which are terminated by the first following newline.
So to summarise, it doesn't matter how you lay out the template function declaration, it must always consist of exactly 3 parts separated by whitespace:
C++:
// or
We can of course have as many template function definitions as we like: each one must start with the template keyword, followed by a class or typename identifier, followed by a function declaration.
  • #52
Hi Pbuk
Thanks for all the info, I have been out and busy the whole day, this is the first change I even get to print it out and read it. I'll read your posts and I'll be back tomorrow.
Thanks so much. Sorry I did not come back sooner.
  • #53
Thank you so much Pbuk. I got it. You verify that my guess in post 35 is correct. Finally it makes sense that template<class T> has to go together with the function. This is what I missed before. I actually made this program with the modification and it works:
C++:
#include <iostream>
using namespace std;
template<class T>  void swapVars(T &var1, T &var2)
{    T temp;
    temp = var1;
    var1 = var2;
    var2 = temp;
template<class T> T larger(T var3, T var4)
    if (var3 > var4) return var3;
    else if (var4 > var3)return var4;
    return var3;
int main()
    int a=4,b=1;//test T as int
    count<<" larger of big and small is: "<<larger(a, b)<<endl;
    double c = 2.1, d = 3.5;//testing T is double
    swapVars(c, d);
    count << " After swapping " << c << ", " << d << endl;
    return 0;
I like to write template<class T> void swapVars(T &var1, T &var2) in one line to remind me they have to go together. I even made the two function templates so one work on int and the other work on double to proof I can use template<class T> and don't have to make it template<class T1, class T2> to accommodate two functions.
Finally, you wrote return (a>b?a:b). What do you call this form: (a>b?a:b)? I would have to write in long form:
C++:
if(a>b) return a;
else return b;
I want to learn how to write in this form, I don't even know what you call that so I can't even search online.
Thanks so much.
  • #54
  • #55
In this case I think I agree with you - it is clearer and it doesn't make the line too long.
  • #56
Thanks so my Pbuk, now I have no issue working through template so far.
But I have questions on the "short" form of writing statements like the a>b ? a:b type. seems like there is a new way of writing program from what I learn in the old Gaddis book. I don't even know what you call these. Last time when I asked you, that turn out to be a very specific if else statement, but there are a lot more like the example below. What do you call those simplified statement. I need to learn this.
Below are a few examples I have no idea where they come from. I put the questions in the comments:
C++:
#include<iostream>
#include<vector>
template<typename T1, typename T2>
? ? ? larger(T1 a, T2 b)// what is ?
    return a > b ? a : b;
auto larger(T1 a, T2 b)// what is auto
template<type T> T larger(const vector<T>& data)
    T result{ data[0] }; //why not T result = data[0]?
    for(auto& value : data)//what is this?
        if (value > result)result = value;
    return result;
Note that it's not the template that I have question, it's the short form statement that I don't get.
I want to get the name of this short form so I can look up and learn. Without the name, I don't even know what to look.
Thanks so much for helping.
  • #57
The <condition> ? <expression> : <expression> form is called a ternery condition, or look up ternery operator. Auto means it doesn't check the type that is returned from the function (note that if a > b then a will be returned which has type T1 otherwise b will be returned which has type T2).
That's two for you to get started on.
  • #58
As pbuk already noted, this is the conditional operator, also called the ternary operator because it has three operands. This operator has been present in C from the beginning, and was inherited by C++. It's also present in Java, C#, Python, Perl, and probably a few others.
The expression a > b ? exp1 : exp2 consists of three parts:
  1. The first part (a > b above) is a Boolean expression, one that evaluates to true or false.
  2. The second part (exp1).
  3. The third part (exp2).
If the Boolean expression is true, the conditional expression evaluates to exp1.
If the Boolean expression is false, the conditional expression evaluates to exp2.
C++:
int pets = 2;
std::count << "I have " << pets << " pet" << (pets > 1 ? 's' : '\0') << std::endl;
If pets is 1, the conditional expression evaluates to the null character, and the output will be "I have 1 pet". If pets is 2, conditional expression evaluates to the character literal 's', and the output will be "I have 2 pets", and similar for other integers larger than 1. Additional logic would be needed if pets is 0 or negative.
The Gaddis book, "Starting out with C++, from Control Structures through Objects," 6th Ed, shows the conditional operator on the 2nd page of the book, and in section 4.14, starting on page 218.
  • #59
C++:
int pets = 2;
Yes, I understand that already, it's the other news ones in my post.
Thank
  • #60
Maybe it's some of these:
C++:
I don't think this is meant to be actual code. As far as I can tell, the ? is just a placeholder for some type.
C++:
This is actual code. @pbuk explained what the keyword auto means here.
C++:
    return result;
T result{ data[0]}; has the same effect as T result = data[0];
The intent is to initialize result to the value in data[0].
This type of for loop is something fairly new in C++, possibly introduced in C++11, but I'm not certain of that. It's called a range-based for loop. Here's more information - Range-based for Statement (C++) | Microsoft Docs
  • · Replies 19 ·
  • · Replies 39 ·
  • · Replies 89 ·
  • · Replies 35 ·
