Question on the trace of two matrices
  • Thread starter Thread starter evlyn
    Matrices Trace
The discussion centers on understanding how the properties of two matrices A and B, specifically their anticommutation (AB = -BA) and the fact that A^2 = I and B^2 = I, relate to finding their traces. It is established that if A and B are n x n matrices, their eigenvalues must be either +1 or -1, leading to the conclusion that their traces, which are the sums of eigenvalues, must equal each other and can be zero. The minimal polynomial is mentioned as a potential tool for further analysis, although its relevance to the problem at hand is debated. The conversation also touches on the implications of matrix size, suggesting that the analysis may be simpler for 2x2 matrices. Ultimately, the key takeaway is that understanding the eigenvalues and their implications is crucial for determining the traces of A and B.
evlyn
How does knowing that two matrices anticommute AB=-BA and that A^2=1 and B^2=1 help me to know how to find the trace of the matrices. I am supposed to show that their traces equal each other which equals 0 but I am not sure exactly how the given information helps me determine the trace?
do you mean A^2 = I?
In general, trace(AB) = trace(BA). Hence from the given relation trace(AB) should be zero as +0 = -0.
or do you mean trace(A) = trace(B) = 0?
and the problem said A^2 =1
What size are the matrices?
I can think of two ways to approach this problem:
1. Assume the matrices are in upper-triangular form (this is always possible), and see what you can conclude about the diagonal elements, or
2. Write out the invariant formula for the characteristic polynomial. The characteristic polynomial can always be written in terms of tr A, det A, and tr A^k for k up to n-1 (for an n x n matrix).
If the matrices are 2x2, then the second method will be very easy. I'm not sure if what you're trying to prove is necessarily true if the matrices are larger.
I don't know what size the matrices are I just know that they are two matrices A and B. I guess I'm still not understanding the connection of the trace to anticommuting and to the squares
(a+ b)^2= a^2+ ab+ ba+ b^2= 2i
(Why are my capital letters always turned into lower case?)
Does i here refer to I (the identity matrix)?
Maybe I'm being really dumb but where does that come from? Is it finding the eigenvalues of (a+b)^2
Welcome to PF, evlyn! :smile:
Yes, as HoI said, his text was turned into lower case.
It should be:
(A + B)^2= A^2+ AB+ BA+ B^2= 2I
However, aside from the fact that it is a true statement, I do not know what he intended with it.
As for your problem, if you look up "Minimal polynomial" (as Ben Niehoff suggested), you'll find that the minimal polynomial of A is a polynomial divisor of (A2 - I), due to the fact that A2 = I.
In effect this means that the only eigenvalues A can have (and also B), are the roots of x2 - 1 = 0.
That is, -1 and +1.
Therefore the trace of A (and also of B) is the sum of n values of either -1 or +1.
Furthermore, for a nxn matrix, the characteristic polynomial is x^n - tr(A) x^{n-1} + ... + (-1)^n \det(A).
In particular, for a 2x2 matrix, you can read off the trace and determinant of A from this.
I don't understand how the minimal polynomial is helpful if I just have a general matrix A? I don't no anything about it except that AB = -BA and that A^2=1 and B^2=1
Well, first off, I interpret your equation as A^2=I.
From just that equation you can draw a number of conclusions about A.
Let me enumerate them for you:
1. A is a square nxn matrix (otherwise you could not multiply it with itself).
2. A is its own inverse, that is, A = A^-1.
3. More specifically: A is invertible.
4. det(A^2)=1, implying det(A)=+1 or det(A)=-1.
Now the minimal polynomial is helpful, since it tells us that:
5. A has n eigenvalues, each of which must either be +1 or -1.Can you tell what the dimensions of B must be?Btw, I get the impression that the minimal polynomial is outside of the scope of your current class material.
Is it?
Perhaps we should zoom in on 2x2 matrices and leave the minimal polynomial out of it...
And anyway, I'm not even sure myself if your statement holds true for matrices larger than 2x2.
the dimensions of B must be the same as A
Is it?
It is most likely assumed that the general population in my class knows what the minimal polynomial is
Yep!
So A and B must both be nxn matrices.
Probably not! :wink:
It is advanced material in linear algebra.
Let's suppose that A = \begin{pmatrix} a & b \\ c & d \end{pmatrix}.
Do you know what the determinant is?
What the trace is?
And what the characteristic polynomial is?
What the trace is?
The determinant would be ad-bc
the trace would be a+d
and the characteristic polynomial I am not entirely sure about ... (t-a)(t-d)-bc ...
t^2-at-td+ab-bc
t^2-at-td+ab-bc
Good! :)
Do you know what the characteristic polynomial represents? What it is used for?
It is used to find the eigenvalues of the matrix
So what are you unsure about?
  • · Replies 26 ·
