Calculating Maximum Height of a Mass on a Rotating Wheel | Physics Question
  • Thread starter Thread starter lefthand
To determine the maximum height a mass will rise above point P on a rotating wheel, the conservation of energy principle is applicable. The formula used, 1/2mv^2 + 1/2lw^2 = mgh, is correct, but attention must be paid to the moment of inertia (I) calculation. It's crucial to ensure that the mass of the wheel is used correctly and to identify whether the wheel is a solid disk or has most of its mass in the rim, as this affects I. Additionally, using the radius instead of the diameter for calculations is essential. If these factors are verified and the issue persists, sharing the detailed work may help identify the error.
lefthand
Suppose the wheel is rotated at a constant rate so that the mass has an upward speed of 4.07 m/s when it reaches a point P. At that moment, the wheel is released to rotate on its own. It starts slowing down and eventually reverses its direction due to the downward tension of the cord. What is the maximum height, h, the mass will rise above the point P?
h =m
my question is what formula should i use? I've been using 1/2mv^2+1/2lw^2=mgh...but i haven't been getting the right answer...if anyone knows has a hint that would help i would like to use it :)
It appears that you are using the correct formula (conservation of energy), though without seeing the figure or your actual work I cannot be 100% sure. Here are a few things that you might check:
1. When you calculate I, do you use the mass of the wheel -- and not the rising mass?
2. Is the wheel like a solid disk, or is most of its mass in the rim? That will affect what I is, in terms of the wheel's mass and radius.
3. Sometimes a problem tells you the diameter of a wheel, and students can mistakenly use that instead of the radius to calculate I, or to relate v and ω to each other.
If you didn't make any of those mistakes I listed, then please post your work.
  • · Replies 17 ·
