Question regarding maximum on a unit disc
9 replies · 5K views
librastar
Find the maximum of |ez| on the closed unit disc.
|ez| is the modulus of ez
z belongs to complex plane
Maximum Madulus Theorem - Let G be a bounded open set in complex plane and suppose f is a continuous function on G closure which is analytic in G. Then max{|f(z)|: z in G closure} = max{|f(z)|: z in boundary of G}
At first glance I was thinking about using Maximum Modulus Theorem by setting f(z) = ez and let G be a open unit disc. Clearly f(z) is analytic in G and is continuous on G closure (the closed unit disc), so I should be able to apply MMT to conclude that the modulus assumes maximum on the boundary.
However I got confused when determining how do I describe |f(z)| on the boundary, in another word, how do I determine what value of z to use?
Please let me know if my approach is right and perhaps give me some advice or hint.
I appreciate all the helps you provide.
as on the boundary |z| = 1, how about starting by writing it in the form z = 1. e^(i theta)
Since z lies on the unit circle, we can write it as: max{|f(z)|: z in boundary of G} = max{|f(z)|: z = exp([tex]i\theta[/tex]), [tex]\theta \in [-\pi,\pi)[/tex]}
However, what do you know about |[tex]e^z[/tex]| when [tex]z = e^{i\theta}[/tex]?
I'm not sure where this is going, in this case we will just have exp(exp([tex]i\theta[/tex]))?
I also know that e^(i[tex]\theta[/tex]) = cos([tex]\theta[/tex]) + i*sin([tex]\theta[/tex]), but I don't know if this will help my solution or not.
It does. Calculate explicitly the modulus of [tex]e^z[/tex] using the identity you provided above for [tex]e^{i\theta}[/tex].
So now I have |ecos([tex]\theta[/tex])+isin([tex]\theta[/tex])|
|ecos([tex]\theta[/tex])*eisin([tex]\theta[/tex])|
= |ecos([tex]\theta[/tex])*(cos(sin([tex]\theta[/tex]))+isin(sin([tex]\theta[/tex])))|
Now I don't know why I got stuck here...
not too sure what you did there in the last step... but you need to remember the complex conjugate in the magnitude... try that before you simplify
[tex]|e^{ cos(\theta)}e^{i sin(\theta)}|^2 = (e^{ cos(\theta)}e^{i sin(\theta)})(e^{ cos(\theta)}e^{i sin(\theta)})^*[/tex]
thanks for the tip.
Well, I know that (ez)* = e[tex]z^*[/tex]
So I can simply [tex]|e^{ cos(\theta)}e^{i sin(\theta)}|^2 = (e^{ cos(\theta)}e^{i sin(\theta)})(e^{ cos(\theta)}e^{i sin(\theta)})^*[/tex] to:
[tex](e^{ cos(\theta)}e^{i sin(\theta)})(e^{ cos(\theta)}e^{-i sin(\theta)})[/tex]
Then by combing the exponential functions with the same exponent, then I obtain:
[tex](e^{ 2cos(\theta)})[/tex]
So after taking the square root of the whole thing,
[tex]|e^z| = e^ { cos(\theta)}[/tex]
The max value of [tex]cos(\theta)[/tex] = 1
So the maximum of [tex]|e^z| = e[/tex]?
lanedance said:
that looks good to me
Thanks.
