Question with acceleration vector
9 replies · 2K views
goonking
http://imgur.com/LravIr3
We know A is wrong, because a object going in a circle has acceleration (i'm not sure why that is, maybe someone can explain)
B is wrong because if a car in reverse is slowing down, it technically has positive acceleration, right?
D is wrong because refer to my explanation for B.
C and E, I have no idea what that formula is but V x T is distance but I have no idea what the formulas are implying. Anyone can shed some light on what C and E means?
The formula ##v(T + Δ T) ## refers to the velocity of the object at time## (T +Δ T)##.
Now can you decide if C and E are right or wrong?
how does velocity multiplying the time give you velocity again?
Its not multiplication, It's a way of representing the velocity at a particular time, as the velocity varies with time!
can you make up a word problem that uses v(T+ΔT)?
Okay instead of a word problem with ##V(T+ΔT)## try this.
Let ##~~ V(t) = ƒ(t)## and ##ƒ(t) = u(0) + at ##
here i used ## u(0)## itts actually ##u(t=0)## we often miss out the ##t=##
so in your question it should have been- ## v(t_2 = T+ΔT)## and ##v(t_1 = T)##
we often omit the t= to make things easier,
Its represented like this because velocity is not a constant and is a function of time, skips the steps you'd have to involve to define ##v_1 ~ and~ v_2##
its just like writing ##V(initial) and V(final)##
see this
answer (D) seems true
EDIT: (D) is not always true
Where the acceleration of a body is known to be constant, we can determine that acceleration by making two measurements of its velocity some time apart, then using the formula;
a = Δv / Δt
= ( v(T+ΔT) - v(T) ) / ΔT
if I'm in a car, and I'm in reverse while increasing my speed. I'm accelerating while going backwards so my acceleration is negative. I then slow down a bit while reversing but I'm still moving backwards, my acceleration is now positive even though I'm still moving backwards. It is positive because I slowed down in reverse. How can D still be true?
You are right. I was not correct because in that case (D) is not true. I'll amend my earlier post. Thanks for the correction.
