Question with gravity, speed, heights
  • Thread starter Thread starter ital_dj
    Gravity Speed
The discussion revolves around solving physics problems related to projectile motion, specifically concerning a 60g pebble fired at 35m/s. The maximum height reached by the pebble when fired straight up is calculated using the equation h = v12 / (2g), resulting in a height of 61.25 meters. Additionally, the discussion touches on the kinetic energy equation (KE = 1/2 mv2) and gravitational potential energy (Eg = mgΔh) to derive the necessary relationships for solving the problems presented. The participant also inquires about the derivation of these equations and their application in the context of the problems.
  • Understanding of basic physics concepts: kinetic energy and gravitational potential energy
  • Familiarity with projectile motion equations
  • Knowledge of the conservation of energy principle
  • Ability to manipulate algebraic equations
  • Study the derivation of the kinetic energy equation (KE = 1/2 mv2)
  • Learn about gravitational potential energy and its applications in projectile motion
  • Explore the conservation of energy in the context of vertical motion
  • Practice solving additional projectile motion problems using different initial velocities
Students studying physics, educators teaching projectile motion concepts, and anyone seeking to understand the principles of energy conservation in motion.
ital_dj
[SOLVED] question with gravity, speed, heights
a boy fires a 60g pebble with his slingshot. the pebble leaves the slingshot at 35m/s.
a) how high above the slingshot will the pebble rise if it is fired straight up?
b) if the pebble is fired so that it goes in an arc and has a speed of 10m/s at its maximum height, what will the maximum height be?
c) at what speed would an 80g pebble have to be fired to reach the same height as the pebble in (a)? Assume that the 80g pebble is also fired straight up.
I'm just going to guess some relevant equations, because I'm so lost.
d = vt
F = mg
Eg = mg\Deltah
I tried basic multiplication, division, and other stuff... couldn't figure it out
You're help is greatly appreciated. Thanks a lot
EDIT: I just looked at the teacher's solution that she wrote, and it was mgh = \frac{mv_{1}^{2}}{2}, but how did she arrive at that? Thanks
Also, from that equation it gets narrowed down to h = \frac{v_1^2}{2g}
are you sure you copied the solution correctly? remember that when the pebble is shot straight up and reaches its maximum height that 100% of its kinetic energy will have been converted into gravitational potential energy.
Sorry, you're right... it should be divided by 2... I'll fix it right now. But, with the correct solution now, how did she arrive at that?
what is the equation for kinetic energy? what is the equation for gravitational potential energy?
Kinetic Energy = 1/2mv^2
Gravitational Energy (Eg) = mg\Deltah
i guess max height which is required in prblm (a) = u^2/2g
u = initial velocity = 35
so max height = 61.25 m i think we don't need mass here o.O I'm confused too...
11K
  • · Replies 30 ·
