A Questions about changing frame in QM and rotating wave approximation
  • A
  • Thread starter Thread starter Malamala
    Electric field
Malamala
Hello! I have a 3 level system with energies ##E_0##, ##E_1## and ##E_2## and 2 time varying electric fields, the first one connects ##E_0## and ##E_1## while the second one connects ##E_0## and ##E_2## with Rabi frequencies ##\Omega_1## and ##\Omega_2## and the frequencies of the electric fields are ##\omega_1## and ##\omega_2## such that ##|E_0-E_1-\omega_1|<<|E_0-E_1|## and ##|E_0-E_2-\omega_2|<<|E_0-E_2|##. So my Hamiltonian looks like:
\begin{pmatrix}
E_0 & \Omega_1\cos\omega_1 t & \Omega_2\cos\omega_2 t\\
\Omega_1\cos\omega_1 t & E_1 & 0\\
\Omega_2\cos\omega_2 t t & 0 & E_2
\end{pmatrix}
If I had only ##E_0##, ##E_1##, I would use this matrix:
U = \begin{pmatrix}
1 & 0\\
0 & e^{i\omega_1 t}
\end{pmatrix}
to go in a frame rotating with the electric field and remove all the explicit time dependence from the problem. But I am not sure what to do for a 3 level system (i.e. can I remove all the time dependence?). In principle I can use this for a 3 level system:
U = \begin{pmatrix}
1 & 0 & 0\\
0 & e^{i\omega_1 t} & 0\\
0 & 0 & e^{i\omega_2 t}
\end{pmatrix}
which would give a time-independent Hamitlonian (and that is a valid unitary transformation), but I am not sure this is ok physically. Basically, if I use this, the 2 different excited states seem to be in different rotating frames, which is confusing to me. What is the right way to proceed? Can I actually go to a time independent frame that makes physical sense?
Let us choose an operator
U(t) = \begin{pmatrix}
1 & 0 & 0 \\
0 & e^{i\omega t} & 0 \\
0 & 0 & e^{i\omega t}
\end{pmatrix}
where
\omega = \frac{\omega_1 + \omega_2}{2}.
Transform the state vector as
|\tilde{\psi}(t)\rangle = U^\dagger(t)|\psi(t)\rangle
and the Hamiltonian as
\tilde{H}(t) = U^\dagger(t)H(t)U(t) - iU^\dagger(t)\frac{dU(t)}{dt}.
The original Hamiltonian is
H(t) = \begin{pmatrix}
E_0 & \Omega_1\cos(\omega_1 t) & \Omega_2\cos(\omega_2 t) \\
\Omega_1\cos(\omega_1 t) & E_1 & 0 \\
\Omega_2\cos(\omega_2 t) & 0 & E_2
\end{pmatrix}.
First, compute the term
Since
\frac{dU(t)}{dt} = \begin{pmatrix}
0 & 0 & 0 \\
0 & i\omega e^{i\omega t} & 0 \\
0 & 0 & i\omega e^{i\omega t}
\end{pmatrix},
we obtain
iU^\dagger(t)\frac{dU(t)}{dt} = \begin{pmatrix}
0 & 0 & 0 \\
0 & -\omega & 0 \\
0 & 0 & -\omega
\end{pmatrix}.
Next,
amounts to multiplying the off-diagonal driving terms by exponentials of $\pm i\omega t$. Thus,
U^\dagger(t)H(t)U(t) = \begin{pmatrix}
E_0 & \Omega_1\cos(\omega_1 t)e^{-i\omega t} & \Omega_2\cos(\omega_2 t)e^{-i\omega t} \\
\Omega_1\cos(\omega_1 t)e^{i\omega t} & E_1 & 0 \\
\Omega_2\cos(\omega_2 t)e^{i\omega t} & 0 & E_2
\end{pmatrix}.
Therefore, the transformed Hamiltonian becomes
\tilde{H}(t) = \begin{pmatrix}
\Omega_1\cos(\omega_1 t)e^{i\omega t} & E_1 - \omega & 0 \\
\Omega_2\cos(\omega_2 t)e^{i\omega t} & 0 & E_2 - \omega
\end{pmatrix}.
This single rotating frame captures part of the oscillatory phase of both fields without forcing each excited state into a separate rotating frame, leaving behind only the differences
\omega_1 - \omega
and
\omega_2 - \omega
in the exponentials when we use
\cos(\omega_1 t)e^{-i\omega t} = \frac{1}{2}\left(e^{i(\omega_1-\omega)t} + e^{-i(\omega_1+\omega)t}\right)
(and similarly for $\omega_2$). We may then invoke a two-frequency rotating-wave-like approximation if $\omega_1 \approx E_1 - E_0$, $\omega_2 \approx E_2 - E_0$, and $\omega$ is chosen to capture the main portion of both transitions, leaving smaller detunings
\Delta_1 = \omega_1 - \omega
and
\Delta_2 = \omega_2 - \omega.
If $\Delta_1$ and $\Delta_2$ are not too large, the rapidly oscillating counter-rotating terms can be truncated, yielding an effectively time-independent or slowly varying block of the Hamiltonian. The procedure is mathematically rigorous because it uses a globally well-defined unitary transformation of the Hilbert space and allows us to keep a single frame for all excited states while still systematically treating any leftover time dependence via perturbation expansions or by focusing on the resonant (slow) components of the dynamics. Physically, it can be viewed as “splitting the difference” between the two fields, thereby simplifying the system without introducing separate rotating frames for each excited state. This resolves the confusion of placing each level in a different frame, and in the regime of near resonance, we can reduce the problem to a slowly varying effective Hamiltonian that accurately reproduces Rabi oscillations for both transitions.
thomsj4 said:
...leaving smaller detunings
and
If ...
Asking @thomsj4 for a personal favor: could you dramatically reduce your use of carriage returns so I don't have to wade through vast empty spaces (and risk snow blindness :wink: )?
Try this for example:
"...leaving smaller detunings$$\Delta_1 = \omega_1 - \omega$$and$$\Delta_2 = \omega_2 - \omega.$$If ..."
which renders as:
Or better yet: put small, unnumbered equations like those above inline:
"...leaving smaller detunings ##\Delta_1 = \omega_1 - \omega## and ##\Delta_2 = \omega_2 - \omega.## If ..."
giving:
Much more readable.
Thanks!
1 & 0 & 0 \\
\end{pmatrix}
where
\end{pmatrix}.
Since
0 & 0 & 0 \\
\end{pmatrix},
we obtain
0 & 0 & 0 \\
0 & -\omega & 0 \\
0 & 0 & -\omega
\end{pmatrix}.
Next,
\end{pmatrix}.
\end{pmatrix}.
\omega_1 - \omega
and
\omega_2 - \omega
and
Thank you for this, it all makes sense. However, I am not sure how to get rid of ##\Delta_1## and ##\Delta_2##. For example, I have ##\Delta_1 = \frac{\omega_1-\omega_2}{2} = \frac{E_1-E_2}{2}## assuming the 2 lasers are on resonance. But there is no relationship between ##E_1## and ##E_2## i.e. ##E_1-E_2## can be arbitrarily large or small and I am not sure what to do with this term in general.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
