Questions About LFTR - Uranium 233 & Gamma Rays
  • Thread starter Thread starter Nerdydude101
The discussion revolves around the use of uranium-233 (U-233) in Liquid Fluoride Thorium Reactors (LFTRs), specifically addressing its production, associated gamma radiation, and safety concerns compared to conventional nuclear reactors. Participants explore theoretical and practical aspects of LFTR designs, including the implications of U-232 contamination and the challenges of handling radioactive materials.
  • Some participants note that LFTRs convert thorium-232 into fissile U-233, but there is uncertainty about whether U-233 is used in all LFTR designs.
  • It is mentioned that U-232, a byproduct of U-233 decay, is a strong gamma emitter, which raises questions about the radiation safety of LFTRs.
  • Concerns are raised regarding the proliferation resistance of U-233 due to the difficulty of separating it from U-232 and the hazards associated with handling these materials.
  • Participants discuss the half-life of proactinium-233, a precursor to U-233, and the challenges of separating it from irradiated thorium to produce U-233.
  • Some argue that LFTRs may be safer than conventional reactors, while others question this claim due to the presence of gamma radiation and the engineering challenges involved.
  • There are differing views on the feasibility of separating U-233 from U-232 and the implications of gamma radiation for reactor safety.
  • Participants express skepticism about the accuracy of external resources, such as videos, that simplify the complexities of LFTR technology.
Participants express a range of views on the use of U-233 in LFTRs, the implications of gamma radiation, and the safety of LFTRs compared to traditional reactors. There is no consensus on the safety claims or the technical challenges presented.
Participants highlight limitations in understanding the separation processes for U-233 and U-232, the implications of gamma radiation, and the engineering requirements for LFTRs. The discussion reflects ongoing uncertainties regarding the practical application of LFTR technology.
Nerdydude101
So I have been reading about LFTR and I understand the concepts but there are a few things I have questions about, mainly it's possible use of uranium 233. Some articles I have read and diagrams I have seen make mentions if using uranium, however other articles and diagrams make no mention of uranium at all, so is it used in a lftr or maybe just in some lftr designs? If it is used then how is it used and how is it prevented from emitting gamma rays because from what I understand a lftr only emits alpha radiation. Thanks for any help you can give!
A LFTR converts fertile Th-232 into fissile U-233. This reactor will emit gamma because of U-232 poisoning of the U-233. U-232 is a very strong gamma emitter that is generated as a small fraction of that decay chain. The articles you read that claim that LFTR reactors are proliferation resistant, that resistance is because of the U-232. The U-232 is very hard to separate from the U-233 and handling it tends to kill people. And also a portion of that proliferation resistance is probably because U-233 is prone to spontaneously exploding when it is fashioned into a fission bomb.
The half-life of the U-233 precursor, proactinium-233, is 27 days. You could chemically separate protactinium from irradiated thorium to produce pure U-233.
I've never heard this before. The SF rate of U-233 is lower than U-235 (and much lower than Pu-239) so why is this so?
Thorium is not fuel, only breeder material. LFTR's convert thorium into U-233 to produce energy. They require an initial loading of U-233, U-235, or Pu-239 in order to begin the breeding process. All nuclear reactor types and fuel cycles will produce gamma radiation from irradiated impurities and fission products.
So is it also not true that they are safer that a common nuclear reactor? I had heard that they were safe to be built in a higher density population area but if they met gamma rays then that wouldn't be true, also is this video inaccurate then?
https://m.youtube.com/watch?v=nYxlpeJEKmw
The video is simplistic and misleading. It does not address the various engineering/technical challenges associated with a LFTR system.
It is the engineering that determines and assures safety.
Any fission system inherently produces fission products which are beta and gamma emitters. The fission products would have to be separated and processed, then ultimately deposited somewhere isolated from the environment. Each LFTR plant requires a processing system to extract/separate U-233 and recirculate it into the reactor system. At startup, a fissile inventory (U-235 or Pu-239) is required.
The plant efficiency will be determined by the peak temperature of the working fluid, and as temperature increases materials are challenged. It may be possible to use a Brayton cycle for power generation, otherwise, a steam Rankine cycle would be employed. Steam cycles introduce corrosion and erosion issues associated with the water interaction with the structural alloys.
Agreed w one exception. If a molten salt reactor design must fall back to a Rankine cycle, steam will be obtained via heat exchangers. The reactor vessel itself and fission products will always be at a couple atm at most. An MSR is not a PWR.
Yes but that's not the problem the problem is separating the resulting U-233 and U-232. It requires the same equipment as separating U-235 and U-238. In addition it is far more radioactive than natural uranium.
Sorry I was incorrect as to the requirements for premature destination. The main proliferation negator is the gamma emission. See the response on this article http://www.americanscientist.org/issues/pub/2010/5/a-thorium-future
The gamma can be stopped by materials such as lead or depleted uranium. What makes them safe for high density population centers is the salt plug that holds the fuel in. If the fuel gets to hot the salt plug melts draining the fuel into a separate area separating it from the external neutron source.
No, U-232 is generated by neutron absorption in the reactor. If you chemically separate the proactinium outside of the reactor and wait for it to decay to U-233 there will be no U-232 contamination.
It's difficult to compare the safeness of a hypothetical reactor design to real world power plants. While LFTR's have some potential advantages, there are also challenges, both known and unknown, which have to be analyzed. An LFTR would certainly still require a containment building.
Ok true however you still encounter the same problems with getting the proactinium out as you do the U-233. The U-232 would irradiate everything in the vicinity until the proactinium was separated out. Also due to the short half life of proactinium I doubt there would be enough at anyone time to generate a usefull amount of U-233 outside the reactor. You would have to break open the reactor multiple times and separate out proactinium each time.
The half life of proactinium-233 is 27 days which is plenty to reprocess. Chemically separating protactinium from the fuel is not very complicated. And since we are referring to a LFTR, it would be easy to get out since the fuel is already liquid and presumably reprocessing equipment is already part of the plant design. Additionally, the process can be made more efficient by having external breeding blankets.
Ok just focusing on the separation part of it though. You would need a remote handling facility due to the high radioactivity of the U-232. Anybody who had that kind of facility would have been better off building an enrichment facility for natural uranium. They would get a higher yield bomb without attracting unwanted attention by pilfering a LFTR for its proactinium.
But the point of a nuclear reactor is to generate energy, nt to create bombs, well I mean the government doesn't see it that way but if you exclude the bomb making would lftr be more efficient?
That really depends on the design of the LFTR itself.
Well no. By design, LFTR's use liquid fuel which is re-processed on site. This is completely different from enriching natural uranium, which requires extensive facilities and specialized equipment. It would not be hard to add capability for U-233 breeding and separation. The operation would be similar to that of plutonium production. The advantage of plutonium breeding vs. thorium is that plutonium breeding does not require high enriched fuel to seed the breeder, and the physics of Pu-based bombs is much more well tested and understood.
More efficient in what sense? Cost? Fuel efficiency? Thermodynamic efficiency?
QuantumPion said:
...The advantage of plutonium breeding vs. thorium is that plutonium breeding does not require high enriched fuel to seed the breeder, and the physics of Pu-based bombs is much more well tested and understood.
I don't believe the seed need be HEU, but only enriched sufficiently to sustain a reaction for some time.
It's ability to convert the fuel into energy, we convert almost none of uranium into energy, but from what I've read we can convert a large amount if the thorium into energy but from what people on this post have said I'm starting to doubt everything I've read haha.
Ok we'll then were getting into a nation state level endeavor. I've been approaching this in regard to what prevents an individual or small group from getting the U-233.
Yes, but during the Manhattan project they had no source of fissile material to start with, so it was easier to go the plutonium route and there was little incentive to later switch over to thorium.
Well that part is true. Any breeder reactor will be far more fuel efficient than a standard fuel cycle, and any reactor design that includes on-site reprocessing will have reduced or even eliminated spent fuel disposal issues.
The point was that there's no proliferation risk due to the seed required for a LFTR startup
As QuantumPion indicated it is important to clearly define what type of efficiency one is considering, e.g., thermodynamic efficiency, or fuel utilization, i.e., burnup (energy per mass of fuel).
In a conventional LWR, about 4.5% to 5.5% of the U is converted into energy. It could be greater if certain design, reliability and safety requirements could be met (but that's a different topic). One of the constraints on LWR fuel is the accumulation of fission products and transuranics (TU) and the impact on fuel reliability and safety (e.g., solid and gaseous swelling of the fuel, and rod internal pressure, and how that affects the requirements of fuel/core coolability and reactivity control (i.e., ability to reliably shutdown reactor in response to various AOOs and postulated accidents)).
In an LWR, fuel may be used for two or three cycles, with each cycle being typically 18 to 24 months (in the US and parts of Europe). Each batch of fuel removed is on the order of 34% to 50% of the core. The oldest fuel is removed, and fresh fuel is added. The oldest fuel contains the fission products and TU accumulated from the two or three cycles of operation.
The benefit of the LFTR is that fission products are removed and the Th-based fuel cycle does not accumulate as much TU as does the U-based fuel cycle. However, the LFTR system does require a reprocessing system that will accumulate the U-233, recycle the Th-232, and accumulate the fission products that then have to be fabricated into a safe form (typically encapsulated ceramic). The waste forms then have to be cooled.
Thermodynamic efficiency is also factor. LWRs have a range of thermodynamic efficiencies from ~32% to ~38%, while some gas-cooled reactors have expected efficiencies of ~42%. That also improves the MWh/MTHM. While it might be possible to have comparable thermodynamic efficiency with an LFTR, one must realize that the reprocessing plant will consume some amount of the electrical energy produced - and each LFTR needs it's dedicated reprocessing plant (and waste storage).
It may be desirable to have modular LFTR units with a common reprocessing plant, and then one has to decide if the LFTR units are moderate in size (e.g., 200-300 MWe) or larger (1000 - 1500 MWe). The power ratings will determine the size of core, which then determines enrichments.
Not as long as the fissile material (U-235 or Pu-239/241) is diluted in Th-232 or mixed fluoride salt.
Actually they went with reactors that bread plutonium because that also produced materials for bombs. Some of the scientists on the Manhattan project such as Eugene Wigner and Alvin Weinberg actually advocated that the thorium fuel cycle be used.
Or before. There would be no need to ship HEU to the reactor to start it, thus no need to produce HEU.
On the other hand, if one has a mixture of U-235 and Th-232, then somewhere in the process, one has HEU, since low LEU is < 5% U-235 and 95% U-238.
If there is little or no U-238 in the Th-based fuel, then somewhere one has to make HEU (predominantly U-235).
I'm unaware of a reason why some U238 can not be introduced into a LFTR as part of a starter seed of LEU.
  • · Replies 60 ·
9K
