Questions concerning the Church-Turing thesis
  • Level: Graduate
  • Thread starter nomadreid
    Thesis
nomadreid
The differences in the following versions of the Church-Turing thesis
1) any algorithmic process can be simulated on a Turing machine
2) any algorithmic process can be simulated efficiently on a Turing machine
3) any algorithmic process can be simulated efficiently on a probabilistic Turing Machine
evoke the questions:
a) Does version 3 refer to definitive results, or just results with a high probability of being correct?
b) If definitive, then has there yet been found an algorithm which would be able to be simulated on a probabilistic (e.g., quantum) computer that would not be able to be simulated at all (hence referring to version 1, not version 2) on a Turing machine?
c) Finally, are there algorithms which can handle higher-order logics (not just those parts of these logics which are reducible to first-order logic)? If so, does the thesis also refer to them?
Thanks.
The last two are just being specific. Best not to read too much into the specific wording.
eg. A probabilistic Turing machine is a subset of a Turing machine. Some simulations are more efficient than others. (Shouldn't that be "effective" though?)
Unless I have misunderstood...
(a) "any algorithmic process" means: if it can be written down as a series of steps, then it counts.
(b) no. #1 always holds. If it is simulated by a PTM, then any TM can simulate it - the program will be different.
(c) No doubt there are, and the thesis refers to any algorithmic process.
... all subject to restrictions in the same thesis of course.
I have fluffed a bit. See also:
http://www.alanturing.net/turing_archive/pages/reference articles/The Turing-Church Thesis.html
Simon Bridge, thank you for your reply. The reference you gave includes some extremely interesting articles in its bibliography. (Pedantic side note: the bibliography cites some preprints which themselves start off by forbidding anyone from citing the preprint due to its differences to the final published version...and the text cites a reference -- Hogarth -- which does not exist in its bibliography. But, as the famous last line in "Some Like It Hot": "Well, nobody's perfect."). Copeland, especially, makes some interesting distinctions.
By "Turing machine" I meant (mea culpa for not writing it explicitly) "deterministic Turing machine". In that case, a deterministic Turing machine is a subset of probabilistic Turing machines. So, the question becomes
***Can a probabilistic Turing machine do something which a deterministic Turing machine cannot do?
The inspiration for thinking that it might comes from the irreducibility of quantum mechanics to classical physics, that is, killing classical determinism, so I get a gut feeling that a quantum computer (a probabilistic Turing machine) might not be reducible to a classical one, i.e., a deterministic Turing machine. Put another way, perhaps Turing's oracles might come from the real world and hence not reducible to a deterministic TM. But that is only a gut feeling that I am not sure can be justified. Hence my question.
No, "effectively computable" just means algorithmic, so that would have been redundant. Rather, a strong version of the Church-Turing Thesis is using the very strong (and dubious) assumption that any problem solvable on a deterministic TM that requires, say, exponential time on the deterministic TM can be reduced to a problem that requires only polynomial time ("efficient") on a deterministic TM. This is in contrast to version #3, which makes a similar claim but takes away the restriction to deterministic TM's, and which therefore has perhaps a bit more appeal.
In that case, a deterministic Turing machine is a subset of probabilistic Turing machines. So, the question becomes ***Can a probabilistic Turing machine do something which a deterministic Turing machine cannot do?
Oh OK - I'd say "yes" to that - but, like you, do not have an example handy.
Lets see if I can attract someone better versed than me :)
