Questions on electrochemical cells using Zn, Cu
7 replies · 4K views · last reply
Leesy007
The problem
http://www.chem.iastate.edu/group/Greenbowe/sections/projectfolder/animations/CuZncell.html
After veiwing the animation found at the website above answer these questions:
Is there an electron transfer between species?
Which species is losing electrons
Which species is gaining electrons?
Write down the oxidation half reaction under the species that is undergoing oxidation.
Write down the reduction half reaction under the species that is undergoing reduction.
What is the Anode?
What is the Cathode?
Which direction is the spontaneous reaction? Explain your reasoning.
Write the complete balanced equation for the reaction.
2.The attempt at a solution
Is there an electron transfer between species? Yes
Which species is losing electrons? Zinc/Zn
Which species is gaining electrons? Copper/Cu
Write down the oxidation half reaction under the species that is undergoing oxidation. Zn-> Zn 2+
Write down the reduction half reaction under the species that is undergoing reduction. Cu 2+ ->Cu
What is the Anode? Zinc/Zn
What is the Cathode? Copper/Cu
The spontaneous reaction is occurring from the zinc to the copper because the zinc is losing electrons and the copper is gaining electrons.
Zn 2+ + Cu --> Cu 2+ +Zn
Please help me here!
I need someone to check my answers, I'm pretty sure about the first ones, but the last one about the balanced equation I think it wrong.
Any help would be greatly appreciated.
THANKS!
If copper is the species being reduced, how can your reaction be correct?
Zn 2+ + Cu --> Cu 2+ +Zn ?
You will notice that the metallic zinc electrode is being converted to Zn+2 and that the Cu+2 ions in solution are picking up electrons and depositing on the surface of the copper electrode. Write down these two processes one after the other:
A+2 + 2e- ------> A
B -------> B+2 + 2e-
______________________
Add them together and see what you get...
A+2 + B ---> B+2 + A
we don't factor in the 2e- because they cancel each other out right?
so it would be:
Zn+2 +2e- ----> Zn
Cu----> Cu+2 + 2e-
___________________
Zn+2 + Cu----> Cu+2 + Zn
Right?
wait that's what I had before...
oh god.
would it be
Cu+2 +Zn ----> Cu + Zn+2 ?
That's correct. Now examine each of the metals in the equation. Which one is being oxidized and which is being reduced?
