Questions on the basic principles of physics.
  • Thread starter Thread starter MoreZitiPlease
    Physics
8 replies · 7K views
MoreZitiPlease
Really isn't involving problems, just principles of physics.
What are the units of velocity?
Im aware of m/s, but I hear there are more.
What is the value of "G"?
If an object starts from rest and travels a distance d in t sec, what equation may be used to find its acceleration?
Really all I need help on.
Average velocity is the change in unit distance per the change in unit time. (m/s, mph, feet/sec. km/h, etc).
Instantaneous velocity is the rate of change in position per the rate of change per unit time. Same units.
The value of g is 9.8 [tex]\frac{m}{s^2}[/tex] or 32.2 [tex]\frac{ft}{s^2}[/tex]
Equation of motion:
[tex]x=x_0+vt+\frac{1}{2}at^2[/tex] Solve for a
Hey, I made a new thread.
I don't think you properly understood the question.
See my new thrad.
And I know the value of G is 9.8 we
but It would be 980cm/m2
right
right
Centimeters per meter-squared? No. In centimeters, it would be [tex]\frac{cm}{s^2}[/tex]
Velocity could be measured in any distance units divided by any time units.
The acceleration caused by Earth's gravitational field, at the surface of the Earth, is normally denoted by g (not G) and is 9.81 meters per second per second.
If your object is accelerating at a constant rate then the equation to use is
d = 0.5 at^2
a = 2d / t^2
Yra I know it is 9.80 meters, but they want to convert it into centimeters. So it would b 980?
Yes. Use google as a calculator. Put in the following "9.8 meters to cm", click "search" and you get out the following: 9.8 meters = 980 centimeters
It even does automatic unit conversions. Put in "9.8 m + 32.2 ft", click "search and get back:
(9.8 meters) + (32.2 feet) = 19.61456 meters
How about this:
"50 mph + 10 m/s" "search"
(50 mph) + (10 (m / s)) = 32.35200 m / s
Pretty damn cool, huh?
Velocity is loosely a change in a position (distance) divided by the time interval that it took to change position.
So it will always be a distance over a time. Big G is called the gravitational constant( [tex]6.673*10^-11 \frac{m^3 s}{kg}[/tex]). Little g is acceleration due to gravity ([tex]GM/R^2[/tex]). On the surface of the Earth we can roughly measure it to (9.80m/s^2)
