Questions related to Relations and Functions
15 replies · 2K views
Raghav Gupta
1. Range of the function ## \sqrt {x^2+x+1} ## is equal to?
2.ƒ:R---->R is defined as ƒ(x) = x2 -3x +4, then f -1 (2) is equal to?
NA
For the first one tried squaring on both the sides but that does not give linear x in terms of y for finding the range.
For second one, I can directly substitute f(x) as 2 for getting the answer.
But I have a confusion that a function must be injective and surjective for the inverse otherwise it inverse must not exist.
1. you must have ##x^2 + x + 1 \geq 0## so for what x is that true?
2. I think you could start with ##2 = x^2 - 3x + 4## & go from there
1. I'm not asking for domain but range.
I know that the domain would be set of all real numbers.
2. That I know but I think f inverse should not exist as the function is not one one and onto?
You have a square root to worry about, so not every ##x## works in the domain. And what ##x##'s work determine the range.
Sometimes when ##f^{-1}## does not exist, the notation such as ##f^{-1}(2)## means the set of all ##x## such that ##f(x)=2##.
But I see here that if we choose any x here in this case , the value of
x2 + x + 1 is always greater than zero,
so not to worry for square root in this case.
That's right, but that does not mean the range is ##(0,\infty)##. For example, what ##x## gives ##f(x) = 1/2##?
No x gives that value
Right. So you still have to figure out the range.
Ya, the range then must be greater then 1/2 also.
What is the method to find the particular value?
You have to figure out the least that ##x^2+x+1##, and hence its square root, can be.
I differentiated it,
Got 2x + 1 = 0
Hence x = -1/2, a minima.
Substituting in function we get square root of 3/4 which is √3/2
Hence range is [√3/2,∞)
Thanks.
The word least provoked the differentiation.
Good. Note that you could have also found the min value without calculus by completing the square.
Hmm that's also fine.
As the thread is related to relations and functions.
I wanted to ask only a last question.
If ## f(x) = sin^2x + sin^2(x+ π/3) + cosxcos(x+ π/3)## and ##g(5/4)=1##, then ##(gof)(x)## is equal to?
Options are
sinx
None of these
I know gof(x) is g(f(x)) but here g(x) is not given.
Raghav Gupta said:
Anybody there or should I start a new thread?
I say yes - new thread. It's quite a different question.
Composition in LaTeX is ##(f\circ g)(x) \ \ \ \leftarrow\ \ \ \text{(f\circ g)(x)}## .
