Questopn about phase shift SHM
6 replies · 4K views · last reply
Saladsamurai
Question about phase shift SHM
The displacement of an object is given by
[tex]x(t)=x_mcos(\omega t+\phi)[/tex]
If the inital displacement is 0 and the initial v is in the negative x direction, then the phase constant must be ___rads
I know that if x=o then the cosine of the phase must be 0
[tex]\cos(\omega t+\phi)=0[/tex]
so[tex]\omega t+\phi=\frac{\pi}{2}[/tex]
and I am stuck from here...hints?
Initial means t=0. So x(0)=xm*cos(phi). phi=pi/2 works for that. Is v(0) negative? If so then you have a solution.
v is in -x direction...that is where I am most confused, does that just mean that phi has to be negative?
It means v=dx/dt is negative at t=0.
Okay...
so if [tex]v=-\omega x_m\sin(\omega t+\phi)=-[/tex]
and x_m=+
t=0
then [tex]-\omega x_m\sin(\phi)[/tex] is negative
so sin(phi) is positive
Thus, phi=+pi/2
Does that check out?
Looks ok to me. Draw a graph of cos(x) if you don't believe me.
I will...cause I don't.
No I won't...cause I do.
but I probably should so I can see the relationships...
Thanks again Dick.
