Quick Calculus book uses Δ by itself, ex: (ln(x+Δ)-lnx)/Δ
  • Context: Undergrad
  • Thread starter Thread starter lonely_nucleus
    Book Calculus
The discussion centers around the notation used in a calculus book, specifically the use of Δ in the expression (ln(x+Δ)-lnx)/Δ without an accompanying variable. Participants express confusion and opinions regarding this notation in the context of differentiation of logarithms and exponentials.
  • Some participants question the absence of a variable following Δ, suggesting it should be Δx for clarity.
  • Others argue that Δ is being used as shorthand for Δx, though this is considered sloppy by some.
  • One participant notes that different notations (like Δ, Δx, and h) are common in calculus, and consistency is preferred but not always necessary.
  • Another participant expresses discomfort with using Δ as a variable name, viewing it as an operator that could lead to confusion.
  • Some participants acknowledge that while Δ can be a valid variable name, h is more commonly used in this context.
  • A participant mentions that all letters can serve as names for sets, objects, and functions, depending on the context, which may include operators.
Participants generally express disagreement regarding the appropriateness of using Δ without a variable. There is no consensus on whether the notation is acceptable or if it causes confusion.
Some participants highlight the potential for confusion due to the dual role of Δ as both a variable and an operator, indicating that the notation may depend on the context in which it is used.
lonely_nucleus
On the section on differentiation of logarithms and exponentials the book shows equations like this
(ln(x+Δ)-lnx)/Δ and it gives values for Δ, I do not understand why there is no variable following the Δ.
if you want to see the exact question I am trying to explain please look at page number 119 in this online version of the book: https://www.amazon.com/dp/0471827223/?tag=pfamazon01-20
I'm not able to view page 119 from the link below. As to the notation, I believe the author is using Δ as a shorthand notation for Δx. That's a bit sloppy IMO.
I really appreciate you clearing that up for me friend.
Well, the title of the book was Quick Calculus. It was apparently so quick that Δx became just Δ. Or there was a disagreement with the typesetter, who got back a little on his own.
there must be (x)
Emmanuel_Euler said:
there must be (x)
It would be better if the author used Δx, but if he explains somewhere that he is using a shortcut, then no harm done, IMO.
The author can use whatever symbol s/he wants? I've seen x +Δx, x + Δ, x+h. A book should usually be consistent in that it uses the same notation, but be used to several different notations for the same thing. Different notations usually have upsides depending on what is being discussed.
you are right
\Delta is a perfectly good variable name, although h is more usual in that context.
I do not like Δ being used as a variable name because it is an operator and it caused me confusion, I will have to deal with it but using Δ by itself is similar to using + by itself. Thank you for the reply, it gave me a good heads up..
Not inherently so, in the way that +, -, \times, \circ, \wedge ... are operators.
All letters are available for use as names of sets, objects and functions (a category which includes operators), and may be reused for different purposes depending on context.
  • Sticky
  • · Replies 33 ·
11K
