Is Removing c from the Square Root in This Equation Correct?
  • Thread starter Thread starter rgtr
    Roots Square
The discussion centers on the mathematical manipulation of equations involving the variable c, particularly in the context of special relativity. Participants clarify that removing c from the square root in the equation r = sqrt(c^2) + x is not valid, as the expressions yield different results. The conversation also explores how to derive time dilation equations, specifically T_B and T_A, and the correct approach to simplify these equations. Participants point out algebraic errors and emphasize the importance of understanding the underlying physics. The thread concludes with a suggestion to seek further clarification in a dedicated relativity forum.
rgtr
## r ={ \sqrt{c^2} + {x} } ##
If I wanted to remove c from the square root, ## r ={ \sqrt{c^2} + {x} } ## would this be correct ## r = \sqrt { {c} + {x} } {c} ## ?
No they these two expressions for ##r## are not necessarily equal. For example c=2, x=1, the first gives ##r=2+1=3## while the second ##r=\sqrt{2+2}=2##.
if ##c## is a real number it is straightforward to remove the square root from ##c^2##...
How can I remove a single c from the square root?
Assuming ##c,x\in\mathbb{R}##:
It is ##\sqrt{c^2}=|c|## where ##|c|## the absolute value of c.
On the other expression , ##\sqrt{c+xc}=\sqrt{c(x+1)}=\sqrt{c}\sqrt{x+1}## only if we are given that c,x+1 are positive. As you can see in this case there is no way to remove c from the square root.
okay thanks
What are you really trying to do?
Likes Delta2
I am trying to solve ##T_B = \frac {2h} {\sqrt {v^2 - c^2} } ## ,##T_A = \frac {2h} {c} ## Then I need to divide TB by TA. This is in reference to special relativity deriving time dilation.
I managed to reduce it to ## \frac {T_B} {T_A} = \frac {( 2h)(c)} { \sqrt {(2h)( v^2 - c^2)} } ## . Then ## \frac {T_B} {T_A} = \frac { \sqrt {( v^2 - c^2)} } {c} ## The problem I then encounter is I have equal amount of the c variables. So I figure I have mutliply both sides by ## \frac {1} {c^2} ## Is this correct? Or is there a better way? Or are my calculations wrong?
Also why do I divide instead of - TB and TA?
rgtr said:
I am trying to solve ##T_B = \frac {2h} {\sqrt {v^2 - c^2} } ## ,##T_A = \frac {2H} {c} ##
You are solving for ##T_B##, ##T_A##, ##h##, ##H## or ##v##?
i.e. what are your knowns and that are your unknowns?
Also, can you back up and tell us what you are really trying to do instead of starting in the middle with partially simplified equations that may or may not be correct?
I am trying to get gamma. so iow's ## \frac {T_B} {T_A } = gamma## I would have to do the calculations. I guess I am asking am I am on the right track? Sure I will show my math. Let me make a new post.
##r = (\sqrt (c^2)) + x##
##r = (\sqrt (c))(\sqrt (c)) + x##
##r^2 = (\sqrt (c))(\sqrt (c))^2 + x^2 + 2x(\sqrt(c^2))##
##r^2 = (\sqrt (c^2))(\sqrt (c^2)) + x^2 + 2x(\sqrt(c^2))##
##r^2 = c(\sqrt (c^2)) + x^2 + 2x(\sqrt(c^2))##
That seems to be the only way to forcefully produce a single c out of the square root.
  • Skeptical
Likes DaveE, Delta2 and PeroK
Are the ##h,H## the same thing?
You have several problems (errors) here. In addition to Algebra issues, it looks like there must be errors with the physics. Assuming that ##v^2<c^2## you have the square root of a negative quantity.
So, please answer @jbriggs444 questions much more thoroughly. What are you really trying to do?
Likes Delta2
This makes sense as: in reality this can be simply written as ##r= c + x## . Squaring this equation would essentially give the same answer.
  • Skeptical
Likes DaveE and PeroK
Neither of your posts are correct.
Please, just let @jbriggs444 make a reply.
In LaTeX how do I go 1/1/1/1/?
you mean this $$\frac{\frac{1}{1}}{\frac{1}{1}}$$?
Write click on the latex pic and choose Display as Tex Commands
Likes rgtr
First, as noted, you probably mean ##\sqrt{c^2-v^2}##.
Next, you have gone wrong in simplifying ## \frac {T_B} {T_A}##. In your first step, ##\frac {( 2h)(c)} { \sqrt {(2h)( v^2 - c^2)} } ## , I guess it is a typo that the 2h in the denominator is inside the square root. But your final ## \frac { \sqrt {( v^2 - c^2)} } {c} ## is inverted.
I don’t understand what you mean by "The problem I then encounter is I have equal amount of the c variables." Where were you hoping to go from there?
What I mean is that ## \frac {c} {c } = 1 ## .
Both H's are the same.part 1
## \frac {T_B} {T_A} = \frac{\frac{2h}{c^2-v^2}}{\frac{ 2h} {c}} ##
part 2
Then I performed algebra rules 10 https://algebrarules.com/## \frac {T_B} {T_A} = \frac {(2h)(c^2- v^2)}{(2h)(c} ##
part 3
Then I use algebra rule 4 the right hand side becomes the left side by using c. https://algebrarules.com/
## \frac {T_B} {T_A} = \frac { (c)(1)} {\sqrt { (c^2 - v^2)} } ##
part 4
The c -v should be square rooted but due to formating issues I left it I am in a rush.
## \frac {T_B} {T_A} = \frac{\frac{1}{c -v}}{\frac{1} {c} }##
part 5
I left the 1 at the bottom due to troubles with formatting.## \frac {T_B} {T_A} = \frac{ \frac {1} {\sqrt {c^2-v^2}} } {\frac{c} {1} } ##I fixed it finally.
rgtr said:
part 1
## \frac {T_B} {T_A} = \frac{\frac{2h}{c}}{\frac{ 2h} {c^2-v^2}} ##
You've lost a square root, and it seems inverted. In post #7 you wrote
I see you now have the more reasonable ##c^2-v^2## so that becomes
##T_B = \frac {2h} {\sqrt {c^2 - v^2} } ## ,##T_A = \frac {2h} {c} ##
From that I get ## \frac {T_B} {T_A} =\frac{\frac{2h}{\sqrt{c^2-v^2}}}{\frac{ 2h} {c}} =\frac c{\sqrt{c^2-v^2}}##.
Likes Delta2
Ya the squre root was just a typo. My question is am I on the right track? I can also cancels out the c's.
This is where you lose me. What do you mean that you can cancel the c's?
You can do ##\frac c{\sqrt{c^2-v^2}}=\frac 1{\sqrt{1-(\frac vc)^2}}##.
Likes Delta2 and rgtr
RSOTE = right side of the equation.
Okay the RSOTE you just mentioned is confusing me. Can you explain it? The confusing part is the c's.
## \frac c { \sqrt{ { c } } } = 1 ##
I guess it is kind of self explained. Thanks I think the title needs a change.|
I just have 1 question in special relativity I have a stationary light clock and a moving light clock. Why did I divide them and not minus the two frames?
Dividing top and bottom by c:
##\frac c{\sqrt{c^2-v^2}}=\frac 1{\frac 1c\sqrt{c^2-v^2}}##
Moving the 1/c inside the square root:
##=\frac 1{\sqrt{\frac 1{c^2}(c^2-v^2)}}##
##=\frac 1{\sqrt{1-(\frac vc)^2}}##.
Likes Delta2
Please use the more standard "RHS" and "LHS" for designating the two sides of an equation. Thank you kindly. :wink:
Likes malawi_glenn, SammyS and Delta2
Because special relativity laws imply ##\frac{T_B}{T_A}=\gamma## and not ##T_B-T_A=\gamma##? Anyway post this question in the relativity forum so that the experts there can give more detailed and in depth answers.
EDIT: You could 've taken ##T_B-T_A## and end up with ##T_B-T_A=(\gamma -1)T_A##
No, @rgtr please send me a PM (private message -- click my avatar and "Start a Conversation") to explain your question. I will help you formulate it better and get it ready for a new thread start in the appropriate forum. Thank you.
This thread is closed for now.
Likes Roon, Orodruin and SammyS
  • · Replies 21 ·
