Quick question about impedance paradox
  • Thread starter Thread starter Tusike
    Impedance Paradox
The discussion centers on calculating the effective current in a parallel circuit consisting of a 0.0768H coil and a 50 Ohm resistor at 230V, 60Hz. Two methods were attempted: one using impedance calculations leading to an effective current of 12.567A, and another using phasor analysis resulting in 9.2A. The error identified was the improper handling of complex impedances, which require the use of imaginary numbers for accurate calculations. The correct approach involves using the formula for the magnitude of the total impedance, which yields a resultant impedance of 25 Ohms.
  • Understanding of AC circuit theory
  • Familiarity with impedance calculations
  • Knowledge of complex numbers and phasors
  • Basic electrical engineering principles
  • Study complex impedance calculations in AC circuits
  • Learn about phasor representation of AC currents and voltages
  • Explore the concept of reactance and its impact on circuit behavior
  • Review the use of the imaginary unit in electrical engineering
Electrical engineering students, circuit designers, and anyone involved in analyzing AC circuits and impedance calculations.
Tusike
Hi!
We have a parallel circuit on 230V, 60Hz voltage. One of the parallel's has a 0.0768H coil, the other has a 50 Ohm resistance on it. The question is: What is the effective I in the main current?
Z = Lw
OK, so I have two ways of solving this, and they lead to different results, I don't know which isn't correct and why.
#1). The impedance of the resistance is the same, 50 Ohms, while the impedance of the coil is L*w = 0.0768H * 120*pi = 28.868 Ohms. And so for the overall impedance: 1/Z = 1/Z(R) + 1/Z(L) = 1/50 + 1/28.868 = 0.05464 and so Z = 18.3 Ohms. For the effective I in the main current; I(eff) = U/Z = 230V/18.3Ohms = 12.567A.
#2) Since the coil's current is 90 degrees behind the resistance's, it is true that the main current i^2 = i(ZL)^2 + i(ZR)^2, where i(ZL) is the current in the coil and i(ZR) is the current in the resistance at a given point in time. Divide this equation by sqr(2)*sqr(2) to get the same equation for the effective currents: I^2 = I(ZL)^2 + I(ZR)^2.
We have calculated before that Z(L) = 28.868, so I(ZL) = 230/28.868=7.9673A. Z(R) = R = 50, so I(ZR) = 230 / 50 = 4.6A. And so the effective current in the main current is sqr(7.9672^2 + 4.6^2) = 9.2A.
Can anybody please tell me what I did wrong and why is it wrong? Thanks!
-Tusike
Tusike said:
Z = Lw
You can not simply add up impedances or reciprocal impedances. If you learned about complex impedances, you should handle them as complex numbers. ZL=iwL where i is the imaginary unit. So the reciprocal resultant impedance is 1/Z=1/(iwL)+1/R = 1/R-i/wL. The magnitude is obtained as |1/Z|=sqrt((1/wL)2+(1/R)2), |Z|= 25 ohm
Oh OK I see now. I didn't learn yet about calculating with imaginary numbers, so for now I'll just use my other method, but I'll definitely look into this after I'm finished.
Thanks!
  • · Replies 21 ·
