Quick question on accuracy (statistics)
The discussion revolves around estimating the accuracy of measurements taken by multiple individuals across different distances, utilizing statistical methods. The original poster has calculated means and standard deviations but seeks clarification on how to define and estimate accuracy in this context.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the relationship between standard deviation and accuracy, with some questioning the definition of accuracy itself. There are discussions about using the standard deviation of the means and the root mean square as potential measures of accuracy.
The conversation is ongoing, with participants providing insights into different interpretations of accuracy and its statistical measures. Some guidance has been offered regarding the use of standard deviation as a measure of accuracy, but there remains a lack of consensus on a singular definition.
Participants are navigating the ambiguity of the term 'accuracy' in statistics, with varying interpretations based on the context of the measurements taken.
Elfrae
I've got nine sets of data (three people each took ten measurements of three different distances), and I need to find an estimate of the accuracy to which each person measured each distance.
I've already calculated the mean and standard deviation for each set of data, but I don't know how to estimate the accuracy. Someone mentioned using the root mean square but I'm not sure if this is correct. How do I go about this?
Look at the standard deviations of the means.
\sigma_{\mu_{x}} = \frac{\sigma_{x}}{\sqrt{N}}
I'm not sure I understand you. Are you saying that the standard deviation of the mean is the standard deviation of the data divided by root N? Is that the accuracy? I don't know what is meant by 'accuracy' in this context.
"Root mean square" is the standard deviation!
I think Courtigrad was under the impression that you wanted an "overall" accuracy for all three people, not three different accuracies.
Just as there are several different "averages" (mean, median, mode, midrange) so there are several different measures of accuracy or "dispersion".
The standard deviation is itself a perfectly good measure of "accuracy". Another is the "distance from the mean": Take the absolute value of the difference of each measurement and the mean. The "accuracy" is the largest of those: you are saying that the "true value" is the mean plus or minus that "accuracy".
So there is no one definition for 'accuracy' but using the standard deviation as a value for accuracy is acceptable?
Right, now I know what the question is asking! Thank you.
  • · Replies 26 ·
