Quick Resultant Forces Question
Pablo1122
Free-body style diagram of three forces on a particle at the origin of x and y axes: 65.0 N at 30 degrees above the positive x-axis, 30.0 N pointing left along the negative x-axis, and 20.0 N at 20 degrees from the negative y-axis. Answer choices a to e listed below.
So we have 65N @ 30*, 30N @ 180* and 20N at 250*
Ncos(angle)i + Nsin(angle)j
Using this video
I did the following.
F1(65N) = 65cos(30)i+65sin30i
Then using the radian circle I saw that 30* has x,y coordinates of sqrt3/2 and 1/2 respectively. So as shown in the video I did
65(root3/2)i+65(1/2)j
= 56.3i + 32.5j
I did this for the left one too (30N).
But for the one at the bottom (20N) I get the degree of it to be 250. (270-20) = 250.
250* is not on the radian circle so how can I write 250* in terms of x,y coordinates?
Unit circle diagram with angles marked every 30 degrees from 0 to 330, each labelled with its (cos, sin) coordinates; the 240 and 270 degree points are visible but no 250 degree point is marked.
If we look at this radian circle. We see that 240* = (-1/2, -sqrt3/2) and then it goes to 270* = (0,-1). How can I find the x,y coordinates for 250* and use it in the equation?
Thanks in advance.
I don't believe that trig functions of that particular angle can be simply expressed. (Like the others can.) You'll need a calculator.
Ah yes, I just found this out. Thanks!
If it's a matter of expressing it in surds, you can use the usual expansion of sin(3x), with x=20o, and apply the formula for solving cubics.
