Calculating Beam Deflection with Different Materials Using PL/AE
  • Thread starter Thread starter glid02
The discussion focuses on calculating beam deflection for a composite beam made of steel and brass using PL/AE. The user is tasked with determining the deflection of a 1m x 1m steel beam with a 1/4m brass shell, subjected to an evenly applied force. The key insight is that both materials must deflect together, and the effective modulus of elasticity (E) should be considered rather than simply averaging the values. The user is encouraged to utilize PL/AE to analyze the combined effects of both materials on deflection.
  • Understanding of beam deflection principles
  • Familiarity with material properties, specifically Young's modulus (E) for steel and brass
  • Knowledge of composite beam analysis
  • Experience using PL/AE software for structural analysis
  • Research composite beam theory and how to calculate effective modulus of elasticity
  • Learn how to perform beam deflection calculations using PL/AE
  • Study the effects of axial loads on composite materials
  • Explore advanced topics in structural analysis, such as finite element methods
Structural engineers, materials scientists, and students studying composite materials and beam deflection analysis will benefit from this discussion.
glid02
I'm supposed to find the deflection of a beam. It's steel with a brass shell, so they have different values for E. How do I do this problem using PL/AE.
Intuitively I think I should take the average, but I have no idea if that's right or not.
Thanks.
I should probably give some more information:
the steel part is 1m x 1m and the shell is 1/4 m on all sides, so the total area of the beam is 1.5m x 1.5m. The force is applied evenly on the end of the beam.
I thought maybe I should just use PL/AE for the material with the higher E value - steel - but the brass shell would have to have some effect on the deflection.
Thanks.
When the beam is subject to the axial load P, part of that load is carried by the steel, and the other part by the brass. Both the brass and steel must deflect together by the same amount. Does that give you a hint as to how to proceed?
Yeah, that helps. I'll give it a shot and you'll hear back from me if I still can't get the right answer.
Thanks.
20K
