Quick SUVAT Check: Find Time for Particles P & Q to Become Level
  • Thread starter Thread starter Taylor_1989
    Suvat
The discussion focuses on solving a physics problem involving two particles, P and Q, using the SUVAT equations. Particle P is fired vertically upwards at 17.64 m/s, while particle Q is fired 1.8 seconds later at 25 m/s. The user successfully calculates the time at which both particles become level, arriving at the correct answer of 2.44 seconds. The user seeks confirmation on their understanding of the SUVAT equations and the time variables involved.
  • Understanding of SUVAT equations in kinematics
  • Knowledge of vertical motion and projectile motion principles
  • Ability to solve simultaneous equations
  • Familiarity with the concept of maximum height in projectile motion
  • Review the derivation and application of SUVAT equations
  • Practice problems involving multiple projectiles in motion
  • Explore the concept of maximum height and time of flight in projectile motion
  • Learn about the effects of air resistance on projectile motion
Students studying physics, particularly those focusing on kinematics and projectile motion, as well as educators looking for examples of SUVAT applications in real-world scenarios.
Taylor_1989
I would just like someone to give a quick check to part b) of this question, just to make sure I have fully grasped the concept.
A t=0s, particle P is fired vertically upwards with speed 17.64ms-1.When P reaches its maximum height, particle Q is fired vertically upwards with a speed 25ms-1. Both particles are fired from ground level.
a) find the time between the two particles being fired.
Ans:1.8s
b) Find the length of the time after P is fired before the two particles become level.
So I start with the SUVAT equation:
S=Sp, U=17.64, V=0, T=T
S=Sq, U=25, V=N/A, T=T-1.8
I then use the equation S=ut+\frac{1}{2}at^2
I would the set Sp=Sq, and solve simultaneously.
My point I would like to touch on is the t part. I set T=T because I do not know the total time take for the ball to reach maximum height; correct? T=T-1.8, because once again I do not know 1. the time taken for the ball to reach max height 2. - 1.8 because it was fired 1.8s later than the first.
I did end up with the right ans which is t=2.44s. But just want to makes sure I have the right intuition behind the question.
Big thanks in advance.
Yes you do. Good job.
  • · Replies 38 ·
  • · Replies 21 ·
10K
