Radius and Interval of Convergence for (3^n x^n)/(n+1)^2 Series
The series (3^n x^n) / (n+1)^2 has a radius of convergence of 1/3, determined using the ratio test. The interval of convergence includes endpoints -1/3 and 1/3. At x = 1/3, the series converges due to the p-series test where p = 2, which is greater than 1. At x = -1/3, the series converges as well, confirmed by the alternating series test, which applies to the absolute values of the terms that decrease to zero.
  • Understanding of series convergence tests, specifically the ratio test and alternating series test.
  • Familiarity with p-series and their convergence criteria.
  • Knowledge of absolute convergence and its implications for series.
  • Basic algebraic manipulation of series terms and limits.
  • Study the properties of p-series and their convergence criteria in detail.
  • Learn about the alternating series test and its application to series with alternating terms.
  • Explore absolute convergence and its significance in determining the convergence of series.
  • Practice applying the ratio test to various series to solidify understanding of convergence radii.
Students and educators in calculus, particularly those focusing on series convergence, as well as mathematicians seeking to deepen their understanding of convergence tests and series behavior.
badtwistoffate
Have to find the radius of convergence and interval of convergence,
the series is (3^n x^n ) / (n+1)^2,
did the ratio test and found the radius of convergence to be the 1/3.
now for finding the interval of convergence I plug in -1/3 and 1/3 into x and find out if it converges or not
For 1/3, it converges due to p-series, 2>1.
But for -1/3 I know it converges but can see why? Any help here at this endpoint?
You could use the alternating series test.
More simply, you can relate the series at -1/3 to the series at 1/3...
I don't quite understand, the alternating series only works when An+1< or = to An, and in that series it doesnt, because An is negative and An+1 is postivie?
Could you elaborate and how I would relate it to the series at 1/3?
Look at the alternating series test again, it's the absolute values of the terms that are decreasing (and going to zero) while the sign is alternating.
The series at 1/3 is the absolute values of the terms of the series at -1/3, i.e. you've already should that the series at -1/3 is absolutely convergent.
iiiiiiiiiii...
my book doesn't say absolute value... so idk. I see what you mean if that's true. Why doesn't my book say that it says just that its decreasing or equal too...
