Quotient Group is isomorphic to the Circle Group
7 replies · 5K views
spotsymaj
A portion of a homework problem was given me to solve for practice. I have solved some but not all of the homework problem and I hope you all can help.
Here is the problem:
1. For each x [tex]\in[/tex] R it is conventional to write cis(x) = cos(x) + i sin(x). Prove that cis(x+y) = cis(x) cis(y).
Let x, y [tex]\in[/tex] R. We want to prove that cis(x+y) = cis(x) cis(y). Thus,
cis(x+y) = cos(x+y) + i sin(x+y)
= (cos(x) cos(y) - sin(x)sin(y)) + i(cos(x)sin(y) + sin(x)cos(y))
= cos(x) cos(y) - sin(x) sin(y) + i sin(x) cos(y) + i sin(y) cos(x)
= (cos(x)+ i sin(x))(cos(y) + i sin(y))
= cis(x) cis(y)
2. Let T designate the set {cis(x) : x [tex]\in[/tex] R}, that is, the set of all the complex numbers lying on the unit circle, with the operation of multiplication. Use part 1 to prove that T is a group.
3. Use the FHT to conclude that T isomorphic R/<2[tex]\pi[/tex]>
4. Prove that g(x) = cis(2[tex]\pi[/tex]x) is a homomorphism from R onto T, with kernel Z
Let g: R -> T by g(x) = cis(2[tex]\pi[/tex]x).
g is subjective since ever element of T is of the from cis(a) = cis(2[tex]\pi[/tex](a/2[tex]\pi[/tex])) = g(a/2[tex]\pi[/tex]) for some a [tex]\in[/tex] R. The kernel of g is the set of x [tex]\in[/tex] R such that cis(2[tex]\pi[/tex]x) = 1. This equation only holds true if and only if 2[tex]\pi[/tex]x = 2[tex]\pi[/tex]k for some k [tex]\in[/tex] Z. Divide by 2[tex]\pi[/tex] then you get ker(g) = Z. Hence, g is a homomorphism with a kernel of Z
5. Conclude that T is isomorphic R/Z
By the FHT g: R -> T is a homomorphism and R is subjective to T. Since Z is the kernel of g then H is isomorphic to R/Z
I really have no clue how to do 2 and 3 so any help would be great on that. Also if you can verify that my other three are correct that would be great. Thanks for the help in advance
for #2 you need to verify the group axioms.
pick [tex]z,w,v \in T[/tex]
you need to show:
1. [tex]zw \in T[/tex]
by the first problem you have proved... we have
[tex]zw=cis(x)cis(y)=cis(x+y) \in T[/tex]
cis(x+y) is in T by definition since x+y is in R
2. [tex](zw)v=z(wv)[/tex]
not hard to show... (since T is a subset of the complex numbers)
3. there exists a multiplicative identity in T
...its 1( =cis(0) ) !
4. there exists an inverse for z in T
[tex]z \in T \Rightarrow |z|=1[/tex]
use [tex]\frac{1}{z} = \frac{\bar z}{ |z|^2}[/tex]
and |z|=1 to show that 1/z is in T.
For #3 define:
Note that R here is treated as an additive group!
[tex]f: R \rightarrow T[/tex]
by [tex]x \rightarrow cis(x)[/tex]
problem 1 shows its an additive homomorphism
you need to show that the kernel of f is [tex]< 2 \pi >[/tex]
do you know how to do this?
Eric Wright said:
Do you know how to do this?
Not really! I have taught myself this whole course
What does this mean?
[tex]1=cis(0) \in T[/tex]
the multiplicative identity in T is the number 1 which is e^0=cos0+isin0=cis(0)
1 is in T since 1=cis(0) and 0 is a real number
Take an arbitrary element of [tex]<2 \pi >[/tex] and show it is in the kernel.
Next take an arbitrary element of the kernel and show it is in [tex]<2 \pi >[/tex]
This is a technique called double containment and it is how we normally show that sets are equal.
