Quotient Groups - Dummit and Foote, Section 3.1, Exercise 17
12 replies · 4K views
Math Amateur
MHB
I am reading Dummit and Foote Section 3.1: Quotient Groups and Homomorphisms.
Exercise 17 in Section 3.1 (page 87) reads as follows:
Let G be the dihedral group od order 16.
[tex]G = < r,s \ | \ r^8 = s^2 = 1, rs = sr^{-1} >[/tex]
and let [tex]\overline{G} = G/<r^4>[/tex] be the quotient of [tex]G[/tex] generated by [tex]r^4[/tex].
(a) Show that the order of [tex]\overline{G}[/tex] is 8
(b) Exhibit each element of [tex]\overline{G}[/tex] in the form [tex]\overline{s}^a \overline{r}^b[/tex]------------------------------------------------------------------------------------------------------------------
I have a problem with part (b) in terms of how you express each element of [tex]\overline{G}[/tex] in the form requested - indeed, I am not quite sure what is meant by "in the form [tex]\overline{s}^a \overline{r}^b[/tex]"My working of the basics of the problem was to put [tex]H = <r^4>[/tex] and generate the cosets of H as follows:
[tex]1H = H = \{ r^4, 1 \}[/tex]
[tex]rH = \{ r^5, r \}[/tex]
[tex]r^2H = \{ r^6, r^2 \}[/tex]
[tex]r^3H = \{ r^7, r^3 \}[/tex]
[tex]sH = \{ sr^4, s \}[/tex]
[tex]srH = \{ sr^5, sr \}[/tex]
[tex]sr^2H = \{ sr^6, sr^2 \}[/tex]
[tex]sr^3H = \{ sr^7, sr^3 \}[/tex]So the order of [tex]\overline{G}[/tex] is 8BUT - how do we express the above in the form [tex]\overline{s}^a \overline{r}^b[/tex] and what does the form mean anyway?
Would appreciate some help.
Peter
[Note: This has also been posted on MHF]
Peter
You have essentially already done that when you listed the cosets. All you need to do is to notice that $\overline{s}^a \overline{r}^b$ is just an alternative notation for the coset $s^ar^bH$.
Thanks Opalg.
... just checking ...
It does not appear at first glance that [tex]r^3H = \{ r^7, r^3 \}[/tex] actually fits the form $$ s^ar^bH $$ unless of course we view it as $$ s^0r^3H $$.
Presumably that is the interpretation?
Peter
Peter said:
Thanks Opalg.
Peter
Yes, you need to say that $r\in\{0,1,2,3\}$ and $s\in\{0,1\}$.
Opalg,
I do not follow why $r\in\{0,1,2,3\}$ and $s\in\{0,1\}$.
Can you explain?
Peter
Can you explain?
Look at the list of cosets that you gave:
Peter said:
[tex]1H = \color{red}{s^0r^0H}[/tex]
[tex]rH = \color{red}{s^0r^1H}[/tex]
[tex]r^2H = \color{red}{s^0r^2H}[/tex]
[tex]r^3H = \color{red}{s^0r^3H}[/tex]
[tex]sH = \color{red}{s^1r^0H}[/tex]
[tex]srH = \color{red}{s^1r^1H}[/tex]
[tex]sr^2H = \color{red}{s^1r^2H}[/tex]
[tex]sr^3H = \color{red}{s^1r^3H}[/tex]
Hi Opalg,
From what you have emphasized regarding my calculations it appears that the cosets are of the form $$ \overline{s}^a \overline{r}^b $$
where
$$ a \in \{0,1 \} $$
and
$$ b \in \{ 0,1,2, 3 \} $$
Can you please comment?
[Maybe I am being pedantic, but just want to make sure i understand what is being said ...]
Peter
One can visualize $\langle r \rangle$ in the following "geometric" way:
Imagine a unit circle in the plane with eight distinguished "dots", starting at (1,0), and spaced around the unit circle so as to form a regular octagon. $r$ then can be represented as the rotation that takes each dot to the next one counter-clockwise.
Now what does "modding out $\langle r^4 \rangle$" correspond to?
You can imagine it like so: We deform the circle by "squeezing" the points (-1,0) and (1,0) together, to form TWO circles, like a figure 8, and then "fold the top one over" fusing the two circles. So now what used to be a 1/8 turn (on the original circle) is a 1/4 turn on the fused pair.
$s$ plays no part in this, all we have done with $G$ is to effectively replace the rotation generator $r$ with a new one $rH$ that now has an order of 4, instead of 8. In this quotient, the coset of $s$ is still of order 2 (because we have $s^2 = e \in H$ and $s \not\in H$, so that $sH \neq H$) and the relation:
$rs = sr^{-1}$
still holds in $G/H$:
$(rH)(sH) = rsH = sr^{-1}H = (sH)(r^{-1}H) = (sH)(rH)^{-1}$.
Given this, do you see how we can form a surjective homomorphism: $D_8 \to D_4$?
$rs = sr^{-1}$
Thanks for those helpful insights, Deveno.
I can see how the two circles come about from squeezing the points (-1,0) and (1,0) ... see my attached diagram and brief explanation ...
I am not sure what the above does to the octagon but inuitively it turns it into a sqare in each of the smaller circles, and hence the octagon becomes a square in the overlapped circles ... so I can imagine a transformation from $$ D_8 $$ to $$ D_4 $$ ... but exactly how to show this ... ?
You mention that if we replace the rotation generator r with rH where $$ H = r^4 $$, then rH has an order of 4. This seems right as
$$ rH = \{ r^5, r \} $$
$$ {rH}^2 = (rH)(rH) = r^2H = \{ r^6, r^2 \} $$
$$ {rH}^3 = r^3H = \{ r^7, r^3 \} $$
$$ {rH}^4 = r^4H = 1.H $$
Thus (rH) has an order of 4, compared with r which has an order of 8.
You also mention that the coset sH has an order of 2 ...
we have $$ (sH)^2 = s^2H = 1H = H $$
So yes, sH has an order of 2 ...
(But what is the relevance of $$ rs = sr^{-1} $$
Regarding a surjective homomorphism $$ D_8 \to D_4 $$ I cannot quite see how to do it ... can you help?
I can see that there is a surjective homomorphism: $$ \pi \ : \ D_8 \to D_8/H $$ where $$ H = <r^4> $$ given by
$$ \pi (a) = aH $$
In this homomorphism for example:
$$ \pi (r) = rH = \{r^5 , r \} $$
$$ \pi (s) = sH = \{ sr^4 , s \} $$
and then
$$ \pi (sr) = srH = \{ sr^5 , sr \} $$
So, check that $$ \pi (s) \pi (r) = \pi (sr) $$
$$ \pi (s) \pi (r) = \{ sr^4, s \}* \{ r^5, r \} $$
But ... how to multiply two sets ... ? ... Guess ... multiply all elements ...
Then get $$ \pi (s) \pi (r) = \{ sr^9, sr^5, Sr^5, Sr \} = \{sr, sr^5 \} $$
which seems right ...
But how do we get a surjective homomorphism from $$ D_8 $$ to $$ D_4 $$?
Peter
The rule for multiplying two cosets is:
$(aH)(bH) = (ab)H$
For this to "make sense", we need to be confident that whenever:
$c \in aH$
$d \in bH$
that $cd \in (ab)H$.
If $H$ is normal, THIS ALWAYS MAKES SENSE.
Proof:
Suppose $H$ is normal, with $c \in aH, d \in bH$. Thus:
$c = ah$, for some element $h \in H$, and $d = bh'$ for some element $h' \in H$.
So... $cd = (ah)(bh')$.
But since $H$ is normal, $Hb = bH$, that is, $hb = bh''$ for some (possibly different) $h'' \in H$. Thus:
$cd = (ah)(bh') = a(hb)h' = a(bh'')h' = (ab)(h''h') \in (ab)H$
(since $h''h' \in H$ by the closure property of a subgroup).
$(aH)(bH) = (ab)H$
$c \in aH$
$d \in bH$
Proof:
Thanks Deveno, yes, that is clear.
Can you help on the surjective homomorphism from $$ D_8 $$ to $$ D_4 $$?
Peter
Let's write:
$D_8 = \{1,r,r^2,r^3,r^4,r^5,r^6,r^7,s,sr,sr^2,sr^3,sr^4,sr^5,sr^6,sr^7\}$
Where $r^8 = s^2 = 1$.
The multiplication table is completely determined by the rule:
$rs = sr^{-1}$.
For example:
$(sr^2)(sr^3) = (sr)(rs)r^3 = (sr)(sr^{-1})r^3 = (srs)r^2$
$ = s(rs)r^2 = s(sr^{-1})r^2 = s^2r = r$
(It is faster when verifying the entire multiplication table of 256 entries (!) to first prove the rule:
$r^ms = sr^{-m}$)
Let us write:
$D_4 = \{e,a,a^2,a^3,b,ba,ba^2,ba^3\}$ where $a^4 = b^2 = e$,
subject to the rule:
$ab = ba^{-1}$.
Then, all we must do is verify that the following map gives a homomorphism:
$\phi(s^kr^m) = b^ka^m$
(There are four cases to check, I leave them to you).
Note that this mapping is NOT one-to-one, for example:
$\phi(r^2) = a^2 = ea^2 = (a^4)(a^2) = a^6 = \phi(r^6)$.
What is $\text{ker}(\phi)$?
If $\phi(s^kr^m) = b^ka^m = e$, we must have $k = 0$, that is:
$s^kr^m \in \langle r \rangle$.
Direct computation shows that the only $m$ for which this holds is:
$m = 0,4$, so $\text{ker}(\phi) = \{1,r^4\}$.
Deveno said:
Let's write:
$rs = sr^{-1}$.
For example:
$r^ms = sr^{-m}$)
Let us write:
$ab = ba^{-1}$.
Direct computation shows that the only $m$ for which this hold is:
Most helpful indeed!
Working through the post carefully now!
Peter
