R for Beginners: Textbooks & Resources for Neurobiology
  • Thread starter Thread starter cobalt124
    Beginner
The discussion centers on resources for learning R programming, particularly for a university student studying Neurobiology. The user seeks recommendations for textbooks and online materials to help their daughter, who is new to programming and needs to use R for statistical modeling and graph plotting. Suggestions include various online tutorials, particularly from Tutorialspoint and Learn X in Y Minutes, as well as a recommendation for the "R in a Nutshell" book from the O'Reilly series. YouTube courses are also mentioned as useful resources. The conversation highlights the importance of R as a statistical computing language, noting its established reputation in the field. While alternatives like MATLAB, Julia, and Python are acknowledged, the consensus is to focus on R since it is a course requirement. The discussion also emphasizes the value of comparing R solutions to those in other programming languages, which can provide perspective without causing distraction. Overall, the emphasis is on finding effective learning tools and maintaining focus on mastering R for academic success.
cobalt124
TL;DR
R programming advice for a beginner
My daughter has just started her first year at university studying Neurobiology. She doesn’t have much experience with programming and is having to learn R (RStudio 3.0.2) from scratch for the statistical modelling/graph plotting parts of the course. She knows what she needs to do with her data but not how to express the requirement in R. Are there any textbooks/online resources anyone could recommend for a beginner using R?
Technology news on Phys.org
Google is your friend, searching on R tutorial will bring up many good resources for her to look at, in particular tutorialspoint is a good starting place:
https://www.tutorialspoint.com/r/index.htm
is R a course prerequisite?
If not there are other tools that may fit the bill such as MATLAB, Julia, or Python. A lot of stat modules are available for these more commonly used tools.
There are also some YouTube videos on R, here’s one such course
Likes FactChecker
Thanks for the links, I’ll pass them on. Yes RStudio is what she has to use. I did a Google search and checked the forum resources before posting. I mistakenly assumed R resources would be as common as for Python, that doesn’t seem to be the case. Think we’ll have to have a further search, thanks for the start.
Look at "R in a Nutshell". The O'Reilly Nutshell series of books are usually good and the R book is a good reference.
Likes jedishrfu
BTW the last time I looked for R books in a bookstore, they were not with the other programming books but were, instead, filed over in biology. Just in case you want to go browse books in person. Took me a while to find them.
Likes jedishrfu
Your daughter might also benefit from browsing https://rosettacode.org ##-## she can check how a given problem can be solved in R, and then review solutions to the same problem in e.g. Mathematica or Python.
Here's an example:
rosettacode.org said:
R being a statistical computating language, the chi-squared test is built in with the function "chisq.test"
Code:
dset1=c(199809,200665,199607,200270,199649)
dset2=c(522573,244456,139979,71531,21461)
chi2IsUniform<-function(dataset,significance=0.05){
  chi2IsUniform=(chisq.test(dataset)$p.value>significance)
for (ds in list(dset1,dset2)){
  print(c("Data set:",ds))
  print(chisq.test(ds))
  print(paste("uniform?",chi2IsUniform(ds)))
Output:
[1] "Data set:" "199809" "200665" "199607" "200270" "199649"
Chi-squared test for given probabilities
data: ds
X-squared = 4.1463, df = 4, p-value = 0.3866
[1] "uniform? TRUE"
[1] "Data set:" "522573" "244456" "139979" "71531" "21461"
data: ds
X-squared = 790063.3, df = 4, p-value < 2.2e-16
[1] "uniform? FALSE"
The same problem solved in Mathematica:
This code explicity assumes a discrete uniform distribution since the chi square test is a poor test choice for continuous distributions and requires Mathematica version 2 or later
Code:
discreteUniformDistributionQ[data_, {min_Integer, max_Integer}, confLevel_: .05] :=
If[$VersionNumber >= 8,
  confLevel <= PearsonChiSquareTest[data, DiscreteUniformDistribution[{min, max}]],
  Block[{v, k = max - min, n = Length@data},
   v = (k + 1) (Plus @@ (((Length /@ Split[Sort@data]))^2))/n - n;
   GammaRegularized[k/2, 0, v/2] <= 1 - confLevel]]
discreteUniformDistributionQ[data_] :=discreteUniformDistributionQ[data, data[[Ordering[data][[{1, -1}]]]]]
code used to create test data requires Mathematica version 6 or later
uniformData = RandomInteger[10, 100];
nonUniformData = Total@RandomInteger[10, {5, 100}];
{discreteUniformDistributionQ[uniformData],discreteUniformDistributionQ[nonUniformData]}
Output:
{True,False}
The same problem solved in Python:
Implements the Chi Square Probability function with an integration. I'm sure there are better ways to do this. Compare to OCaml implementation.
Python:
import math
import random
def GammaInc_Q( a, x):
    a1 = a-1
    a2 = a-2
    def f0( t ):
        return t**a1*math.exp(-t)
    def df0(t):
        return (a1-t)*t**a2*math.exp(-t)
    y = a1
    while f0(y)*(x-y) >2.0e-8 and y < x: y += .3
    if y > x: y = x
    h = 3.0e-4
    n = int(y/h)
    h = y/n
    hh = 0.5*h
    gamax = h * sum( f0(t)+hh*df0(t) for t in ( h*j for j in xrange(n-1, -1, -1)))
    return gamax/gamma_spounge(a)
c = None
def gamma_spounge( z):
    global c
    a = 12
    if c is None:
       k1_factrl = 1.0
       c = []
       c.append(math.sqrt(2.0*math.pi))
       for k in range(1,a):
          c.append( math.exp(a-k) * (a-k)**(k-0.5) / k1_factrl )
          k1_factrl *= -k
    accm = c[0]
        accm += c[k] / (z+k)
    accm *= math.exp( -(z+a)) * (z+a)**(z+0.5)
    return accm/z;
def chi2UniformDistance( dataSet ):
    expected = sum(dataSet)*1.0/len(dataSet)
    cntrd = (d-expected for d in dataSet)
    return sum(x*x for x in cntrd)/expected
def chi2Probability(dof, distance):
    return 1.0 - GammaInc_Q( 0.5*dof, 0.5*distance)
def chi2IsUniform(dataSet, significance):
    dof = len(dataSet)-1
    dist = chi2UniformDistance(dataSet)
    return chi2Probability( dof, dist ) > significance
dset1 = [ 199809, 200665, 199607, 200270, 199649 ]
dset2 = [ 522573, 244456, 139979,  71531,  21461 ]
for ds in (dset1, dset2):
    print "Data set:", ds
    dof = len(ds)-1
    distance =chi2UniformDistance(ds)
    print "dof: %d distance: %.4f" % (dof, distance),
    prob = chi2Probability( dof, distance)
    print "probability: %.4f"%prob,
    print "uniform? ", "Yes"if chi2IsUniform(ds,0.05) else "No"
Output:
Data set: [199809, 200665, 199607, 200270, 199649]
dof: 4 distance: 4.146280 probability: 0.3866 uniform? Yes
Data set: [522573, 244456, 139979, 71531, 21461]
dof: 4 distance: 790063.275940 probability: 0.0000 uniform? No
R is respected and well established as a statistics package. I would not advise her to worry about other languages unless it was unavoidable.
I think that it's clear from the direct comparison that the chi square function is more easily implemented in R ##-## the OP said that R was mandatory, anyway ##-## I presume that merely casually reading other languages for comparison purposes, as distinguished from coding in them, would not cause his daughter to become too distracted ##-## I agree that it's important to keep focused when learning a new programming language; however, I also suppose that seeing how things are done in other languages can help to bring about a valuable sense of perspective.
Likes FactChecker
